[Oshpark] BLF SRK FET v3 (46mm / LFPAK56 / Dual+Triple Channel / ATtiny13A+85)
98 posts / 0 new
BeardedRaleigh
BeardedRaleigh's picture
Last seen: 3 hours 39 min ago
Tom E wrote:
Ordered! Thanks!!
Ooooohhhhhhhhh.
Slow is smooth, smooth is fast.
HarleyQuin
HarleyQuin's picture
A first look at the next version.
Goal is to implement programming while maintaining high current capabilities. I will go with the “jester” design, simply because it’s more space-efficient.
In v3.5 the MCU was much more below the center and I really don’t want the cells to short with the ground via of the programming pad…
So the MCU had to go up, while the BAT+ vias should as well be out of reach for the cells. Really don’t want the cells scraping these vias. To keep as much BAT+ vias as possible, they needed to be distributed sideways… and the rest just fell in place.
Advantages are really fat current paths, be it from the ground ring to source, from drain to LED+, from the cells to LED+ and for all AMC7135, where the route widens with the amount of 7135s. And having the output path of the 7135s not under them allows for larger ground pads of all 7135s.
Some finetuning needed and it should be ready.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
Lexel
Lexel's picture
Last seen: 1 hour 12 min ago
could we please agree on one programming key standard?
why now make a 2. with different footprint and pin orientation?
2 examples of course depending on driver minimum is 2 viases and total of 6 pads and if possible no conducting parts left and right in the upper row, even if on latest I insulated on the key those pogos from ground
you can use your key on my footprint without any modification, reverse it does not fit
HarleyQuin
Lexel wrote:
could we please agree on one programming key standard? why now make a 2. with different footprint and pin orientation? 2 examples of course depending on driver minimum is 2 viases and total of 6 pads and if possible no conducting parts left and right in the upper row, even if on latest I insulated on the key those pogos from ground … picture … you can use your key on my footprint without any modification, reverse it does not fit
a)
this SRK driver
Ah, you disconnected your orientation pins from ground, that allows some interoperability and avoids the short between VCC and GND.
I can make this driver dual purpose to fit your key as well.
It’ll loose orientation protection but I trust those who build this one know what they’re doing.
b)
key standard
I can’t give us a common standard because I will not use a single standard even on all of my own boards.
I thought I had explained in my progkey thread. Will try again:
I tried your pin distribution (3+3 with VCC down center) on several of my drivers and it did not work well. Simply impossible on one, difficult to route on others. Your orientation pin is where the VCC via will be, much better to use it just there. And I want more vias, preferably all of them, the contact on pads sucks.
Don’t get me wrong, the idea of a programming key is fabulous and I’m absolutely grateful you introduced it on BLF with ways for a practical solution. I’m so giddy about this that I did more driver developing in the last month than in the whole rest of the year. A bit like when the OTC was introduced. Major Step. A Real Thing.
So I tried different approaches and I saw that I don’t want to limit even myself to a certain layout. There’s one layout I prefer, but I can’t get it to work on all boards. So these became my priorities:
- as much vias for the pogo pins as possible (preferably 6, for good contact)
- least possible routing for the prog part (often the space is already needed for the driver circuit)
- avoid wrong orientation, so no symmetry up and down
So I made the 4+4 progkey that allows all this, is universal, small, dirt cheap and easy to build.
You know, these are all drivers I use myself, highly customized, some for just a single type of flashlight. Some have 1s/2s and double/triple channel selectable on one small PCB. I want to keep the freedom to use the best programming pattern for each driver. That’s why I chose a flexible approach, and shared the progkey to use it. I simply share what I use myself. Anyone who wants to use it, can freely do so. It’s my way of giving something back to the community.
Those who use your drivers can use your key. That’s perfect. And I really suggest they do, because that way it’s foolproof!
And the small handful of hardcore DIYers that really build my boards, well, for 4 bucks and change they get 3 progkey PCBs from Oshpark and 100 pogo pins from Fasttech and can program all they need.
Oshpark Boards:
HarleyQuin
BLF SRK FET v3.6
Same circuit, but some major overhaul.
Added Vias for a Programming Key to allow for programming while the driver stays in the light.
Performance optimizations: Even more LED+ vias, more GND vias around the FET, wide path from GND to Source
LED+ vias still unmasked to allow filling with solder and all vias are inside the battery contact circle
LED pads reduced to 2×3, but each pad increased in diameter
Unified the other pads: octagonal for both switch pads, round for I3/I7/Tin/T+, square for I-/T-
Honestly, can’t wait to get these into my SRKs Crazy
https://www.oshpark.com/shared_projects/LZhFeMG8
Schematic:
Pin5 is hardwired to the single 7135 (Q1) for the low modes.
Pin6 and Pin3 can, using the fancy 4-pad-connector (aka QuadPad), alternatively be connected to Q2-11 or the FET.
For the Attiny13A: use Pin6 for the channel you want to PWM, be it the FET or Q2-11. Use Pin3 for the channel you want to just switch on/off.
Mind that the position of the pads within the QuadPad has changed due to the optimization of the driver.
Component list:
- 13A/85: MCU ATtiny13A or 25/45/85; 8S1 (SSU) or 8S2 (20SU)
- FET: n-channel MOSFET at Pin3 or Pin6; LFPAK56
- (Rgate): series gate resistor; use the QuadPad (FET-to-pin3 or FET-to-pin6); 0805
- Rpldn: pulldown resistor (gate to GND); 0805
- Q1: single AMC7135 at pin5; SOT-89
- Q2-11: up to 10 AMC7135 at pin3 or pin6; SOT-89
- R5: series resistor between VCC and MCU pin1; 0805
- D1: schottky diode for 1S (4.2V); SOD-323
- LDO: low dropout regulator for 2S (8.4V) [LDO needs C1 and C2]; SOT-23-5 (Vout is pin5)
- C1: input capacitor between VCC/LED+ [behind R5] and GND; 0805
- C2: decoupling capacitor for MCU; 0805
- C3: additional capacitor between VCC/LED+ and GND; 0805
- C4: capacitor between drain/LED- and GND; 0805
- R1: voltage divider to VCC [before D1 / behind R5]; 0805
- R2: voltage divider to GND; 0805
- Rb: bleeder resistor from VCC to GND; 0805
- SW+: pad for momentary switch to pin2
- SW-: pad for momentary switch to GND
- Tin/Rt1/Rt2/T+/T-/Ct: external temperature sensor
- I3/Ri3/I-: indicator LED at Pin3
- I7/Ri7/I-: indicator LED at Pin7
Notes:
- Rb is parallel to C3 and can be used to add capacitance
- Ct is parallel to C2 and can be used to add capacitance or for a zener diode
- Q1 can be used as Nanjg star 2
- Rt2 can be used as Nanjg star 3
- SW+/SW- can be used for an OTC or as Nanjg star 4
- a momentary switch at Pin3 can be soldered to the QuadPad
Oshpark Boards:
HarleyQuin
reserved for application examples
Oshpark Boards:
DavidEF
DavidEF's picture
Last seen: 2 days 10 min ago
That’s a really nice looking board. It’s nice having all those easy to find pads for temp sensor and indicator LEDs, as well as the programming vias/pads and all the other great features.
EDIT: I saw your post in Mike C’s GAW thread. Seeing this new board design, I’m wondering whether you have any intention of moving to more advanced MCU chips in the near future, or if you think ATtiny85 is good enough for your purposes for the foreseeable future.
- The YKK Philosophy
