Ok, so I am getting a light that uses 4 14500’s in series. I am planning to use protected batteries for this light, I am thinking either XTAR or Keeppower’s.
But, I am open to suggestion, since this will be a first for me…
Matt I don’t have experience with Xtar cells but have used keeppower, though not extensively. They weren’t high current but you can’t really expect that from little cells. Otherwise they seemed fine.
Same make and capacity…?…yes and no. Using cells of even slightly varying capacities will also have different internal resistance so drain at different rates. If the light is not a hotrod and all the cells are protected then I don’t see it as a huge problem. There maybe slightly shorter run times but no biggy. If you’re relying on driver LVP on unprotected cells then that will be a problem if the cells are not matched.
