Ever had a flashlight lens spontaneously break?
20 posts / 0 new
Bort
Bort's picture
Last seen: 5 hours 43 min ago
Pics below, its hard to see in the photo but the lens cracked while in the holster and not dropped.
Along the edge is broken about 1/3 way around (but hard to see) in addition to the center crack shown.
Anyone else have this happen?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Edited by: Bort on 07/14/2016 - 01:27
Angler
Angler's picture
Last seen: 4 hours 22 min ago
Had you ever had the lens out to inspect it prior? Could have had a small defect, like a nick or scratch on the side. Or possibly an internal defect in the glass aka an inclusion. Either would eventually succumb to thermal stress, at a potentially unexpected time like even when the light is off.
tru3s1lv3r
tru3s1lv3r's picture
Last seen: 22 hours 41 min ago
I had one crack on me when screwing the bezel back on. I didn’t think I had it on too tight, but I guess I did. It sucked either way having to buy another UCL lens…
Aspiring Fhashlightaholic!
Jack Kellar
Jack Kellar's picture
Last seen: 4 weeks 1 day ago
I had that happen to me with a Thrunite Archer 2A v2 very recently. The break came along with a rip in the GITD o-ring at the bezel. Kinda disturbing since I didn’t even drop the dang thing, it literally fell on its side from headstanding when it happened, and it had tanked some true tumbles before with no damage at all.
A good talk with CS had me with replacements for both parts, and all is good now.
Boaz
Boaz's picture
Last seen: 6 hours 29 min ago
Yep .. I have a couple lights with broken lenses . I think it’s a bezel issue in my case . Both lights came with broken glass. Not a big deal .
snakebite
snakebite's picture
Last seen: 3 days 19 hours ago
look for a high spot,debris,ect on the bezel or head in that area.it delivers concentrated stress there and a temp change might be all it takes to crack it.
FrontPorchCarver
Yep this happened to me just two days ago. I had recently disassembled an old Preon to do an emitter swap, and after disassembly the lens cracked while the flashlight was off and just sitting there. I think heating the head to release the threadlock was mainly to blame.
Bort
Bort's picture
I have had the glass out, maybe last year, the light has not been used on high power for maybe a few weeks, and i have not done anything like heat the head for modding purposes. I don’t recall any chips or defects. This could have happened any time in the last few days, and what bothers me the most is potentially having glass dust possible in several places or along the floors of my place. Also i have to remove it to prevent more broken glass ending up everywhere, and getting a replacement is not in the cards right now Sad
will34
will34's picture
Last seen: 4 hours 50 min ago
Happened with a Courui, too much pressure from the bezel and it suddenly just cracked
FlashKat
Last seen: 6 hours 28 min ago
A new lens is not that expensive. Do you know what size the lens is?
Beachlogger
Last seen: 1 day 10 hours ago
I noticed one day my$10 crelant ch10 clone had a broken lens. Doesn’t really bother me as long as the 2 halves stay put. It’s actually been a nice beater work light Smile
Bort
Bort's picture
31.86mm, i’ll round that to 32mm
FlashKat
Thickness?
What country do you live in?
!{width:60%}https://s31.postimg.org/yfxl51iej/image.jpg!
Bort
Bort's picture
FlashKat wrote:
Thickness?
1.57mm
Canada
FlashKat
I thought I had that size, but mine is 37.5
Bort wrote:
FlashKat wrote:
Thickness?
1.57mm
Canada
xv-750
xv-750's picture
I’ve seen glass shatter after 8 months use without being touched or used at the time – it was a 6 place glass top table and broke into lots of little pieces and was about 6mm thick.
Riding for 50 years, last off was black ice in ’73.
First paid computer job was in ’75, writing an extra report for HAPAS accounts on a Wang Computer.
DB Custom
DB Custom's picture
Last seen: 6 hours 36 min ago
I have quite a few glass lenses here Bort, I’ll check that size and see if I can fix you up… Wink
31.86mm dia x 1.57mm thickness, right?
Dale
DB Custom
DB Custom's picture
I looked through over 80 glass lenses, the closest I found was 29 or 36.
I could probably order one from flashlightlens.com and have it sent to you as cheap or cheaper than I could mail one to you directly.
I think I have a 35mm UCLp for an X6 that I could reduce the diameter on, these are all 2.25mm thick though, if that would make a difference.
Going over to Chris’s shop to see if he has a glass one in your size…
Dale
DB Custom
DB Custom's picture
Chris has an AR coated UCL glass lens at 31.52mm x 1.85mm thick for $5.25. Want me to have it sent your way?
Dale
DB Custom
DB Custom's picture
Might be of interest to name the light, I can’t tell what it is from the pictures.
Shipping to Canada for Chris (flashlightlens.com) is $10 plus the $5.25 for the lens itself, makes me wonder if the light is worth a $15 lens replacement… some are some aren’t.
Also wondering if an UCLp in Acrylic might serve better in a light that had a glass lens break without obvious reason. The UCLp at 31.52×2.25 is the same price, in case you were wondering.
Y’all may have seen by now that I like to compare perspectives, so if you think a $15 lens is ridiculous think about this, I got a burger at McDonalds the other day that cost me $7.75 just for me, the Lone Star Stacker, and it was ok but not great. So if a burger can come that close to being $10, obviously a dessert would approach the $15 of this lens. Relative perspectives, one is gone in a matter of hours the other can last a veritable lifetime. Wink
Edit: And no, I didn’t even consider looking at prices of plain glass lenses without AR coating, if it’s got to be replaced it may as well be an upgrade. Silly
Dale
