This is the new Orca T11 single AA powered flashlight.
I received this light from Orca (through Amazon) for a discounted price in exchange for reviewing.
Link to light Amazon.com
Price at time of this review $34.98
I find this light to be a very well built and robust EDC. It is AA powered ONLY and will not except 14500 cells. With that being said for AA power only it does have a really good output for the size and the power source. I would like to see a 14500 version or dual cell capable version of this light made.
If you are looking for a light to mod then this is not the one , as everything other than the tailcap and switch is sealed (glued). I don’t think I mentioned in the video but I found NO sharp edges anywhere on this light and the anodizing is pretty much flawless as is the reflector inside that sealed head. The beam is a nice smooth beam with no rings or artifacts that I can see in regular use and NO detectable PWM.
I did a water submersion test of 10 hours at about 6 feet deep as these lights are rated water proof and Orca even asked me if I could do water testing……the results are in the video as well as still shots of the light and some still beamshots with some shining around outside and comparing with my TG06. I also forgot to mention the light comes with a really nice little holster as well as lanyard , extra Orings and one AA cell.
The video and specs below it…………………
Package Included:
- 1*Flashlight:Orcatorch T11 six modes white light flashlight
- 1*AA unrechargeable battery
- Accessories:1* lanyard
- 2*Waterproof O-ring
1*belt clip
Product Parameter:
Lamp type: Cree XP-G2 (R5) LED , max 190 lumens output
Working voltage:0.8-3V
Lumens (brightness) and battery life: Turbo(190lumen with runtme 2.6h)-High(80lumen with runtme 7.6h)-Middle(30lumen with runtme 19.8h)-Low(10lumen with runtme 60h)
Mode or stalls: Six modes(Turbo-High-Middle-Low-Strobe-SOS)
Irradiation distance: 106M (347feet)
LED runtime: 50,000hours
Using Battery: One AA battery (note torch operating voltage range)
Waterproof level: IP68, can prevent rain and living water
Size: 104.6mm(Length) x 25mm(Head Diameter) x 23mm(Tail Diameter)
Flashlight Weight: 55g (excluding battery)
Body Material: Aircraft-grade Aluminum with high hardness, light weight
Surface Technology: Type III military hard-anodized anti-abrasive finish with high strength and good wear resistance
Class: Toughened glass with anti-reflective coating
Cup: Aluminum alloy material, strong impact and scratch resistant, anti-aging, good fire resistance
