Build/Mod: Zoomie with Brynite B158B host (wider flood mod)
43 posts / 0 new
Mike C
Mike C's picture
I ordered some B158B hosts directly from Brynite to evaluate if I want to use this host with my drivers as my “production” zoomie for fellow cave/mine explorers/photographers. So, let the evaluation begin…
The first thing I had to deal with is the pill can’t take a 20mm Noctigon. I new this from other threads so it was no surprise. However, I did not want file down the 20mm to size. The idea is that this is going to be a production light so I don’t wanna do that for each build, so I needed a reliable method to center a 16mm. I found a driver retaining ring from some old light that fit in the pill perfectly after just a little filing. Then I slapped on some Artic Alumina adhesive and stuck in a Nichia 219c on a 16mm Noctigon:
Then push the retaining ring over the LED to keep if centered while adhesive dries. I had to make sure I didn’t slap on too much adhesive as I want to re-use the retaining ring for all B158B builds. It worked perfectly:
My 17.7mm drivers where just a little too small so I had to solder it in. I used a G-12 in this one (12 × 380mA 7135s). I’ll be making the diameter a little larger for B158B based lights, but soldering would have to do for now:
The plastic ring for LED fits back on, makes it look cleaner than the bare Noctigon with soldered wires.
The next thing I had to deal with was the forward clicky switch. I don’t like them, I want reverse. I know BLF user Cula replaced the contact board and raised the new switch with epoxy putty, but I find a different way which works good enough and uses the original board. I took out the plastic cradle that holds the switch and hacked it up a bit. It ain’t pretty I don’t care, it’s not a visible part. Here next to an original:
I put a Omten switch upside down in the cradle, turned the cradle upside down, filed down the original switch hole a little for perfect height match and soldered the switch into place. The original forward clicky switch on the left, mine with the reverse clicky on the right:
So the light was ready for testing. Some here at BLF may know I use wide floods for climbing and photography. Most use zoomies for pencil beams, but I don’t (although it’s fun), I need and adjustable flood that can go wide… and the B158B does not. It doesn’t cut it, too narrow for my use. However, there is a lot of room between the pill and lens so there definitely room enough for a wide flood, but the flood wideness stops early because of the tube design. If Brynite made made the threaded part about 8mm longer and removed the same 8mm from the wider non threaded part, and removed 8mm from the outer tube, then the light would be able to utilize wider flood without sacrificing focused beam:
The good thing is it can be fixed rather easily. I screwed out the pill about 8mm. I’ll have to find a way to fix the pill to the tube with it hanging out this much, like some thin tubing that’s thin enough to fit inside the host’s inner tube without hitting the outer tube so the pill can go all the way in for that focused beam.
Of coarse with the pill screwed out this far the cell won’t make contact with the tail switch spring. So I had to make the tail switch spring reach longer. I took apart the tail cap again and moved that white “spring cover retainer” from under to the top of the tail switch retainer ring, and stuck it with epoxy:
But the spring inside the tail cap isn’t long enough and I couldn’t be bothered to replace the spring so I just made the spring cap solid instead of hollow by filling it up with copper wire (I filled it with solder after):
Tail cap assembled again, and now I have a tail cap spring that pushes the cell onto the driver and keeps contact all the way until the pill is fully screwed out:
So, I now have the perfect zoomie. It’s waterproof (according to rating, will be properly tested later) and now has a very wide flood that almost rivals my widest zoomie without sacrificing the focused beam at all.
With these mods this is now my favorite zoomie host by a lot. I can now sell lights to my caving/mine buddies with a quality host instead of the cheapo one I’ve used before.
I’ve been dealing with Martin from Brynite. So far he has been very fast and helpful. I don’t know if Brynite will want to make changes to the host design, but it doesn’t hurt to ask Martin if they are willing to. Most importantly I’d like the the threaded part of the inner tube to be 8mm longer and the fatter non threaded part 8mm shorter (so overall length is same but there is more threading). The outer tube would have to be shortened by 8mm too. With these changes I wouldn’t have to lengthen the tail cap spring. Second I’d like LED place in the pill widened so a 20mm Noctigon fits perfectly, or make a 20mm capable pill as an option (they do sell pills separately).
I’ll ask Martin about these changes and see what he says… Maybe there will be a minimum order for making changes like this, it doesn’t cost to ask though.
Edited by: Mike C on 07/24/2016 - 04:07
pscal
Last seen: 2 weeks 3 days ago
Looks great! A kan 28 switch fits that plastic cradle perfectly, with no filing required. A different switch boot is needed, though. Also, kiriba-ru’s pills fit a 16mm Noctigon perfectly, and are very thick (heavy) compared to the stock pills.
Does the B158B have logos on it? Do you know if it is possible to get one with no logos?
Edit: I especially like the flood mod, bringing the LED closer to the lens. That is a great idea.
Mike C
Mike C's picture
pscal wrote:
Looks great! A kan 28 switch fits that plastic cradle perfectly, with no spring lengthening required.
I lengthened the spring only because I’ve screwed the pill out for a much wider flood. No need to do it if you don’t want wider flood.
Thanks for the tip on the kan 28 switch though, will make building these lights a little easier. Are they good for about 6 amps? The Omten switches seem to be.
kiruba has pills for this light? Cool, thanks for this tip too!
Martin from Brynite offered with or without logos. I ordered without.
pscal
Mike C wrote:
I lengthened the spring only because I’ve screwed the pill out for a much wider flood. No need to do it if you don’t want wider flood. Thanks for the tip on the kan 28 switch though, will make building these lights a little easier. Are they good for about 6 amps? The Omten switches seem to be.
I understand now, pardon my hasty reading (edited my post before your reply hit). The flood mod is awesome. I have not had any issues with Kan 28s with direct drive lights, but I can’t guarantee anything Smile
Awesome!!
MRsDNF
MRsDNF's picture
Last seen: 16 hours 48 min ago
Wow. Lotsaworkgoneintothisone. Smile
LightRider
LightRider's picture
Last seen: 2 years 2 months ago
Very cool! So there are enough threads in the head to continue twisting til stopped by the pill? I always prefer these kinds of lights without branding as well.
Mike C
Mike C's picture
Enough threads for the pill to be screwed out about 8mm. Screw it out longer and the inner tube’s threads pop out. The pill is pretty close to the lens too, I don’t wanna be scratching it by hitting it with the pill. 8mm is about right, makes for a pretty wide flooder.
Cula
Cula's picture
Last seen: 5 days 7 hours ago
Very nice mod Mike. It’s a great and versatile flashlight. I never thought I would like it so much but nowadays it’s my favorite one. Great work.
Nicolicous
Nicolicous's picture
Last seen: 17 min 32 sec ago
How far can this light throw with 12 × 7135 chips Mike?
Nico -.-
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 1 hour ago
Good mod.
But If I understood right you loosed full focus(zoom in) mode? Now you have flood light?
Also if my memory serves me right in this light you have greater flood mode by dedoming emitter (try this).
This is thrower flashlight so it would be really nice to see throw numbers with classic nichia and your driver.
The Miller
The Miller's picture
Last seen: 7 months 2 weeks ago
Wauw!
What smart clever solutions
Up side down switch
Getting the led closer to the lens.
Yes I have some contact with Martin too, excellent English AMD fast replies.
Anxiously awaiting if your suggestions can be done.
Mike C
Mike C's picture
Yeah, I really like it with the wider flood. The waterproof rating is good for us cavers. Your switch mod that pointed me in the right direction, so thanks for the write up you did on it Beer
I haven’t tried. I’m using Nichia 219c with dome intact. It’s a very nice tight beam, I haven’t tested throw distance.
No, that’s the beauty of this mod, full focus is still intact. With the pill extended out I can still twist it all the way in. So I have extended flood range but full focus is intact and untouched.
I have never seen a good tint after any de-dome with the de-domes I have tested. I really want to keep the 219C tint and CRI intact, it’s very important to me.
I’d like to know them too, but I don’t have the equipment to test. Maybe I should get it as I am selling lights to friends. What equipment do you recommend?
The Miller wrote:
Wauw!
Up side down switch
Thanks! About the mods, kiriba-ru might be able to make custom copper pills that are already extended, so there could be two ways to get it done. I’ll ask Martin by email tomorrow in any case.
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 4 months ago
Does the tail cap screw on if you screw the pill back in?
Scott
hank
hank's picture
Last seen: 5 hours 2 min ago
Got a link to any pages of caving pictures and stories? I did a lot in the US when I was a youngster. I miss it.
“Mr. Ranger, how many miles of the cave haven’t been discovered yet?”
LightRider
I did this with an sk98 a while back. I filed down the end of the pill to get the emitter closer to the lens. Then I added the extension to allow the zooming mechanism to slide fully back.
It worked well. Gave me just over focused when zoomed in and a nice wide flood when zoomed out.
djozz
djozz's picture
Last seen: 3 hours 46 min ago
Nice mod! A wide flood is very useful and not many zoomies have it.
The Kan28 is actually a switch that I tested: http://budgetlightforum.com/node/41577
Mike C
Mike C's picture
No, not quite. It looks like it’s almost in but it doesn’t make contact. Need the original tail cap if the pill is in it’s original spot.
Not much caves lately, but I got some photos I’ve taken down in old abandoned mines. check my photo stream on flikr for tghe latest: https://www.flickr.com/photos/akrylamid/
Some older: https://www.flickr.com/photos/akrylamid/6725168879/
And my absolute favorite photo I’ve ever taken so far:
I’ve made two video clips too:
https://www.youtube.com/watch?v=abAJLb_Vvnc
https://www.youtube.com/watch?v=X7CYayyw3LQ
Looks nice. I found a spacer for my pill in the plumbing section of a “home depot” style shop. Not a perfectly tight fit but it does the job, I can screw the pill tight on to it and it fits back down into the outer tube:
Mike C
Mike C's picture
Thanks!
And thanks for the link to your test. It looks like a good enough switch to use, it will make building these lights even easier then Smile
Rufusbduck
I suppose you could also buy a spare pill and put an 8 mm spacer under the Noctogon. Then it’s just a pill swap to get either type of beam(more flood or more throw) rather than dedicated take tail caps which aren’t as readily available since they sell spare pills but not spare tail caps.
Scott
“I’d like to know them too, but I don’t have the equipment to test. Maybe I should get it as I am selling lights to friends. What equipment do you recommend?”
10-30$ China lux meters should be ok for getting throw figures. Couple of threads about them on BLF search box but if I remember right you can’t go wrong with any cheapo luxmeter.
So you are pro photographer? Smile
I am looking forward for pics in zoom in an zoom out mode Wink
Your 12×7135 driver would be killer for old and unavailable xp-g2 s4 2b dd emitter cause in FET driver it draws about 4.2-4.5A giving around 300kcd in throw and also very fine and most intense flood mode in a zoomie world.
But since you are not candela hunter this will also be fine. Thumbs Up
Mike C
Mike C's picture
That’s the thing with my tail cap mod, I don’t have to screw the pill back in. I keep it 8mm out and it goes all the way in when I twist the tube for focus, there is enough threading on the inner tube for that. I don’t shift focus range, I only add range to flood. Full focus is same as stock. By reading others comments it appears that the Kan28 switch fits in the cradle without modding, so all I have to do is the “spring extension” mode, and that’s as easy (if not easier) than adding a 8mm spacer under the LED PCB.
I think I have one laying around. One I bought some time ago but haven’t tested it even once.
Definitely not pro. This photo is taken with a zoomie. Flood beam for the foreground lighting, then I ran to the back and light up the side with focused beam:
I might become a candela hunter yet, if I could get my hands on one of them old XP-G2s you mention I might get hooked. I am going to build a B158B with a XHP35 HI though, have to try it out with my F-8 with zener mod. F-8 has 8 × 7135s and a FET on a 17mm driver board.
The Miller
Wow what a interesting pic man!
OK today I am emailing with Martin about testing of their new 18650 cells
LOL one is now double charging (so with a USB cable direct and a charger. This was kind of exciting to do because Brinytes engineers could not say much more then “don’t do it, maybe the charging circuit fries and burns” so needless to say all progress was followed closely.
But I brought this topic to Martins attention. He is going to forward the information to the engineers, and sure Mike, if you mail him with more details they will consider it very seriously (I mean you just improved an already sweet zoomie so why wouldn’t they Wink )
LightRider
Is this b158b host available for purchase?
Mike C
Mike C's picture
Yeah, I promised Martin I would send him the link to my first build with impressions, so I’ll do it today even though you have, and suggest a B158C Smile
Yes. I sent an email to an email adress I found on Brynite’s website and asked. I was contacted by Martin, a very good person to deal with. He can be reached at ledflashlight@brinyte.net.
Martin Ren
Last seen: 3 years 7 months ago
Hi Mike ,
You have done a great job. It has drawed our boss’s attention, I will translate the entire article to my boss and engineers and wait to see whether there will be any change in our future flashlights.
You know we really have a short product line on photography light on land, even we have several photography flashlights for diving, but we really have no such a flashlight which is used in photography on land.
You showed us a direction of how to design our next flashlight. We will take in some of your experience.
Thank you for your advancing spirit and effort.
Brinyte, LED flashlight expert
www.brinyte.com
Email: ledflashlight@brinyte.net
Email: ledflashlight@brinyte.com
Martin Ren wrote:
Hi Mike ,
Sellers that actually follows BLF user experiences.
Well done Brinyte… If you can make even floodier B158B then why not? Wider beam for even more versatility Wink
Mike C
Mike C's picture
Hi there Martin.
I just sent an email with some photos and more detailed explanation of the suggested changes for the host (or new model B158C maybe?). Let us know if it is possible and if there would be a minimum order requirement to make a batch. Others here at BLF might be interested in such hosts or lights.
LightRider
Idk, but it seems that making a specialized or extended pill would be the easiest way to do it, but there may be more to it than I am seeing…
The Miller
If they move the cell this 8mm closer to the front as well could that not make the length 8mm shorter?
Mike C
Mike C's picture
Yep, the specialized extended pill is the easiest. kiriba-ru is making it for me Smile
This is what I suggested:
Add 8mm of threading to the inner tube, and remove 8mm of the fat part to keep same length on inner tube. Original on top, a crappy photo edit of what I’d like it to look like on the bottom:
For this to work the outer tube has to be 8mm shorter. Original on top, another crappy photo edit on the bottom.
The light will only be 8mm shorter when it’s in full flood. Otherwise length would be the same.
Of coarse maybe Brynite might prefer to make the extended pill and offer it as a separate part for flood extension. Personally I’d rather see changes to the host, would keep weight down a bit, especially if using kiriba-ru’s original copper pill vs extended copper pill, but I’d understand them if they preferred making a new pill instead of a new host.
LightRider
Ok. I see. I was thinking they would have to extend the Tailcap spring and leave the length the same. If they shortened the body and extended the threads, I agree that would me nice.
