jgradyc
(jgradyc)
July 24, 2016, 2:18am
1
I’ve had a Thrunite Ti keychain light for about five years. The problem I’m having recently is the twisty head has started coming off in my pocket. If I try to tighten it, of course, the light comes on!
How can I get the head to fit snugly enough that it doesn’t work itself off?
DBSAR
(DBSAR)
July 24, 2016, 2:27am
2
sounds like the o-ring is getting worn and loose. ( it may need to be replaced) i had a similar light that got loose, and fixed it with a thin single wrap of Teflon plumbers tape strip on the threads, it tightened up so it dont come loose or turn on in a pocket.
jgradyc
(jgradyc)
July 25, 2016, 12:11pm
3
DBSAR:
It took a double wrap, but this seems to work. Thanks!
I really like this little flashlight. With a 14500 battery it puts out an amazing amount of light.
DBSAR
(DBSAR)
July 25, 2016, 4:55pm
4
jgradyc:
DBSAR:
your welcome. threads do wear loose on heavily used twistie flashlights, the pipe tape trick usually works.
cyclops
(cyclops)
September 25, 2018, 5:54pm
7
jgradyc:
jgradyc:
DBSAR:
I really like this little flashlight. With a 10440 battery it puts out an amazing amount of light.
I still have these from 2012 and really like the form factor and finish. I was thinking of adding some more punch to it by using it on 10440.
Unfortunately I dont own any of the LiIon batteries so I will have to buy a battery and charger for it. Any suggestions?
Thanks!
Venice
(Venice)
September 25, 2018, 9:06pm
8
cyclops:
jgradyc:
jgradyc:
DBSAR:
Thanks!
Only the obvious; get the batteries and a charger.
It will open up new possibilities.
One poster mentions using a 14500, and another a 10440.
My guess is the AA sized 14500 was a typo?
And… I never knew the Ti3 could handle the higher power. I assume each mode is a bit brighter, or does it only kick in on High?
