Test/Review of Sony US18650VTC6 3000mAh (Green)
114 posts / 0 new
HKJ
HKJ's picture
Last seen: 21 hours 49 min ago
DSC_5460
Official specifications:
  • Typical capacity: 3120mAh
  • Minimum capacity: 3000mAh
  • Nominal voltage: 3.6V
  • Standard charge: CC/CV, 0.2C, 4.2V
  • Standard discharge: CC, 0.2C, 2.5V
  • End-of-charge voltage: 4.2V +/-0.05V
  • End-of-charge current: 0.02C (About 62mA)
  • End-of-discharge voltage: 2.00V
  • Continuous maximum discharge: 5C/10C (15A/30A) with temp cutoff at 80°C
  • Max. discharge current vs. time: 30A-40A > 44s, 55A > 19s, 80A > 6s (Never discharge above 80°C)
  • Cycle life: 300 cycles @ 0.5C to 80%
  • Initial impedance: 8mOhm – 18mOhm
  • Weight: 46.4g +/- 1.5g
  • Operating temperature: Charging 0°C ~45°C, discharging: -20°C ~ 60°C
  • Storage temperature: -5°C ~ 35°C
Sony%20US18650VTC6%203000mAh%20(Green)-info
The latest and probably last high current battery from Sony and it was a very high capacity together with the high current.
DSC_5459
DSC_5461 DSC_5462
DSC_5463
DSC_5464
DSC_5465
Sony%20US18650VTC6%203000mAh%20(Green)-Capacity
There is no doubt this is a quality battery, the curves track perfectly and capacity is nearly constant with current.
At high current the battery gets hot and I stopped the 20A and 30A test due to that.
Sony%20US18650VTC6%203000mAh%20(Green)-Temp-15.0
At 15A or greater Sony species that there must be a temperature cut-out at 80°C, I could just stay below that at 15A
Sony%20US18650VTC6%203000mAh%20(Green)-Temp-20.0
Sony%20US18650VTC6%203000mAh%20(Green)-Temp-30.0
But at 20A and 30A I hit 80°C or rather went above. Here I was up to 91°C.
Sony%20US18650VTC6%203000mAh%20(Green)-CapacityTimeHours
Sony%20US18650VTC6%203000mAh%20(Green)-Energy
Sony%20US18650VTC6%203000mAh%20(Green)-PowerLoadTime
Sony%20US18650VTC6%203000mAh%20(Green)-TripCurrent
Sony%20US18650VTC6%203000mAh%20(Green)-Charge
Conclusion
Very few batteries can handle high current as well as Sony VTC batteries and this cell also high capacity.
But this cell is not “draw all the current you want and stay safe” (That type of battery do not exist), to stay safe some requirements must be fulfilled!
I will rate it a very good battery.
Notes and links
The batteries was supplied by ENERDan for review.
Sony are in the process of selling their battery division (Except alkaline) to Murata.
Compare to 18650 and other batteries
EasyB
Last seen: 2 weeks 1 day ago
Nice, thanks. These discharge curves look very similar to the Samsung 30Q.
bugsy
Last seen: 4 years 2 months ago
Actually, this is clearly superior to the 30Q.
Has HKJ reviewed the HG2 yet?
HKJ
HKJ's picture
Similar, but a bit better.
blueb8llz
Last seen: 3 hours 9 min ago
thank you, i did not even know vtc6 even exist. does enerdan have a website so i can purchase these cells?
zelee
zelee's picture
Thanks for the review HKJ, it’s on my wishlist now
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
EasyB
Yes, but by a very small amount. I was mostly noting their similar shaped curves and IR. Comparing the curves, the IR of the 30Q is only about 2% higher than the Sony’s. The Sony does hold a 0.02-0.03V higher voltage throughout the discharge. This is not negligible, but it is a small difference. It equates to approximately 0.2A higher current in a direct drive XPL setup (or even a triple XPL setup).
HKJ
HKJ's picture
They do have a website, but they can only sell these cells to companies. Sony do not want these cells in the hand of vapers! Sony probably believe it is bad publicity if a vaper gets the mouth blown away by a Sony branded cell.
Lookout of rewrapped cells without Sony on them.
Note: Enerdan is a German company, i.e. they uses .de, not .com, it is probably also fairly expensive to ship outside Europe.
will34
will34's picture
Last seen: 9 hours 43 min ago
Wow, very nice… Hope to see them on sale soon. Thanks again HKJ for the review!
Here’s a comparison with the Samsung 30Qs and to what I strongly believe to be rewrapped LG HG2s:
Tom E
Tom E's picture
Last seen: 3 hours 13 min ago
Excellent review, once again! Interesting about the availability, but hopefully it's just a matter of time.
sidecross
sidecross's picture
Last seen: 3 years 4 months ago
!{width:60%}http://i.imgur.com/8bxe60B.png!
+1
HKJ provides a valuable resource in this ‘Battery Comparator’ link.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
MG
Thanks for adding this one to your excellent library of battery reviews.
RobertB
RobertB's picture
Last seen: 1 day 15 hours ago
Sony makes it very clear they don’t want individual cells in the hands of consumers no matter what they use them for. They even say on their spec sheets “these cells are designed to be used in packs. Not for individual use”
Barkuti
Barkuti's picture
Last seen: 3 hours 7 min ago
Hello!
Do these batteries purport to be any better than LG HG2s a year later? Sick
I'd take VTC5s any day.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
will34
will34's picture
I’d take VTC5s any day.
But HG2 and 30Q are already better than the VTC5…
The reason you see still see so much praise for the VTC5 is because of the vaping community, but their need for very high pulsing current are vastly different to ours…
Barkuti
Barkuti's picture
will34 wrote:
But HG2 and 30Q are already better than the VTC5...
The reason you see still see so much praise for the VTC5 is because of the vaping community, but their need for very high pulsing current are vastly different to ours...
Of course a matter of opinions. Vaping is not the only high current application, there are others yet, of course, for each battery a freak like me may decide to use to hack/overhaul/repair a tool's pack, more than a thousand may go to vapers' hands.
By the way, I'd love to see a well done review of the A123 systems ANR26650M1A (and or the newer ANR26650M1B) batteries, and see if those can really deliver what they claim to. Question
Cheers Party
Tom E
Tom E's picture
I'm not sure, but HKJ's calculated internal resistance of 0.03 for this VTC6 is, I think, the best we've seen? The other top cells, I think, are all 0.04 ohms.
I don't think it's the only important spec, but I find HKJ's internal resistance # the most important spec for DD FET based drivers.
cabfrank
Last seen: 2 hours 30 min ago
Let’s hope Murata will continue with the Sony quality.
Thanks as always, HKJ.
Mitko
Mitko's picture
Thanks for that great review m8, we have a new BLF fed dd king i presume
Tom E
Tom E's picture
Yea, might be, but hope we can get them though.
Mitko
Mitko's picture
We will Tom, sooner or later we will, have have dozen throwers vaiting for them impatiently Smile
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 6 days ago
Mooch from reddit , confirmed it can be found also as Enercig EC-C6 . It has Sony VTC6 inside .
jescereal
jescereal's picture
Last seen: 1 week 1 day ago
I’m a bit curious, why it could be their last?
sidecross
sidecross's picture
Sony announced they will no longer produce batteries.
will34
will34's picture
I do hope they sell their technology to another Japanese cell maker…
sidecross
sidecross's picture
Tesla is building and will on completion have the largest lithium battery production facility in the world outside of Reno, Nevada in the U.S.
I would expect increases in battery technology to fill an enlarging amount of products using this energy technology.
HKJ
HKJ's picture
Because they are selling their battery division, I did write that at in the notes.
cabfrank
Yes, to Murata, as HKJ said.
nofearek9
nofearek9's picture
thanks for the review ,nice battery ,any link to buy them ?
jescereal
jescereal's picture
Whoops sorry, I didn’t notice it. Facepalm But thanks for the answer!
shadockan
shadockan's picture
Last seen: 1 day 23 hours ago
Personally I do not think it stops.
One of the battery manufacturing companies on behalf of N.A.S.A. It is not easy to stop …………..
Personal opinion of course …….
