Review of DP50V5A & DPS3012 bench top power supply modules, best bang for the buck around!
145 posts / 0 new
smile
Last seen: 2 years 2 months ago
Nice power supplies, the screen makes it a bargain. But why so low frequency?
I wanted to drive power leds in cc mode. Given the fact that unit has very nice color screen!
Specialized LED drivers like the LED2001PHR work at 850khz fixed frequency so you don’t ever get flicker even on camera.
Is RDtech willing to release series for LED driving? Like RGB, RGBW versions would be awesome.
Even upgrading switching frequency on current units would be good enough for me.
RD tech
RD tech's picture
Last seen: 1 day 9 hours ago
you can connect the LED directly … only the current is closed to resolution , it will blinking
for example , DPS5015, the resultion is 0.01A, if the current is 0-0.05 , it will be blinking .. when the current is more than 0.1a , it will not be blinking …
for DPS5005, The resolution is 0.001A, at 0-0.005, it will be blinking, more than 0.01A, it will not be blinking
so the resolution will affect this ..
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
iglon
Last seen: 2 years 1 month ago
how can I connect bluetooth module ?
I cannot find any documentation on that subject.
I have DSP5005 with communication modules; USB works just fine but I cannot get Bluetooth module to work with DPS5005 PC Software V1.3.
How does blue-tooth module connects to DSP 5005?
Any information is welcome.
pulu
Last seen: 1 year 11 months ago
re the DPS5015, which I ve noticed there is not much referene to!
I have riged up a DPS5015, and it is working ok, loaded at 3 amps.
But, the fan is not moving.
My question, which , so far, no one has been able to answer, is “should the fan work all the time, or only at a certain temperature”?
Pulu
HKJ
HKJ's picture
Last seen: 13 hours 16 min ago
In the models I have tested the fan start above a certain current, but also on temperature.
thijsco19
Last seen: 6 days 2 hours ago
Noticed they have a 1000W cv cc buck converter, 50V and 20A.
Pretty impressive.
https://www.aliexpress.com/store/product/RD-DPS5020-Constant-Voltage-cur...LCD-voltmeter/923042_32821185351.html?spm=2114.12010608.0.0.4ab05bc5KWFxl8
I’m still figuring out of I need and want one or not. (obviously, I want it but not really need it Big Smile )
dchomak
Last seen: 1 year 9 months ago
As in my case, you won’t actually realize how much you need it until you get one Wink
I really don’t know how I got by with out it, use it all the time.
RD tech
RD tech's picture
1, Our DPS power supply android APP was published today,
A, Now it is only support communication version of DPS3005 , DPS5005 and DPS8005. If you have bluetooth board, you can connect it with android phone (only support android 5.0 and above).
This is the down load link (or you can check their file link ) http://www.mediafire.com/folder/i5iu0dw7rrwpx/DPS_power_supply_APP .
This is the video for APP : https://youtu.be/-hBzL224dZk
If you have USB version and not have BT board, you can make order here to buy a bluetooth board https://www.aliexpress.com/store/product/RD-bluetooth-board-for-DPS-and-DPH-power-supply-communication-version/923042_32882334859.html (if you have no communication version, don’t buy it)
B, For other power supply communication version (DPS5015. DPS5020,DPH5005), APP is designing ,in the future Maybe you just update this app on line to get new APP. Now please wait our good news
This is all DPS power supply link, you can check https://rdtech.aliexpress.com/store/group/DPS-digital-control-power-supp...
2, our new products UM34 USB 3.0 meter and USB load LD25 (25W, intelligence control ). For the old rules, new products are published, there is lowest price in 4 days , UM34 12.99 USD (normal price 16 USD), UM34C 16.98 USD (normal price 20 USD). LD25 8.99 USD (normal price 11 USD ), buying together will more cheaper, please check the link.
UM34 link: https://www.aliexpress.com/store/product/RD-UM34-UM34C-for-APP-USB-3-0-Type-C-DC-Voltmeter-ammeter-voltage-current-meter/923042_32880908871.html
LD24 link https://www.aliexpress.com/store/product/RD-LD25-Electronic-Load-resistor-USB-Interface-Discharge-battery-test-LED-display-fan-adjustable-current-voltage/923042_32882318330.html
UM34 video : https://youtu.be/zZCPJQrqKPU
A, UM34 is better than UM24, same interface with UM25, have USB 3.0 port.
B, only APP, not PC software, precision is better than UM24, not better than UM25C,
C, LD24 is digital control USB load, have many protection(OVP,OPP,OTP) , can set the output state and current, big power 25w.
Thank you again for read so many thing, if you want to learn more , please check the page
This is our home page : https://rdtech.aliexpress.com/store/923042
Hope you like our APP and new products
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 21 hours ago
Do these latest versions support logging now? I have not kept up with them recently.
RD tech
RD tech's picture
the APP has this function , for PC software, we did not add
prototype3a
Last seen: 1 day 22 hours ago
I just spotted this DPH5005. Buck/Boost and up to 10A on the input side. Looks like a nice unit but I honestly wish it was even more powerful and could go up to 80vdc on the output to drive some of the new ~72vdc COBs.
https://www.aliexpress.com/store/product/RD-DPH5005-Buck-boost-converter...LCD-voltmeter/923042_32840324731.html
I may still get one to use with some of my 36-40v COBs.
Edit: HKJ Review
http://budgetlightforum.com/node/63598
moderator007
moderator007's picture
Last seen: 21 min 52 sec ago
https://www.aliexpress.com/store/product/RD-DPS8005-programmable-constan...?
Just needs a 80 volt power supply. Most are settable, set it at a little higher voltage and your good to go.
prototype3a
DPH series is buck boost. DPS is Buck only.
Enderman
Enderman's picture
Last seen: 18 hours 19 min ago
The more you boost voltage the less current it can output and the lower the efficiency is.
Making it a boost driver would overcomplicate things and just make it worse.
Get a good 80V power supply and just use the DPS.
prototype3a
No.
moderator007
Maybe pair the DPS 8005 with this https://www.aliexpress.com/item/S-400-80-Reliable-Quality-CE-RoHS-5A-400...?
If you think you might need a little more overhead choose the 500 watt model. https://www.aliexpress.com/item/720w-Switching-Power-Supply-adjustable-o...?
prototype3a wrote:
No.
Okay Beer
prototype3a
Lets be honest here. This is a flashlight forum and you’re suggesting that I use something that requires AC? If I wanted to do that, I could just buy a MeanWell HBG series LED driver/PSU.
The DPH series might be inefficient but it is potentially portable and it is flexible enough that I should be able to drive most any COB with it for testing.
Enderman
Enderman's picture
prototype3a wrote:
No.
Well then that’s your problem.
These DP power supplies are meant to be bench top power supplies.
If you want to build some giant flashlight with this instead of a regular LED driver then you just need to have enough batteries to reach 80V+ or use a DC to DC power supply. It doesn’t have to be AC. The DPS has DC input.
moderator007
Why not use this then if your just driving leds from a dc source. https://www.aliexpress.com/item/1-PC-DC-DC-600W-IN-10-60V-Out-12-80V-Boo...?
I thought you were looking for a power supply to test with and power COB leds. Facepalm
prototype3a
I looked at some of those boost converters and I could add a volt/amp/power meter to the output but the DPH is pretty close and a much nicer device.
In the end, I’m probably going to design my own driver since no one is crazy enough to make and sell a 300w buck/boost LED driver board.
I’d like to run my light on 6s lipo since it’s a convenient and readily available size. I may end up going 12s but I’d like to only need a single battery pack for convenience. Sure it won’t be all that efficient but this isn’t going to be a small light. The heatsink for the COB alone will likely be at least a kilogram. The whole thing may end up being 5kg. Also, I have a pile of 6s16AH packs so….
Enderman
Enderman's picture
Maybe you should try thinking about WHY nobody has made one, if it really is because nobody is “crazy enough” or because “it doesn’t work”.
You might want to do some research on boost driver efficiency, or your “crazy” 300W boost driver will barely light up your COB.
RD tech
RD tech's picture
thank you so much
for now buck-boost power supply, we only have DPH5005 and DPH3205
RD tech
RD tech's picture
for efficiency, YES, you are right
for input , our products request DC, because we only design DC -DC, we have designed them better, you only add a simple AC-DC, that’s ok,.
so you don’t need to spend lots money to buy expensive AC-DC power supply
RD tech
RD tech's picture
Enderman wrote:
prototype3a wrote:
No.
right , thank you for your explaination
