I need some advise to start my search
39 posts / 0 new
ZoomieFan
ZoomieFan's picture
Last seen: 1 week 2 days ago
First message after a lot of reading.
None my ‘demands’ are 100% fixed because expert advise may change my mind. But because I have to start somewhere my wishes are:
- Zoomie – Very important for me
- I prefer flashlights without strobe and SOS -> Less useless options is less chance something goes wrong with settings
- I prefer a sliding switch instead of a clicky switch*
- Must fit in the backpocket (may stick out) – Clip or holster is ok too.
- No memory or good memory (1)
- 26650 or 18650 (2)
- I don’t care about weight.
- Good battery life. Perhaps 2 or 3 batteries.
- Flat top batteries. I have a bunch of flat top 18650’s from a laptop and would like to use them in the flashlight.
- Strong. Surviving a fall from a yard high on concrete would be great.
- I don’t care at all it scratches easily or even if it has scratches right out the factory.
- A small bonus would be the flash fight can act as a powerbank.
1] = I have a flashlight with memory but when switched on it switches to the next mode. I would prefer a simple 3 setting sliding switch
2] = I have a lot of 18650 batteries from laptops so that’s what I likely will use most. Still I would like use 26650 (or bigger) because of more capacity. I’m doubting a bit on this because in my opinion a using a 18650 battery in a 26650 flashlight is a waste of compactness or battery life. I prefer a small flashlight but bigger is no issue if it has advantages. More battery life or brightness.
My use of the flashlight….
I don’t need a huge throw, but it would be a nice bonus.
It will be mostly used for walking in the dark. Dark basements. General stuff like changing a breaker.
My current flashlight is: https://www.amazon.com/gp/product/B00VZT2WP6/ref=oh_aui_detailpage_o06_s...
It’s quite ok. High is great when using outdoors but I prefer a lower setting when working indoors because high ‘reflects’ a little to much when for shining on something nearby.
Chargers: Dodge SC, 2x LiitoKala Lii 202, 2x LiitoKala Lii 100, Miboxer C4-12.
Flashlights: BLF Q8, Convoy BD04(1A) /BD06 (3B) /S2+(1A), FiTorch MR35, Zebralight H600Fc.
Edited by: ZoomieFan on 08/21/2016 - 15:35
The Miller
The Miller's picture
Last seen: 2 weeks 18 hours ago
Welcome to BLF!
That is an interesting list you got there Wink
Subbed because I am curious to see what the recommendations will be.
(Seeing that G700 type zoomie you got now there are a lot much better lights to discover!)
dhvl1357
Last seen: 20 hours 10 min ago
Subscribed. In the market for an SK98/clone myself, and the only nice one I’ve found is the Yupard at Aliexpress.
Slow is smooth; smooth is fast.
Alcius
Last seen: 4 months 1 week ago
Convoy BD04
It’s a zoomie + Convoy flashlights are generally good.
Just my 2 cents. I don’t have this particular flashlight.
The Miller
have the BD01 and BD06
not zoomies but the switch and charging is the same
EXCELLENT! Charging is so nice, clipon thingy so no connector inside the light
Memoryso no need to see blinkies
ZoomieFan
ZoomieFan's picture
Alcius wrote:
Convoy BD04
Thanks for the advise.
I don’t have enough knowledge to comment on it besides that I like the fact I can pick a 5 or 3 mode setting. The 3 mode setting has no strobe and SOS.
Quote:
Modes (mode option 1) : 5%Low-30%Mid-100%High-100%Strobe-100%SOS (mode option 2) : 5%Low-30%Mid-100%High
I don’t know how reliable that description is because elsewhere it states:
Quote:
Switch position Side
I looked at some pictures and an unboxing on YouTube but I see no side switch.
The text states the model is “CREE XML2 U2-1A” but a few lines below it gives specs of a different model.
https://www.amazon.com/dp/B01FHTQ7Q4/ref=wl_it_dp_o_pC_nS_ttl?_encoding=...
On this site nothing is mentioned about the ability to ‘configure away’ strobe and SOS
http://www.gearbest.com/led-flashlights/pp_211027.html
The clip is a nice extra.
ZoomieFan
ZoomieFan's picture
I noticed the flashlights come with quite a few different LEDs. Is there a good reference guide to the pros and cons of the most frequently used types?
I think they differ in color and efficiency.
Natural color is a nice bonus but more efficiency is more important for me because it means brighter light and/or more usage hours.
ZoomieFan
ZoomieFan's picture
The Miller wrote:
have the BD01 and BD06 not zoomies but the switch and charging is the same EXCELLENT! Charging is so nice, clipon thingy so no connector inside the light Memoryso no need to see blinkies
Do they work with flattop 18650's? I have a dozen of them from a laptop battery.
Blinkies are flashes. Isn't a flashlight that doesn't flash, broken? Crown
Boaz
Boaz's picture
Last seen: 5 min 38 sec ago
Color rendering IMHO is very important and the lumens you lose to gain a better tint and color are your best investment . all lights are bright as hell anyway . your (g700) Outlite A100 with a$3 ~ $5 driver and a 5$ emitter swap is probably not a horrible zoomie light . Most zoomies suck unless modded so search for the desirable ones people are modding and at least buy one of those . Bynite 158, supfirel2-f3, zeusray(if you can get a real one ) Slide switches don’t exist ….*Are you making stuff up ?? Smile 26650 batteries are over-rated imho and will never catch up to 18650’s …i don’t know of any 2X 18650 zoomies …at least none good ..just carry a spare cell or a second light . Zoomies are basiclly noob lights but that doesn’t mean they are simple and modding them to make them better can be a bit complicated if you really want them to throw maximun distances. do a search on the forum and spend some time reading about zoomies .
ZoomieFan
ZoomieFan's picture
Boaz,
The Outlite is quite good to my standards. But I’ve never seen a quality flashlight to compare. The clicky switch is very irritating. It remembers the last mode and when switched back on it starts in the next mode.
I’m not making up the slide switch thing. Innocent They do exist. Or at least did. I’m making no claims about today and LED lights but way back in my youth I had a flashlight with a sliding multi setting switch.
The Miller
Neutral white (3C/3D) has my preference in tint.
The Jaxman Z1 must be one of the best zoomies around.
single cell, double cell, XML2 XHP LEDs, wide hoice to
But more expensive and the Convoy is really nice.
The side button is a clicky, not electronic.
Alcius
“The clicky switch is very irritating. It remembers the last mode and when switched back on it starts in the next mode.”
All BLF members will agree with you, next mode memory (NMM) is not liked at all, over here . But I don’t believe that NMM is caused by the clicky switch. Some flashlight drivers are NMM, some are not. Generally, cheap drivers are NMM, more expensive ones are not.
hank
hank's picture
Last seen: 1 day 14 hours ago
Yup.
“next mode memory (NMM) … is caused by … Some … cheap drivers”
Clarify if you want a “slide” or a “side” switch?
A slide switch (like the old 2D cell flashlights) would be on the side.
Haven’t seen one in years except on cheap incandescent flashlights.
Most switches now are round buttons you press in halfway to change mode, all the way to click on/off
I don’t see a side switch on the Convoy BD04, but I don’t understand its setup — tailcap button, sliding battery holder, USB charger I guess also connects to the tail somehow.
ZoomieFan
ZoomieFan's picture
Hank, Yes a slide switch like on those ancient D cell flashlights. I would really like to slide trough all modes in a split second. Second best would be a mode switch and separate on/off switch. It's already clear the chance to find that is next to zero. I just thought if I don't ask I'll always be in the dark Facepalm Alcius, Good news about the memory. But I still prefer something without strobe or SOS. Or 5 instead of 3 'normal' modes. But 3 is good enough if spaced decently. Ideal, for me, would be if the light always starts up in the same mode I have configured. (not last used) On my Outlite high is brighter than medium but doesn't add much to visibility, so it drains batteries for no good reason.
One more thing about the price... I would prefer something about $21. Where I live importing things up to $21 is free. After that tax is added. Not much on a flashlight but the post office guys charge $15 handling fee to collect that tax.
So a $22 flashlight costs me $37 + taxes. I visit friend in the USA (Indiana) twice a year, so I could have my flashlight shipped to them IF there are no insane taxes. Anyone knows about such taxes/costs?
BrianK
Last seen: 4 weeks 1 day ago
I never heard of a tax being applied to a flashlight here in the ‘states. I’ve never paid one. Anyone else?
Will you pay duty when you clear customs?
teacher
teacher's picture
Last seen: 4 hours 28 min ago
Here is the latest in “slide switches”………..
The Rest of the Story
Not cheap though……… Wink
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||   Confucius say -- Baaa-haaaaaa......   tongue-out
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
ZoomieFan
ZoomieFan's picture
Luckily it’s not a zoomie so I can say “Nice light but no zoomie.” instead of “I’m to stingy for such a light.” Big Smile
I’ve seen one or two similar flashlights for divers. One had a dimmer switch. (stepless light output). They advised to remove the battery because (magnetic?) sliding switches have a small power leak….?
So they do exist. Perhaps only in the (somewhat) more expensive price range.
I’m preferring the around $20 but if a light meets most of my wishes I’m willing to at least double that.
General question: If the specs state “18650 battery” without more detail does that mean all 18650’s fit? Protected, unprotected, flat top, button top or a combination.
keengeorge
Last seen: 1 month 1 week ago
No. 18650 means the battery is nominally 18mm diameter x 65mm height, But in practice there is quite a bit of variation, & the protection circuit adds an additional 2-3mm approx.
And if they are button top, then that adds to the length as well.
Thus unfortunately, there often is an issue fitting a particular battery into a particular flashlight. So always check before buying either one.
Best Regards,
George
beam0
beam0's picture
Last seen: 2 hours 3 min ago
Take a look at this thread I started recently, I have a list with links to zoomies I’ve been looking at recently:
http://budgetlightforum.com/node/48549
Although it’s way over your budget for this the Fenix FD40 may be the only zoomie with a side switch, at least I can’t think of any other.
And there aren’t many low price zoomies without blinky modes.
_____________
Alcius wrote:
Convoy BD04 It’s a zoomie + Convoy flashlights are generally good. Just my 2 cents. I don’t have this particular flashlight.
I agree with Alcius, I think the Convoy BD04 may be the best option for you:
  • Price under $21 (with 15% BLF discount)
  • No strobe or SOS if you chose 3-mode (mode option 2)
  • You can choose your preferred tint color
  • Looks like a metal on/off mode switch on the tail
  • Fits protected or unprotected batteries (flattops)
  • Has built in USB charging, if that’s something you could use.
  • Convoy is known for good quality
You can get all the options if you buy it direct from Convoy, (send message to request BLF discount) here’s a link:
http://www.aliexpress.com/item/Convoy-BD04-zoomable-flashlight
I’m seriously considering getting a Convoy BD04
BTW Thorfire also makes the BD04 but it’s priced a lot higher and I don’t think there are any options for modes or tints like the Convoy has.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
ZoomieFan
ZoomieFan's picture
The Convoy BD04 looks nice. Zoomie, clip, no blinky, good memory, price is ok.
I have flattop 18650 batteries. Diameter 18mm, length 64mm. I’m wondering they will work in that flashlight. Not because of the size, which is very close to keengeorge’s numbers, but because the flattop may not make electrical contact.
Unfortunately the batteries are unbranded red without anything on it. They come from a Dell laptop battery pack which had ‘Made in Japan’ on it,
My current light is a Outlite A100 Cree XML-T6 LED Bulb,Adjustable focus, Zoom out 500-700 Lumen,Zoom in 700-900 Lumen.
The BD04 is 600 Lumen.
In theory it looks the Outlite is a little brighter. But is that really so? The advertised numbers quite often seem to be overly positive, not to say a scam.
ZoomieFan
ZoomieFan's picture
I really like the option of USB charging because I have lots op USB cables and chargers, also in my car. That adds a lot of flexibility which is good.
It worries me a bit that USB charging thingy gets misplaced. Anyone knows I can leave it permanently on the flashlight with it falling off. That’s likely how I would use it because after every (short) use I’ll likely put it my car charger. That means I have to have that thing with me at all times.
Peho
in my Convoy DB 03 flat top Samsung 26F works fine, it has spring on both sides and i think DB04 use same system
Fenix E35UE 2015, Crelant V6CS, Crelant V1A, KD C8, KD Buckle V6, Convoy S2+ Triple Nichia 219a, Astrolux A01, Olight I3 EOS and others
WojtekimbieR
Last seen: 1 day 1 hour ago
Thorfire also makes a 18650 zoomie, "TA13". Fits in your budget, without blinky modes.
Just for a moment... Okay I may stay a little longer
BrianK
Why not just leave the cable in the car since that’s where it’ll be used. You have a glove box, yes? Or maybe a center console?
But I’m considering my ordered life. Maybe your’s isn’t like mine.
Too, there are solutions for flat top cells if they don’t work; dabs of solder, magnets, but possibly the best solution I’ve seen are some flat top battery connectors. The link is somewhere on the forum, but can I find it now? No.
teacher
teacher's picture
I understand completely ZoomieFan!! Cash .. Cash … I’d just have to say I was to stingy……. CashCash
I should have made it clear I was just using it as an example of a “sliding switch” for the member who said he “had not seen one in years”.
My how the sliding switch has evolved since the days of the old chrome Rayovac………. Wink
member wrote:
Clarify if you want a “slide” or a “side” switch? A slide switch (like the old 2D cell flashlights) would be on the side. Haven’t seen one in years except on cheap incandescent flashlights. Most switches now are round buttons you press in halfway to change mode, all the way to click on/off
ZoomieFan
ZoomieFan's picture
My life is chaos. And that’s reflected everywhere I go! Smile
Seriously, I have chargers/cables about everywhere. Car, office, several rooms at home and even at places I frequently.
visit. My only concern is the that charging cap that clicked on the flashlight. I have only one of that.
ZoomieFan
ZoomieFan's picture
A 500 Lumen Rayovac required a backpack for the batteries Smile
Now I know where to look there are quite a few sliding switches. Most are expensive .
http://www.scubadiving.com/scuba-diving-gear-review-15-new-dive-lights-t...
Number 7 and 8. Stepless dimmers.
Just found a cheap one. No Zoomie. But if a 100m waterproof flashlight with a dimmer switch costs $30 the switch likely isn’t so expensive.
https://www.amazon.com/Soonfire-D01-Diving-Flashlight-Aluminum-alloy/dp/...
Now I even more hope to find a zoomie with a sliding switch. I was just looking for a 3 settings + off but a dimmer switch is ideal if it works as advertised.
The tech exists but I have yet to find it all combined into one flashlight.
There are quite a few diving zoomies (for filming) but they zoom only from 15 to 45 degrees. 140 when a cap is taken off.
Many of those lights are around 200 lumen. The search goes on…..
http://tovatec.com/product/fusion-1000/
https://www.amazon.com/Intova-IFL-WA-ZOOM-Aluminum-Compact-Flashlight/dp...
https://www.amazon.com/Intova-Tovatec-Powerbeam-Scuba-Diving/dp/B007SJMJSM
http://www.intova.com.au/products/fusion-1000/
http://scubaoutfittersnaples.com/diving-gear/dive-accessories/ifl-wa-zoo...
http://www.diversdirect.com/scuba-diving/tovatec-wa-zoom-r-video-light-f...
https://www.amazon.co.uk/Mares-Diving-Torch-ZOOM-Lumen/dp/B00SYZU23I
BrianK
I have an inexpensive diving light that has a simple sliding on/off switch, but the problem is that they use water for heat management* and doesn’t work so well in the air. I didn’t bring it up because it didn’t meet your specs.
*It’ll heat up a glass of water pretty quickly.
teacher
teacher's picture
Yep, it would have; if 500 lumens were even possible back then. Big Smile
Somewhere, I still have my old Rayovac like the one below. If I can locate it I may try to “spice it up” a little.
I think that would be hilarious to use it as a “host” and make it a more “modern” light. Wink
Looks like you have a good start on the ‘sliding switch zoomie’ hunt…. I’m betting you’ll track one down before the hunt ends. Thumbs Up
ZoomieFan
ZoomieFan's picture
I theory it can be souped up. But I think it requires a lot of work. The reflector likely is plastic that melts with a bright led. Less likely, but possible is that the switch doesn’t handle the current very well.
On the bright size there is a lot of space for batteries. An easier way would be to insert a small flashlight with a remote switch.
Makes me think of my idiot math teacher. He had a Porsche engine in his VW Beetle. Just for fun and to outrun luxury cars Smile
ZoomieFan
ZoomieFan's picture
Why is the Convoy BD04 always shown with that ring screwed off?
What’s the max. zoom angle?
