BLF A6 with X5 reflector, or BLF X5 with 18650 tube (A6 body)
144 posts / 0 new
alfas
Last seen: 1 day 9 hours ago
Is there any possibility I could assembly one of these options?
Would really be the perfect pocket thrower around. X6 is just a tad too big in diameter, and X5 reflector size is perfect but it lacks the large capacity for outdoor/camping use. A6 is great but lacks just a tad in throw. So, it would be the best of all worlds.
If there is any interest in the next BLF light I would vote for these one.
Edited by: alfas on 08/21/2016 - 09:58
Rufusbduck
Rufusbduck's picture
Try a convoy M1.
Scott
alfas
Rufusbduck wrote:
Try a convoy M1.
Is there any M1 options available [or M2 also, even better] with FET driver and XP-L HI ~1400 lumens output? If yes I’ll buy it right now.
Chicken Drumstick
Last seen: 6 months 5 days ago
X5 head on an 18650 body would be an awesome setup. I mentioned it when the X5 was first launched. Still amazed it hasn’t happened.
Convoy M1 or 2 feels bigger and more chunky IMO.
alfas
I completely agree. What does it need so we can make it happen? I can provide the mechanical drawings for machining the replacement metals if I have access to the X5 and X6 3D drawings and 2D tolerances specs.
Rufusbduck
Onc you put an 18650 tube on an X5 head it will be chunky too. A good 16650 would triple the run time of a 14500 and IMHO be more proportional. I know I’d look better 10% thinner. One of my favorite size lights was a 14650 chopped mini mag but run time even at only 2A wasn’t enough for me to be really satisfied with it. The 16XXX size has some untapped potential for edc in both tube and bell head lights.
The M1 is available as a host only. As far as I know MtnE would be the only place to get one with a BLF driver pre installed.
Scott
alfas
Maybe if someone send me the drawings I can make a render and I don’t think it will look chunky. I am curious to see it in fact.
Even if it’s the case the size/performance would be better than any 18650 flashlight around, even than the MH20GT.
18650 batteries would be an advantage for those who have lots of 30Q and Efest laying around. No need to spend on extra cells.
The problem asking mtn electronics would be the price of a special made flashlight, but it’s an option if nothing else works out.
X5 and X6 are all set to go. It would need only redesign the bottom of the X5 reflector holder / head to accept 18650 tube thread. 10 minutes in CAD and it’s done.
Rufusbduck
There aren’t a whole lot of choices for fet driven flashlights. By all means, go for it. I’m just pointing out that the OD’s of the M1 and X5 are very similar so if you think the M1 is chunky then putting an 18650 tube on an X5 will be similarly chunky. The main differences are straight vs curved taper and the flutes of the M1 head.
Scott
alfas
So, I got curious on what would be the result and worked a little on photoshop. All the images below and photoshop compositions and with all scales and sizes respected, according to the images referenced. Just a quick study of the final outcome, not a technical render - might be not 100% accurate but gives a nice idea.
So, I grabed the X5 head, kept the reflector diameter, increased only the thread diameter for the tube and assembled the exact X6 18650 tube (it could also be the A6 18650 tube. I don't know which of these two would fit better and would give the smaller size). The finished product can be seen below:
Comparison between the newborn "X5.5" or "X5-6", X5 and X6:
(reference image used for both above: http://img.banggood.com/thumb/view/oaupload/banggood/images/57/FB/804e1006-92a9-44e3-909b-ada14f938fff.jpg )
Another comparison (now including premium lights also smile):
(reference used for pic above: http://i.imgur.com/fsvupMk.jpg )
Comparison between X6 and A6:
(reference image used for size comparison: http://i666.photobucket.com/albums/vv21/Henk4U2/BLF%20miscellaneous/2Ti_Clips_zpsflxatmbt.jpg )
Comparison between Convoy M1, M2, X6 and A6:
(images used for size reference: http://i132.photobucket.com/albums/q11/300bhpton/Torches/Reviews/Eagle%20Eye%20X6-SE%20BLF%20Special%20Edition/IMG_7879Large.jpg and http://i26.photobucket.com/albums/c135/BimmerR/IMG_3901_zps7a4fb796.jpg )
With the options that we have available today, the M2 looks the best midterm but being the same size of X6 makes me stick with A6 but sitll wanting a little less flood.
At the end of the day, this X5 reflector + X6 body combo shows the best combination by far: basically an A6 (that is already pretty nice flashlight) with a throwier reflector.
It is still much smaller than Convoys. When you talk about hiking, this difference is pretty important to fit you bag or pocket: it gives you the stellar X5 performance with a high capacity cell in a A6 sized EDC.
Looks pretty nice and made me want it even more laughing
Guys, this flashlight is already made - we just need to machine a new head! Let's make it happen!
giorgoskok
giorgoskok's picture
Last seen: 7 min 57 sec ago
Why are you doning this now ????????
I already want one!
meti
Last seen: 1 month 3 days ago
I skipped the X5 because of the low runtime offered by 14500. It was a shame as X6 is one of my favorite light, I use one daily and have another mint in the box :). I’ll buy 3 of these if it will get to production.
tristanxoxo
Last seen: 8 hours 54 min ago
I thought about this also. I’d buy one for sure if it existed.
The Miller
The Miller's picture
Well. these images are very clear.
Hardware used is clear
Communicating this should be relatively easy!
The only question is, who has ownership of the CADfiles of the X5 and X6?
Is it team Kronos? Or is it Banggood? This could happen fast.
Is it Manker? maybe team kronos that must have good relationship with them judging by posts and reviews can make this nice light come to life relatively fast too!
It looks like a worthy light to pursue!
giorgoskok
I think it is Manker .
If they want , they would be able to do this really easy …
Edit : But i don’t think they will work again with us , that’s what they said…
Cousin Elmer
Last seen: 1 hour 21 min ago
alfas wrote:
Rufusbduck wrote:
Try a convoy M1.
This isn’t a budget light, but the driver, warranty and the care and attention given their assembly is worth a lot, IMO. You can PM pflexpro on this forum with any questions. He might have suggestions for other customizations.
http://www.pflexpro.com/PFlexPRO-Convoy-M1-XM-L2-LED-Flashlight-p/pfp-m1...
Chicken Drumstick
I don’t think it would be too chunky. The difference would be, I find the X6 too big to carry in my jeans pocket, it’s just too bulky. So it’s a coat pocket only torch for me. Which sadly limits how much I get to use it.
An 18650 tube light like the A6 is perfect for EDC for me in a jeans pocket, but throw is somewhat limited. The X5 Has the throw but not the runtime.
I reckon an 18650 X5 would be slimmer, smoother and more pocket friendly than a Solarforce L2M, but with more throw and output potential. For me it would probably be the ultimate EDC format.
That said I’m quite a fan of the 16650 format, and wouldn’t object to that as an option. Although would mean machining of a new body and alterations to the head. While an 18650 version would only need the head altering as the body tubes already exist, or could be used from another light.
Chicken Drumstick
@alfas
Very cool renderings Smile
As for the Convoy M2. I have one of these, the head is quite chunky. And somehow bigger than that of the X5, so less pocket friendly for EDC as it feels more bulky. This trend is true with the rest of the body tube and tail cap too. It’s really thick metal and just chunky.
The crenalated bezel also makes it longer and sharper for pocket carry too. And my one at least it an OP reflector. So wont throw like the X5 can.
I also have the Convoy M1, it too is a little bulky and lumpy. It has a bigger OP reflector than the M2 and is IMO the nicer light of the two. As despite the bigger reflector, it actually isn’t really any bigger on the outside than the M2.
Stevedog
Stevedog's picture
Last seen: 6 months 1 week ago
I for one would like to see it threaded for the A6 tubes.. 18650 for the larger protected batteries, and the more pocketable 18350.
goshdogit
goshdogit's picture
Last seen: 7 hours 20 min ago
Nice work on the “prototype,” alfas! Wink
I love my X5 and X6, and your X5.5 looks great! I really like the proportions.
I borrowed your work and added the soon-to-be-released 26650-powered Eagle Eye X7 for comparison.
I used the image here that shows the X6 and X7 together, so the scale should be close.
I think these two look great together! Big Smile
cabfrank
Last seen: 13 hours 32 min ago
It looks great. You know I’d be in.
mapache
mapache's picture
Last seen: 8 hours 30 min ago
I don’t have an X6 or X5, but like the idea of an X5 head on an 18650 tube light body.
I might have my history wrong, but didn’t Eagle Eye come out with the X6 design first? From memory they were quite disappointed when they lost out to Manker, and still wanted to work with BLF. Why don’t we ask EE to scale the X6 head down and put it on the X2 tube?
techieman33
Last seen: 1 week 3 days ago
I would buy one, I really like the x5 would love it to have the extra battery life an 18650 would give it.
will34
will34's picture
Last seen: 1 hour 48 min ago
+1
I don’t see why are we still supporting counterfeit… The only reason we ditched EE was because they couldn’t deliver a driver with enough amps, but still… The quality was better than the X6 made by Manker.
WojtekimbieR
Last seen: 1 week 1 day ago
This thread's getting exciting
Just for a moment... Okay I may stay a little longer
meti
+1
I won’t buy anything Manker after the A6, so disappointing quality speaking. EE X6, on the other hand, was really well made, so I hope for a X6.5 or X5.6 or whatever it will be called built by EE.
mapache
mapache's picture
will34 wrote:
+1
I could never follow along, who owns the rights to the BLF drivers? I was under the impression that it was either the members who designed it or BLF as a whole, but not Manker. Even if the original designers don’t want EE to use either of the BLF drivers there should be enough talent around here to come up with something.
If it was built around the X2 body perhaps X2.6 or X2.5 would be a good name to prevent too much association with the Kronos X5.
pilotdog68
pilotdog68's picture
Last seen: 3 weeks 4 days ago
Eagle Eye is right up there with Convoy for my favorite manufacturers. Manker seems to do a decent job on stuff they design (with a couple exceptions) but can’t execute well when we stipulate the design. I think future “Kronos” groupbuys may be done directly with Neal/Banggood/Astrolux.
I would suggest contacting the owner of Eagle Eye through his Aliexpress store regarding this matter. I get the feeling he is a small operation like Simon is, but if you can get these images to him maybe he’d be on board.
My dream would be this form factor (X5 head, 18650 tube) plus the charger from the X2R, but that would hurt the aesthetics a bit.
I think it was less “disappointed” and more “furious.” There’s a reason why you can’t buy any EagleEye products on Banggood anymore. I don’t know how much EE blames BLF for that debacle, or if those wounds have healed.
kiriba-ru
kiriba-ru's picture
Last seen: 1 hour 41 min ago
Brilliant idea, Eagle eye X2 (convoy-compatible tube – 18350 tubes will also fit) with mid-size head with X5 size reflector.
Upd. No, X2R charger is bad idea, it lools awfull. Just indicator led.
Meanwhile in Russia: https://twitter.com/CrazyinRussia
vulpes
vulpes's picture
Last seen: 12 hours 50 min ago
Throw in side switch from EE X5 for some Narsil love.
Chicken Drumstick
+1
What was wrong with the quality on the Kronos X6? I have both the Alu ones and the Cu/SS set.
ZozzV6
ZozzV6's picture
Last seen: 1 hour 59 min ago
I already thinking about the M1 or M2 but I found them too long and thick. The x5 head on a 18650 tube is great idea! If it happens I definietly buy one with BLF driver and an XPL-HI
