[Released] Manker MC13 and Manker E14 III
96 posts / 0 new
Mankerlight
Mankerlight's picture
Last seen: 16 min 36 sec ago
Manker MC13 Ultra-Throw Flashlight - Multi LED Option + Type-C USB Rechargeable 18350 Battery(10A)
Features
- LED Option1: OSRAM KW CULNM1.TG LED (white light)
                         Max. 950 lumens output, Max. 760meters beam distance
- LED Option2: OSRAM KP CSLNM1.F1 LED (green light)
                         Max. 1200 lumens output, Max. 858meters beam distance
- LED Option3: OSRAM KR CSLNM1.23 LED (red light)
                         Max. 260 lumens output, Max. 450meters beam distance
- LED Option4: OSRAM KY CSLNM1.FY LED (Yellow light)
                         Max. 350 lumens output, Max. 506meters beam distance
- LED Option5: OSRAM KB CSLNM1.14 LED (blue light)
                        Max. 115 lumens output, Max. 640meters beam distance
- Powered by 1x 3.7V 1100mAh high drain protected 18350 li-ion battery with Type-C USB port (Included)
- Working Voltage: 2.8-4.3V
- Driver: Most efficiency constant current circuit (Non-PWM)
- With advanced intelligent temperature regulation module,MC13 regulates its output and adapts to the ambient environment,maintaining optimal performance
- Anti-reverse battery protection & overdischarge protection
- Pocket Size, Compact, lightweight
- One-handed, one-button for easy and fast operation
- Lockout mode prevents accidental activation
- Moonlight Mode: Multiple user selectable levels
- Low battery voltage indicated & battery charging indicated
- Material: aircraft-grade aluminum body
                 stainless steel button cap
- Surface Treatment: Premium type-III hard-anodized anti-abrasive finish
- Clip: Stainless steel deep carry clip
- Lens: Toughened ultra-clear glass lens with anti-reflective coating + high temperature resistant optics TIR Lens
- Tail stand capability
- IPX-8 waterproof standard (2 meters under water)
- Impact resistance: 1 meters
- Size: 90.75mm(3.57") length x 41.7mm(1.64") head dia. x 25.8mm(1.01") body dia.
- Weight: 108.6g(3.83 oz) w/o battery, 136.7g(4.82 oz) w/ battery
- Accessory: 18350 li-ion battery x1, type-C USB charging cable x1, lanyard x1, spare o-ring x1, Manual x1
More info, welcome to http://www.mankerlight.com/manker-mc13-ultra-throw-flashlight-multi-led-option-type-c-usb-rechargeable-18350-battery-10a/
Manker E14 III 4000 Lumens Mini EDC Pocket LED Flashlight + Type-C USB Rechargeable 18350 Battery(10A)
Features
- Emitter: 4x Samsung LH351D (Cool White: 6500K, Neutral White: 4000K CRI>90)
- Maximum output: 4,000 lumens
- Maximum beam intensity: 6,000cd
- Maximum beam distance: 155meters
- With advanced intelligent temperature regulation module, E14 III regulates its output and adapts to the ambient environment, maintaining optimal performance
                 copper heat sink
- Lens: Toughened ultra-clear glass lens with anti-reflective coating + high temperature resistant Carclo® optics TIR lens
- Install one removable silica gel light filter plastic sheet (green glow gadget)
- Size: 71.2mm(2.8") length x 28mm(1.1") head dia. x 25.8mm(1.01") body dia.
- Weight: 82.8g(2.92oz) w/o battery,109g(3.84oz) w/ battery
- Accessory: 18350 li-ion battery x1, type-C USB charging cable x1,spare o-ring x1, lanyard x1, Manual x1
More info, welcome to http://www.mankerlight.com/manker-e14-iii-4000-lumens-mini-edc-pocket-led-flashlight-type-c-usb-rechargeable-18350-battery-10a/
Manker MK34 Flood Flashlight 12 Emitters 8000 Lumens Runs of 3 18650 Batteries
Key Features:
12 Emitters (3 quad MCPCBs)
Max output 8000lumens with Cree XP-G3 emitter,6500 luemns with Nichia 219B emitter
Working voltage: 2.8V-4.35V (Over discharge protection)
Reverse polarity protection and battery indicatorMost efficiency constant current circuit driver
Specifications:
1.Emitter: 12 Cree XP-G3 / 12 Nichia 219B/ 12 Nichia 219C (3 version for your choice)
2.Maximum output:
  Cree XP-G3 8000 lumens
   Nichia 219B 6500 Lumens
3.Maximum beam intensity:
   Cree XP-G3 20000CD, maximum beam distance 280 meters.
4.Working voltage: 2.8V-4.35V (Over discharge protection)
5.Driver: Most efficiency constant current circuit
6.Material: Aircraft-grade aluminum body
7.Surface treatment: Premium Type III hard-anodized anti-abrasive finish
8.Lens: Toughened ultra-clear glass lens with anti-reflective coating
9.Water proof: IPX-8(2meter under water)Impact resistance: 1.5 meters1
10Tail stand
Dimensions:
Length 98mm, Diameter 55mm
Weight 278g (Without battery)
Accessories: O-ring *1,  Lanyard*1, User manual*1
Output and runtime:
Moonlight: 0.1-30lumens /2months-5days, Low: 120lumes 30hours
Medium 1: 500lumens 7.5hours , Medium 2: 1000lumens 3.5hours
High: 2500lumens 2hours , Turbo: 8000lumens,  Strobe: 8000lumens
Batteries:Runs of 3 18650 batteries
                 MK34 must use  high drain unprotected 18650 batteries.
(The package does not include any battery)
Side switch battery indicator:
1.Blue: More than 75%  2. Purple: 50% 3. Red: Less than 20%
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
Engineering Mode(Choose output level for Moonlight mode):
Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to engineering mode.
One click to check different level and long press to make your final choice.
For more information please visit Manker website: http://www.mankerlight.com/manker-mk34-flashlight-12x-led-3x-18650/
Mail:sales@mankerlight.com
Web: www.mankerlight.com
Welcome to join Mankerlight Group in Facebook.
Edited by: Mankerlight on 07/28/2020 - 22:13
Nicolicous
Nicolicous's picture
Last seen: 49 min 55 sec ago
Any discount for BLF members?
Nico -.-
keengeorge
Last seen: 1 year 1 month ago
+1 smile
freeme
freeme's picture
Last seen: 2 hours 50 min ago
Thumbs up!
koyotee
koyotee's picture
Last seen: 2 weeks 20 hours ago
Lol, nice try at the noctigon copy
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
nofearek9
nofearek9's picture
Last seen: 7 hours 50 min ago
in for the giveaway Smile
The Miller
The Miller's picture
Last seen: 8 months 1 week ago
Nice
Are you going to do a raffle for one or two with the money it generates donated to the Old Lumens pinkpanda action, Manker?
Mankerlight
The Miller wrote:
Nice Are you going to do a raffle for one or two with the money it generates donated to the Old Lumens pinkpanda action, Manker?
we will  take 50 pcs BLF X5 and donated the sale amount to Old-lumens, Hope this will help Justi.
The Miller
Wow that is awesome!
Thanks!
The Miller
Oh in really like this light and can’t wait to read reviews.
How foes it cope with heat?
Any cell recommendations or no-gos?
Impressive how much you were able to cramp in such a short light!
Easyrr
2500 lumens on high and 8000 on turbo? That’s a kinda huge turbo hole Big Smile
Feels like a first generation 911 Turbo Big Smile
Threadneedle
Threadneedle's picture
Last seen: 2 days 12 hours ago
Absolutely beautiful. I was thinking about buying a meteor but this badboy will take precedence. Sign me up for one.
There’s no runtime for Turbo, though I expect it wouldn’t be too long. What’s the turbo runtime and how long until stepdown kicks in?
Chicken Drumstick
Interesting. I’m sure a group buy would generate lots of sales Manker. Would you be interested?
jack-bkk
why dont you use nichia 219c ???
Threadneedle
I’d groupbuy the hell out of this torch.
stephenk
stephenk's picture
Last seen: 1 week 4 days ago
I’m also interested to know how well this handles heat!
The tripod mount is a good feature.
keengeorge
G'Day Manker, smile
Could you Please tell us what tint & color temperature are the 12 Cree XP-G3 & the 12 Nichia 219B LEDs?
Thank you Very Much,
George
Hunter
Since no one applied for a review let me be the first, just send one and I will do everything else Innocent
Henk4U2
Henk4U2's picture
Last seen: 47 min 45 sec ago
My Astrolux S41 (equals Manker E14) does 7.6A on an IMR18350 and over 11A on a 30Q.
Imagine holding three of those lights in your hands. That’s more heat than three 40 Watt lightbulbs generate!
But it is sure an epic looking light!
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
jack-bkk
The build in anti rolling feature is really thinking out of the circle or box ….
MG
Last seen: 3 weeks 6 days ago
Looking forward to seeing a full review!
blueb8llz
Last seen: 11 hours 35 min ago
holding the switch to turn the light off was the deal breaker for me…nice looking design though, i really like the fact that its smaller in size because its 3×18650 instead of the typical 4x.
Nicolicous
looks like all the questions are ignored.
oh well time to move on with other light spending
Nico -.-
getbully
Last seen: 2 years 10 months ago
I want one! Cash
Tac Gunner
Tac Gunner's picture
Last seen: 9 months 2 weeks ago
I like the looks of it.
myst999
Last seen: 16 hours 40 min ago
Exactly ! If a vendor doesn’t answer simple questions before a light is released – then what kind of service can you expect after purchasing it?!!
Edit – (Manker was online 25 minutes ago as of the time of this writing so they have been online)
MG
I see these are on the big auction site already.
CRX
CRX's picture
Last seen: 4 hours 6 min ago
Love the body, but the personality isn’t so good.
msim
Last seen: 2 years 11 months ago
Agreed. Would rather have short click to turn on and off and long press to change modes like Olight’s current UI.
Mankerlight
keengeorge wrote:
+1 smile
Manker supply product with reasonable price Smile
Mankerlight
stephenk wrote:
I'm also interested to know how well this handles heat! The tripod mount is a good feature.
Please wait for MK34 review from Jonny Mac.
