[Official] Astrolux S41S Quad Nichia 219B/ CREE XP-G3 1600LM Group Buy
1201 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 1 month 1 day ago
Strange that they don’t have the black one with a copper ‘engine’.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
RollerBoySE
RollerBoySE's picture
Last seen: 5 days 9 hours ago
Indeed!
At least they should offer it as an option (for a few dollars more?).
Maybe they are willing to offer it as a special for BLF?
They already have the cost/trouble of sourcing two different heads.
Maybe they should offer a mix and match / build your own version?
Lazy-R-us
Last seen: 21 hours 10 min ago
Is it just me or does the Colored version look like the lens ring is cross threaded and crooked? Leaning to the right maybe?
Lazy-R-us
RollerBoySE
Sure looks like it’s not too well made…
LightRider
LightRider's picture
Last seen: 13 hours 28 min ago
I’m guessing it’s a poor photoshop job. The S41s has a crooked head/body as well. Smile
desmondkun
desmondkun's picture
Last seen: 1 hour 8 min ago
I’m not lucky with s41s. Ordered 2 times, got problems both times.
First time, ordered S41a head. Arrived 4 days ago. Led’s dome damaged eventhough I haven’t unscrew it’s head(may accidentally unscrew the bezel when I unscrew the head but I’ts just 1/4 turn at most). I can noticed it only in moonlight mode. 4 leds still work fine. This may reduce it’s efficient a little but still work fine in real life. I contacted banggood for compensation and still waiting for result.
From the picture, it’s in moonlight mode.
Second order, I ordered SS body tube and SS tail cap(they’re out of stock when I order the head). Got them today. Tail cap is fine but body tube has strange color. Don’t know why, may be because they forgetting something or do coating before machining or whatever. I ordered it because of it’s looks, though. I contacted them and waiting for reply.
Sorry for low quality pics. My cheap cellphone’s camera just died and these pics were taken by a cheaper one. lol
Take care of your flashlight and your flashlight will take care of you.
freeme
freeme's picture
Last seen: 1 hour 12 min ago
TIR can be easily replaced. PM me if you need help for your order.
desmondkun wrote:
I'm not lucky with s41s. Ordered 2 times, got problems both times. First time, ordered S41a head. Arrived 4 days ago. Led's dome damaged eventhough I haven't unscrew it's head(may accidentally unscrew the bezel when I unscrew the head but I'ts just 1/4 turn at most). I can noticed it only in moonlight mode. 4 leds still work fine. This may reduce it's efficient a little but still work fine in real life. I contacted banggood for compensation and still waiting for result.    !http://upic.me/i/o3/15-06-2017-105704.jpg! From the picture, it's in moonlight mode.   Second order, I ordered SS body tube and SS tail cap(they're out of stock when I order the head). Got them today. Tail cap is fine but body tube has strange color. Don't know why, may be because they forgetting something or do coating before machining or whatever. I ordered it because of it's looks, though. I contacted them and waiting for reply. !http://upic.me/i/8t/17-06-2017-1648192.jpg! !http://upic.me/i/z3/17-06-2017-1640152.jpg! !http://upic.me/i/z3/17-06-2017-1651212.jpg!   Sorry for low quality pics. My cheap cellphone's camera just died and these pics were taken by a cheaper one. lol
desmondkun
Thanks. I contacted banggood and they gave me a refund. It’s not worth much but better than nothing. w
Steven
Last seen: 9 months 2 weeks ago
Apologies if this is not the right thread for this, but I have a question about how to configure the S41S.
Just got a S41S from banggood and I can’t seem to change the mode grouping or toggle memory mode. I turn it on, click 15 times, wait for the 2 blinks then turn it off after the two blinks to toggle that specific option. Is that the correct procedure to set the configuration? Is there some trick to it? I’ve tried this 4 or 5 times now and can’t change the mode grouping or toggle memory mode. Light seem stuck in group 1 with memory mode off.
Edit: Looks like it was my error. I needed to turn off between the two blinks not after than.
beam0
beam0's picture
Last seen: 6 hours 33 min ago
Does the S41 have Bistro or A6 UI?
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
freeme
freeme's picture
A6 firmware for S41/ S41S, according to their product descriptions.
g_sintornillos
g_sintornillos's picture
Last seen: 9 hours 3 min ago
+1
I have the S41s and I can confirm that it has A6 firmware
Sorry for my bad English (gogole transtorla)
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 58 min ago
I’ve occasionally heard that the later batches of S41 may have had bistro, but I’m not sure. Originally it was going to use bistro, but the drivers were too sensitive to voltage spikes and couldn’t handle the amps of a multi-emitter light. So they used the older blf-a6 drivers instead, which are more tolerant.
The voltage-spike thing has been fixed in later BLF drivers, but last I heard, it was still a problem on banggood’s bistro drivers.
rizky_p
rizky_p's picture
Last seen: 1 hour 21 min ago
I can confirm that my S41 which i received a week or two weeks ago and it uses the same firmware as the BLF A6 firmware.
beam0
beam0's picture
Thought I read this somewhere too, but wasn’t sure if I had it confused with another light.
Thanks! I was wondering why it would have A6 since this came out after the X6 II, but that explains it.
RollerBoySE
Ordered one of these:
https://www.banggood.com/12_8×3_2cm-Astrolux-Flashlight-Protected-Bag-H...
It was delivered today, but the embroidered name is not Astrolux, it’s MATEMINCO.
Makes it kinda obvious who is producing Astrolux for BangGood.
g_sintornillos
RollerBoySE wrote:
, but the embroidered name is not Astrolux, it’s MATEMINCO. Makes it kinda obvious whos is producing Astrolux for BangGood.
And MATEMINCO still is…
#1132 of this thread
fedcas
fedcas's picture
Last seen: 2 hours 10 min ago
Hello toykeeper, thanks for pointing that out Wink do you know what kind of problems do that caused? I mean, is it some obvious malfunction or is it more about working regularly for a while and then risking to fail later?
ToyKeeper
ToyKeeper's picture
What happens is that the driver reboots. When the FET opens it lets current through, then when it closes it causes kind of a shockwave strong enough to reboot the MCU. So, in the strobe mode, for example, it’ll flash once or twice and then go directly to moon. Or it can go from turbo to moon, or one of the higher FET modes to moon, on its own.
Basically, if it runs at full power it reboots itself and goes to moon.
The attiny13a is tolerant enough to keep running regardless, even when it’s getting far more voltage than it’s spec’d for. But the attiny25v doesn’t respond well to these voltage spikes, and it reboots.
Newer driver designs eliminated the voltage spikes, but I don’t think banggood has any of those newer designs.
CoolJB
Last seen: 3 days 4 hours ago
I got one of those too. Ordered 2 of the holsters, one had astrolux, the other has mateminco on it.
fedcas
fedcas's picture
I see, that’s good to know, thanks a lot for the explanation and for your awesome work! Wink
Sirius9
Sirius9's picture
Last seen: 3 weeks 3 days ago
Any chance we could get new deal for Astrolux S41S SS ?
g_sintornillos
This is the one I know: https://www.banggood.com/collection-2072.html
Sirius9
Sirius9's picture
Thanks g_sintornillos ,
anything I should be aware before ordering? I see that many people were not satisfied with QC, mostly damaged emitters, leds with different tint etc!
I wanted to go for Nichia version.
g_sintornillos
First batch was for oblivion, high failure rate and DOA, then improved
I do not know what’s happening with the current batch, Astrolux is not characterized by having a minimum quality control, it can be a lottery
Mine, from second or third batch, bought at the end of 2016, works fine from out the box
saypat
saypat's picture
Last seen: 3 hours 34 min ago
check out post #366
http://budgetlightforum.com/node/54067?page=12
Sirius9
Sirius9's picture
Thanks, I wanted one for a long time but all this hiccups turned me off, hope they improved the light, wouldn’t like to get faulty nichia led, don’t have those at hand.
freeme
freeme's picture
Astrolux S41S SS - from $32.26 ($64.95)/ Coupon: 8A955D
Nichia 219B / CREE XP-G3 / CREE XP-G2
Lexel
Lexel's picture
Last seen: 11 hours 10 min ago
S41 22.99$ in the app
also colored aluminum 18650 tubes availiable now
wellerus
Last seen: 11 hours 14 sec ago
Which is the lowest price for black S41, i only get 24 usd on BG with a discount code FLSTNE and in android app a price is the same not lower.
https://www.banggood.com/Astrolux-S41-4x-Nichia-219B-XP-G2-A6-1600Lumens...
And which high drain 18350 batteries from aliexpress would be the best for turbo mode, those from litokala probably will not stand the drain https://www.aliexpress.com/item/2PCS-ICR-18350-lithium-battery-900mAh-re...
