Thrunite TN 42 ,a new record in Throw
472 posts / 0 new
lawallac
lawallac's picture
Last seen: 1 day 9 hours ago
Received my TN42 yesterday. My first impressions are as follows:
1. It’s a larger light but not nearly as big as I thought it could be. It’s not as heavy as you might think either. I think having a huge empty volume in that reflector is part of that. But it feels to be a solid well built light. That big reflector is stunning.
2. Batterywise, I installed some button top unprotected LG 3000 HG2s and they well. The springs look long enough to fit some shorter batteries but plenty of space for protected cells too. I’ll prob be putting some protected 3400s in there later.
3. The UI is really nice actually. From off, click and hold for moonlight. It is really useful if you are out in the snow since the other modes are so blindingly bright. The double click from anywhere to get turbo is really appreciated. Once on, holding the button cycles through the modes other than turbo or moonlight. But turbo mode is the only real reason to buy this light.
4. The TN42 projects a very sharply defined hotspot and a medium range and much dimmer area of spill. The farthest treeline behind my house measures at 950 feet or 317yds and casts a really nice bright hotspot even at that distance.
5. CW or NW? This light is the NW variety and really pleased with the tint. I haven’t used the CW version, and it sounds good too, but no reservations here with the throw of the NW. I personally find that NW tints appear brighter than CW tints even when the NW is in a slightly lower flux bin. It’s a little off topic, but I think it has to do with CW lights have a more visible beam to the eyes but NW returns more useable reflected light to the eye. But lighter colored things will show up better in CW and dark green or red objects will show up brighter with NW. I’m convinced lux meters are more sensive to CW to blue light than NW to red. But, lux meters are the way we quantify brightness so best to get both lights to be sure.
Really a nice light!
Easyrr
Last seen: 6 days 4 hours ago
Dale, if there was a like I would instantly push that button at your pic. Brilliant!
Mitko
Mitko's picture
Last seen: 4 months 1 week ago
I dunno how you guys got those 700k , i bought one when it was released( SN 007), the second one arrived before a week or so( SN 066) so i presume they aint that popular Smile
Both cool white, both topped at about 640k( at 5m), increasing the measuring distance lowers the intensity
With the same meter i got 160k from m2x and 245-250k from M3X, 120k from TM16 and 110k from Fenix TK75 so i count it as accurate as a swiss watch
Both are about 2k lumens
Its not that 50k are that important yet…
That torch is crying out loud for XPL at 6.5 amps …the beam is quite narrow anyway
ttrevs1
Last seen: 1 year 3 months ago
How does the TN42 compare to the Firefox4 ?
which 1 throws further? Brighter?
cheers
tatasal
Last seen: 37 min 29 sec ago
cheers
One member here before tested his FF4 and got about 435kcd I think..at more than 6,000 lumens on a much wider hotspot, with glorious tint.
I used to have an FF4 before and though I don’t have a TN42, they are practically two different lights.
ttrevs1
cheers
Thanks for the reply, I have a FF4 but I need more lights for cyclone chasing, I was thinking bout this TN42 or the Bronte BT41
I was hoping LED technology has advanced enough to at least equal or better the FF4.
cheers
Theodore41
Last seen: 7 hours 45 min ago
DB Custom wrote:
Very strange indeed. My light is marked exactly the same… but in a different place!
At Taschenlampen their light is marked on the ramped portion of the head, between the bezel and the housing or pill section. My lamp is marked on the bezel.
And here is my light, with the same technical text but placed differently… (mine has the ROHS designations, a production light, while the sample pass-around light does not)
I’ve got it today.#283.
Theodore41
Having now the TN42,I like more my K70,so I decided not to sell it.I like the “richness” of its beam,which gives a sense of more light.I like the changing mode ring,because I put it to strobe permanently and pressing the button once,I have rich strobe light,if there is need for self defense.
richbuff
Last seen: 50 min 15 sec ago
I have been thinking about getting the TN42. Does it throw a lot more than the K70, or a little bit more throw, or how much more throw?
Yes, it also has normal modes for normal runtime and normal heat generation.  Phil 1: 21-24 and 2Tim. 4: 6-8.
Theodore41
I put the light on the…bench against a luxmeter at 4,7m,I used 4 Samsung 30Q batteries fully charged in a LiitoKala 500 charger, and the result is veeery good. 722,000Cd. Big Smile
I am impressed.
I used 4 Samsung 30Q batteries fully charged in a LiitoKala 500 charger.
I have to change my opinion about this light compared to a K70,because,if there is a very far target,the TN42’s beam cuts the darkness like a sword,reminding me my blue laser pointer of 1.6W.
teacher
teacher's picture
Last seen: 8 months 19 min ago
I am impressed.
Nice Theodore!!!! Thumbs Up
I thought you would be pleased…. Wink
Theodore41
teacher wrote:
I am impressed.
Yes,I am ,it shines. Big Smile
teacher
teacher's picture
Oh yeah…. that it does. Thumbs UpWink
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 5 min ago
Theodore41 wrote:
teacher wrote:
I am impressed.
So the K70 go’s back into the BOX now right? Big Smile
KB1428 “Live Life WOT
Theodore41
I have all my lights,except the TN42,(which is on a table),in two drawers,which are now full of them.I will put on the same table, the new guy,(a TN40S),which is arriving in about a week.
Santa, was generous to me this year . Big Smile
DB Custom
DB Custom's picture
Last seen: 1 day 13 hours ago
I saw a quote recently that struck home… “I’ve almost got all my Christmas shopping done, now I just have to buy everyone one else’s.”
teacher
teacher's picture
You might want to check HERE also. Thumbs Up
pinkpanda3310
pinkpanda3310's picture
Last seen: 14 hours 47 min ago
So has anyone attempted to mod this thing with a different led yet??
DB Custom
DB Custom's picture
Loving mine, not gonna mess with it. Big Smile
tim70
tim70's picture
Last seen: 11 months 2 weeks ago
Received my TN42 couple days ago, on my test I got ( 717,500kcd 1,694M at 5M ) with 30Q button top and ( 682,830kcd ) 1,652M at 9M with 30Q button top.
lawallac
lawallac's picture
NW TN42 in med fog. This show the beam pretty well but it’s hard to see how far it really goes.
teacher
teacher's picture
That is a nice video ‘lawallac’!!! Thank you or sharing it…….. Thumbs Up
I did that the other night (no video) but since I was holding the light I did not get as good a view as I can see on your video.
This thing looks like a mile long light saber doesn’t it??? I love playing with my TN42… Wink
lawallac
lawallac's picture
There really is quite a bit of spill in the beam that it seems kind of unnatural the amount of intensity that it still develops in the central part of the beam. Really unique for an unmodified light to have this much throw. I’d say it’s a keeper.
DB Custom
DB Custom's picture
So now we have the aptly christened TN42 KPR. Wink
teacher
teacher's picture
I’d say so. Smile
Mine is a “KPR” for sure. Wink
nodoubt
DB Custom wrote:
And for the question about bumping output. The XHP-35 is a 12V emitter that is listed as having a max current of 2A. I have built one that is working at 3.13A but I know it’s got to be on the very edge of going POOF! Several other’s I know have had them fry at high 2.8-2.9A range. Mine at 3.13A is making 2989 lumens, this TN42 is making 2463 lumens. So while there might be some small gains to be found, it would mostly be invisible to the naked eye. And since I don’t really relish messing up a proprietary driver on a new $200 light, I’m not playing around with it. 2463 lumens for 702.5Kcd and one mile throw suits me just FINE! Smile
thats a stock tn42 putting out close to 500 more lumens, and 100kcd , over the quoted factory specs?
is it nw, or cw ?
how do you test your big throwers?
5 meters? 10 meters?
what kind of lux meter do you use?
thanks for the help
Enderman
Enderman's picture
Last seen: 11 min 22 sec ago
is it nw, or cw ?
thanks for the help
Texas Ace tested the XHP35 to do about 2500lm max in his calibrated integration sphere, I highly doubt 3k lumens is correct.
DB Custom
DB Custom's picture
My TN42 is Cool White. I test in a PVC “P” Trap lightbox that’s been calibrated by 25 known factory ANSI rated lights initially, then continuously checked over a hundred plus lights since. I also went to the extreme of setting up a true one mile test and got pictures of an 8 1/2 × 11 sheet of paper with text legible by the light from the TN42 one mile away. Beyond the numbers, an actual one mile test proved it out. I think my meter is a 1330B, will double check it when I get back to it. I normally test at 5M, where I have control distance.
nodoubt
ok thanks for that sir
saw your 1 mile test, that was great! tx for doing that
reason im asking, i have a few vn modded lights, a tk61vn, and a newly acquired tn40svn, that are putting out about 120k lux less than the quoted spec
ive checked them on 4 different lux meters, and the only that came close was the dr meter one, it showed about 460k for the tn40svn
others include, my dmm cen-tech, that has lux meter built in, a supposed good quality extech, lt300, that i just got tody , and a cheaper one that got good reviews, and a Holdpeak 881C…
the tn40svn is supposed to put out 500k lux, but i can only get around 390k or so, same for the tk61
he also measured a stock tk42 at 700k lux, just like you did is the reason im asking
about to drive me nutts trying to figure out the true numbers !
ive shot the lights with fresh batteries at any where from 2 meters, all the way up to 10 meters….
tx…..
DB Custom
DB Custom's picture
Sometimes the numbers are hard to chase, if the lights put lumens downrange so you can see, then it’s doing what you bought it for. Getting all the numbers to line up can be frustrating. I use em more for comparative purposes than as a solid indication of what the light can do. Testing it at an actual mile was me not believing the numbers. lol
My meter is the Dr. Meter, LX1330B
