Groupbuy feeler: Klarus XT11GT
Update
Code available!
please send a mail to m4dm4x@aon.at to make answering less painful...
include your nickname ;)
Hey!
another great light is on the way:
the KLARUS XT11GT
Features
• 4th Generation KLARUS Tactical Flashlight. Compact design; superb functionality; industry leading patented features
• Newest CREE XHP35 HI D4 LED, 2000 Lumen Max Turbo output,; beam reaches over 402 meters; industry leading performance
• Compatible with CR123A and protected 18650 Li-ion batteries, one 3600 mAh high-quality 18650 battery included
• Patented Triple-Switch control design, Easy to use; accommodates any user patterns
• Easy Interface: One-Touch Strobe; One-Touch Turbo; One-Touch Low; Mode memory; SOS;
Lock-out function; Capacity indicator, USB charging; ITS temperature control; Quick mode change
• Compact and light (Bezel 34.9mm(1.37") (D), Body 25.4mm(1")(D), Length 142.6mm(5.59")), Weight 130g, (4.58oz) w/o battery
• Patented Dual Tactical Tail Switch Control; One-hand tactile control; the next evolution in flashlight control UI
• Three Interfaces: Tactical Setting; Outdoor Setting; Advanced Tactical Setting
◇Tactical Setting: Classic KLARUS XT series control. One-Touch Turbo; One-Touch Strobe; Side switch full control; versatile in all tasks
◇Outdoor Setting: Specially designed for the wilderness. One-Touch Low; One-Touch Turbo;
Multiple levels with memory; SOS function; suitable for all needs in Hiking, Camping or Search and Rescue
◇Advanced Tactical Setting: Turbo + Strobe; Side switch disabled. Immediate access to Turbo or Strobe for extreme tactical needs.
• Common Micro USB recharging port protects again moisture, dust, and sand
• 1A recharging current; quickly back in action
• Intelligent Digital Charging module; monitors charging progress for safe and fast recharging with over-charging protection
• ITS temperature control, real time monitor and auto-adjust output levels to keep LED and crucial component safe for the best balance of performance and equipment safety
• Special Lock-out mode. Prevents accidental activation to prolong battery use and avoids damages to eyes
• Capacity Indicator alerts on remaining battery capacity any time
• Springs at bezel and tail resist shock and drop damages
• Reverse Polarity Protection; eliminates damage from incorrect battery install
• Aero-space Aluminum alloy body with CNC technology; Military spec hard anodizing (HA III); lightweight and robust
• Stainless bezel ring offers protection for crucial components
• Monolith bezel design for efficient heat dissipation
• Hardened Mineral Glass lens with AR coating; scratch resistant
Specifications
• Utilizes CREE XPH35 HI D4 LED with a lifespan of up to 50,000 hours
• Classic Tactical Setting as factory default
Notice: Only when using KLARUS 18GT-36 3600mAh battery or the same batteries of the other brand, the Max output could be up to 2000LM; When using the normal 18650 battery with PCB protection or 2 x CR123A batteries, the Max output could be only up to 1300LM
• Working voltage: 2.5V-8.4V
• Compatible Batteries: 1x 18650 battery with PCB protection or 2 x CR123A batteries
• Charging time: Depends on the battery capacity
Formula: charging time= (capacity of battery/1000mA+1H)
• Body colour: Black
• Reflector: Smooth reflector
• Switch type: Dual Tactical Tail Switch and Side Switch
• Dimension: (Head)34.9mm(1.37")×(Body)25.4mm(1")×(Length)142.6mm(5.59")
• Net weight: 130 g(4.58oz) (Excluding battery)
• Material: Aircraft-grade aluminum 6061-T6, Type III hard-anodized
• Waterproof: IPX-8 (underwater 2 metres)
• Lens: Toughened ultra-clear glass with anti-corrosion AR coating
enter the List if you want one for a nice price (to be negotiated...)
  1. Liber8
  2. archimedes
  3. Eivwer
  4. Wrathbringer27
  5. ReacherShoots
  6. will34
  7. xed888
  8. ilovejesuschrist
  9. fed893
  10. alejandrov
  11. allcool
  12. tzmxxhh
  13. syracuse
  14. akhyar
  15. Norddeutscher
  16. Corzy
  17. saypat
  18. olivedrab
  19. KCmastertech
  20. Mstevens113
  21. Charga
  22. ID4
  23. Gerrh
  24. khas
  25. dekozn
  26. Nicolicous
  27. charles lin
  28. casi29061965
  29. yellowknifenut
  30. uqs1000
  31. texas shooter
  32. D10ten
  33. ikaruz_500
  34. ikaruz_500
  35. vyvyra
  36. LG
  37. Yasin1981
  38. bluelion95
  39. Bruno28
  40. Anthon
  41. Nostromo
  42. indenial
  43. wurczack
  44. Aladin
  45. BazzH
  46. aL1
  47. alfas
  48. Aussi
  49. RobertB
  50. KawiBoy1428
  51. alexfra
  52. Lars (m@il)
  53. dariot
  54. Tete
  55. Gammel
  56. haro
  57. Mr.Beam
  58. e0mc2
  59. malamask
  60. allcool
  61. ollywood
  62. ale9g
  63. djburkes
  64. AirBreaker
  65. winz
  66. winz
  67. Maiden666
  68. Lars W. FB
  69. hanyon
  70. Zambo84
  71. AdAm0
  72. terjee
  73. goldtyson
  74. freddyt
  75. eifelmar
  76. odyssey
  77. eric800
  78. papaslightsaber
  79. stanley-beamish
  80. rastaman
  81. gorky
  82. kokete
  83. Paule
  84. rastaman
  85. Angel Martínez
  86. Cano
  87. Box
  88. XJojoX
  89. luisgcan
2000 lumens on a single 18650 :open_mouth:
Definitely interested for the right price. Wondering what other batteries could guarantee the 2000 lumens. Also wondering if they mean lumens or klumens.
Sign me up, please!
Interested in 1, thanks!
Interested! But needs to know price… :confused:
Awesome light, interested, but looks very expensive.
I’m in… Constant 2,000lm… for how long?
sign me up please, martin
Interested in 1, Thanks!
add +1 for me
I want to know the price.
Add me for one, diferent XT11S and XT11GT?
Woww led XHP-35, only diference?
I don’t think it could last for 10 minutes!
Interested, depending on price.
Looks like an amazing light but 2000 constant lumens? To me that means it maintains a constant 2000 lumens until the battery is discharged. Heat alone I don’t know how they could do it.
wa! I am interested!
I’m interested.
Interested, but need to know the price first
