Ultrafire CREE XM-L2 U2 900LM EDC flashlight
3 posts / 0 new
WestBam
WestBam's picture
Last seen: 3 days 7 hours ago
A recent UltraFire flashlight would like to present.
This model is the GearBest shop can be purchased, others have not seen. (external reflink)
Specifications:
  • Brand: UltraFire
  • LED: Cree XM-L2 U2
  • Lumens Range: 500-1000Lumens
  • Luminous Flux: 900LM
  • Color Temperature: 6500-7500K
  • Switch Type: Clicky Switch
  • Feature: Anti-Roll Rugged Design,Lanyard
  • Function: Camping, EDC, Hiking, Household Use, Night Riding, Walking
  • Battery Type: 18650 Battery
  • Quantity: 1 x 18650 battery (not included)
  • Mode: 5 (High-Middle-Low-Strobe-SOS)
  • Waterproof Standard: IPX-6 Standard Waterproof
The head of a simple aluminum tube, the end of a normal glass plate insulated seal.
Copper pill is threadedly engaged with the body. Cooling is pretty good in terms of construction. One piece is machined to the body, the wall thickness of surprisingly high. This flashlight is bulletproof. Front and rear rubber ring ensures water resistance.
The tail cap includes a reverse clicky switch over to the (zombie) green GITD rubber seal.
Light slightly bluish.
The driver comprises in this model has mode memory. One group, so all five modes are available continuously.
Measurement results:
  • High: 1,66A
  • Medium: 0,81A
  • Low: 0,40A
Weight without battery: 131g
Body lenght: 133mm
Maximum diameter: 33mm
Use uncoated glass plate on the head.
The lamp heats up during use, so probably a good heat conductivity.
Pros:
  • Tactical look
  • fine quality
  • looks waterproof
  • cheap
  • usable without any modification
  • mode memory
  • good brightness
  • bulletproof
Cons:
  • heavy weight
  • mid and low mode PWM
Conclusion:
This is a very good flashlight, and finally there's the mode memory too! A good layout modes, a lot of scattered light, the brightness level is almost a convoy S2 + 8x7135 version.
Warming in this light can be felt thanks to the fat body, wrapped in copper Pill, so you need not fear that the fry in it the first generation original CREE XM-L emitter.
Compare with other models:
MID mode:
HIGH mode:
The Ultra Fire WF-502B is easily surpasses, the S2 + is doing almost the same brightness.
Edited by: WestBam on 04/26/2018 - 06:01
Serp
Serp's picture
Cons: P60 Drop-in module
Conclusion: buy another flashlight (Convoy S2+) Big Smile
WestBam
WestBam's picture
This is not entirely P60 dropin, which has copper pill with P60 reflector. If you are fed S2+ it will also be good for him. Cool
