Test/review of Enercig EC-26500HP 2000mAh (Blue)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 min 39 sec ago
DSC_4849
Official specifications:
  • Typical capacity: 2030mAh
  • Minimum capacity: 2000mAh
  • Nominal voltage: 3.7V
  • Standard charge: 0.2C (400mA) to 4.2V CC/CV
  • Standard discharge: 0.2C (400mA) to 3V
  • End-of-charge voltage: 4.20V +/- 0.05V
  • End-of-charge current: 0.02C (40mA)
  • End-of-discharge voltage: 3.00V
  • Quick charge current: 20000mA (10C)
  • Cycle life: 300 cycles at 0.5C to 80%
  • Initial impedance: Max.20mOhm
  • Operating temperature: charging: 0°C ~ 45°C, discharging: -20°C ~ 60°C
  • Storage temperature: -5°C ~ 35°C
Enercig%20EC-26500HP%202000mAh%20(Blue)-info
This high current battery has a slightly uncommon size. The data above do not match the tested battery (Capacity is wrong).
DSC_4854
DSC_4850 DSC_4851
DSC_4852
DSC_4853
Enercig%20EC-26500HP%202000mAh%20(Blue)-Capacity
The two batteries tracks fairly well in voltage while discharging, but there is some capacity difference.
The cells can handle 20A discharge current.
Enercig%20EC-26500HP%202000mAh%20(Blue)-Temp-15.0
Enercig%20EC-26500HP%202000mAh%20(Blue)-Temp-20.0
The battery gets warm at 20A, but not too hot.
Enercig%20EC-26500HP%202000mAh%20(Blue)-Temp-30.0
Enercig%20EC-26500HP%202000mAh%20(Blue)-CapacityTimeHours
Enercig%20EC-26500HP%202000mAh%20(Blue)-Energy
Enercig%20EC-26500HP%202000mAh%20(Blue)-PowerLoadTime
Enercig%20EC-26500HP%202000mAh%20(Blue)-TripCurrent
Enercig%20EC-26500HP%202000mAh%20(Blue)-Charge
Conclusion
This battery is good at high current, but the difference in capacity means it cannot be used in series.
The marking on the battery and the datasheet do not match the capacity of the tested battery.
Notes and links
The batteries was supplied by ENERDan for review.
Compare to 18650 and other batteries
Jerommel
Jerommel's picture
Last seen: 10 hours 17 min ago
They contain unobtainium…
2Q19
Barkuti
Barkuti's picture
Last seen: 1 hour 10 min ago
Unobtainium? LOL!
́Cheers Party
