What Convoy S2+to buy? Where from?
Hi,
What do people recommend I purchase as my first Convoy S2+ light.
There seem to be plenty on GearBest, and AliExpress.
I see there’s this coloured version:
http://www.gearbest.com/led-flashlights/pp_154256.html
I prefer gray/black as opposed to colour, is there anything about the gearbest one that makes it better than the aliexpress one?
(Aliexpress one here).
http://www.aliexpress.com/store/product/Free-Shipping-Convoy-S2-Gray-Cree-XML2-U2-1A-AMC7135-3-2-Group-3-5-Mode/330416_1614328969.html
If I purchase the aliexpress one, should I go for the T6 4C / 7135 x 8? I want it to be as bright as possible.
Or should I wait until the Convoy S2+ Desert Tan/Black edition is released. Is it worth it in your opinion?
Thanks in advance.
Aliexpress store of Simon Mao is the original source of Convoy lights. The price is a bit higher than at gearbest or fasttech, but all customization options are available and you can even ask Simon for any customization not listed on product page.
If you find the exact configuration you want on gearbest or fasttech - you can save a few dollars.
Here is the configuration from Simon I would order:
(Convoy S2+)
Black
T6 4C
7135 × 8
Mode option 2 (5% - 30% - 100%)
T6 4C 8 (neutral white) is not the brightest emitting color. … you should go for U2 1A cool white.
If you want the brightest light in the same tube style there is the BLF A6 BLF A6 XPL 1600Lumen 7 / 4Modi EDC LED Taschenlampe 18650 Sale - Banggood Deutschland sold out-arrival notice-arrival notice
mattjberry wrote:
“I want it to be as bright as possible”
As always, you should get what you want. Here’s my opinion.
S2+ are good, floody lights, and I certainly appreciate wanting the brightest.
However, on HI, the difference between 7135x8 and 7135x6 is slight.
With 7135x8, the difference between MED and HI isn’t very much.
With 7135x6, the difference between MED and HI seems proper to me.
In other words, the mode spacing compresses and suffers at higher power, and 8x7135 gets hot quickly.
7135x6 gets this small flashlight plenty warm, but I don’t say hot.
I now have four S2+ 7135x6 (red, blue, grey, black), and think the LO-MED-HI mode spacing is about perfect.
The grey arrived looking sickly - sort of a pastel blue-hued grey - not what I was expecting.
The deep, flat finish on the black one is absolutely beautiful, bought here with code BLF (5% off):
https://www.fasttech.com/products/1653/10002364/1826603-convoy-s2-1-cree-xm-l2-u2-1a-860-lumen-2-group-3
I would second a 6x 7135 driver, the brightness you lose visually is minimal, but the runtime you get in return more than makes up for it. Also, the mode spacing mentioned above looks better at the 6x than the 8x driver.
Don’t listen to these guys, they don’t know anything :slight_smile:
Well, except for that part about S2+ looking better in black than in gray, somehow he got that right :slight_smile:
7135 × 8 is the way to go. If you order with “default mode” the medium is 40, but if you order with “mode option 2” as I recommend, the medium is 30 and the mode spacing is just perfect.
The answer to the OP question depends on use case.
If you want max brightness for each number of 7135 chips, get the U2 1A.
If you want better CRI, or a more neutral or warm tint, look at the other tint options (of which images are in the product page on Simon’s Aliexpress website).
If you only need to run the S2+ max brightness for a few minutes, get the 8*7135
If you need to run on max brightness for longer, consider the 6*7135 or 4*7135 versions. Obviously the max brightness will be less for each model.
If you want the best of both worlds or more mode options, maybe wait for new firmware.
After you’re done deciding on the normal S2+, I recommend getting the nichia UV version as well, paired with the UV pass-through black glass.
Best $17 I’ve ever spent on this hobby. :slight_smile:
I can’t seem to find Simon Mao’s store on Aliexpress. Do you have a link?
Edit: I found it by searching Simon here on BLF and now know his store is Shenzhen.
http://www.aliexpress.com/store/330416
Another question about Simon’s mode option 2. Do you just put a note in the message box in the order to make it “option 2”? I don’t see anywhere to choose that in the order, so I’m assuming a message is all he needs.
Just write down the option in the message box. :beer:
Has simon started offering high bin xpl?
Cheers guys, I’ve gone with:
Convoy S2+
Black
T6 4C
7135 × 8
Mode option 2 (5% – 30% – 100%)
Most of the time I will have it at 30, and can bump it up to 100 for a few minutes when needed.
Great choice :slight_smile:
Anoid alert.
Are you located in the USA ‘mattjberry’
It might not make the highest lumens, but unless you have some way of measuring them (most people don’t), then you’d never be tell by eye. Tint however you’ll notice whatever you use the light on and no matter what output mode you are using.
+1
So true, so true. :+1:
