New Convoy C8 – Clearly better
1530 posts / 0 new
Omega_17
Last seen: 5 hours 4 min ago
Good but no pocket clip? I know there is one separately but it is black.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 12 min ago
ZozzV6 wrote:
Now what? Here is the new nice great drivered clear C8 but I have a noctigon XPL HI, BLF A17DD, Black C8…. I need to sell the black one to buy this clear version, or I will wait for the L1 which will fill the gap between my C8 and L2.. Always decisions to keep or sell . But I want them all Big Smile Ughh But if the M1 get this clear look and new driver too I will buy one. And why the M1 more expensive than C8 everywhere? Is it more difficult to machine on the fins of the head? +1 for Pilotdog’s opinion on driver. I like fet but I can replace it easily.
What are you going to do when the L.5 (1/2 size) of the L1 comes out? Big Smile Just kidding Evil
KB1428 “Live Life WOT
DB Custom
DB Custom's picture
Last seen: 18 hours 43 min ago
The driver is based on Convoy’s prior use of the Nanjg 105B, the layout easily accommodates stacking 7135 chips to raise the current. 4.5A with a modern XM-L2 makes for a very nice C8, with little real world difference in output compared to an FET driver. It’s kept simple this way, Simon get’s to continue using the backstock of drivers on hand, and we benefit from a much more widely accommodating UI.
Really nice win for Convoy, and for Convoy fans alike.
zeremefico
zeremefico's picture
Last seen: 1 hour 54 min ago
Date of release?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Chicken Drumstick
Looking very good, big thumbs up to Simon and all those at Convoy (the op too).
Will definitely be getting one of these. Personally I really like the look of C8 visually. Although I must admit, if Simon offered a green one, I really wouldn’t be able to resist it either…
Smile
J-Dub74
J-Dub74's picture
Last seen: 9 months 3 weeks ago
Serp wrote:
why not used MOSFET for DD?
From the OP “To help keep the C8 comfortably in the budget range we are still using a 2.8A Nanjg based driver”
ZozzV6
ZozzV6's picture
Last seen: 30 min 32 sec ago
It will fill the gap between L1 and C8 or C8 and M1 Cool
J-Dub74
J-Dub74's picture
Ok all I’ve posted the complete UI description in post #2 of this thread. I will add more details as I can and of course make any corrections if necessary. Cheers.
giorgoskok
giorgoskok's picture
Last seen: 1 week 5 days ago
Is there an L1 prototype ?
Because i saw you mentioned it also in L6 thread.
DB Custom
DB Custom's picture
I keep pushing for it. Silly
ZozzV6
ZozzV6's picture
I like the UI very much. My only problem with it that I need to have lot unnecessary flashy modes to have battery check function.
DB Custom
DB Custom's picture
Wherever there are 100 ways to provide a solution there will be that 101st person to have a new problem. Wink
Not picking, but it’s always the case. The ATTiny13A only has so much space, it’s just about impossible to provide solutions that are perfect for absolutely everyone. Our own MattAus found that out with his Hyperion firmware, quite some time ago… and the saga continues…
J-Dub74
J-Dub74's picture
This is all pretty spot with the exception of “backstock”. That’s probably true of some of the components but these are newly manufactured drivers made specifically for Convoy. The primary goal in this driver choice was to give the very budget minded an excellent C8 option better that what’s currently available. Going to a FET driver would have put this light in the $30 range when we want be closer to the $25 range. That doesn’t mean FET drivers can’t be an option down the line but my goal with this driver redo was to bring a higher level of awesomeness to the lowest priced lights in the Convoy line in true BLF spirit.
This driver will also be used in the S series lights including the next S2+ colors (or lack of) that will be produced. Finally, as Dale pointed out and has tested himself, any modder that can stack more 7135 chips to bump the power higher. Thumbs Up
DavidEF
DavidEF's picture
Last seen: 1 day 18 hours ago
Well, it’s ATtiny13, so you can ‘flashy’ whatever modes you want! Wink
- The YKK Philosophy
ZozzV6
ZozzV6's picture
Not a real problem. I have BLF drivers but not much times I used the batt check. The stepdown and LVP kick in and then replace batteries if I discharge them so far but mostly I don’t. Thumbs Up
KawiBoy1428
Jared, you done good!! I’m pretty sure there isn’t another budget light with multiple UI choices and a Custom finish for this kind of $$$$$ or is there?? Thumbs Up
David excellent point! Thumbs Up DIY!
The Miller
The Miller's picture
J-Dub74 wrote:
The Miller wrote:
And what is the voltage for LPV to kick in (now it is a bit too high for my liking in Convoys so if that is reduced to (<)3V this looks like an awesome driver I will order more from (preferring longer runtimes over a shorter extra brightness))
Per TK: LVP kicks in at 3.0V at which point the driver will start stepping down power levels finally ending in a “soft off”.
Awesome!
Sounds like a very nice driver for quite a few of my lights.
Thanks once more!
Fritz t. Cat
Fritz t. Cat's picture
It is good that it has DTP, because the smaller package of the XP-L won’t cool as well as an XM-L2 on a non-direct star. The listed thermal resistance is better, so they must have improved or reduced the internal insulating layer, but the smaller footprint would give the heat less area through with to penetrate an insulator on the star.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
HorizontalHunter
HorizontalHunter's picture
Very nice.
Bob
Vegetarian: vejiˈte(ə)rēən/noun: old Indian word for lousy hunter.
Lightbringer
Lightbringer's picture
Last seen: 7 min 51 sec ago
BLF noob here, so I don’t quite know all the players involved…
Is this an actual “type 3” model C8 direct from Convoy, or modded/variant of the type 2? (type 1 = pill, type 2 = integrated head)
Maybe I didn’t read closely enough, but I’m not quite sure who’s going to be selling them. Smile
I always loved the “gunmetal gray” that M*g had. Not that polished-Al (“chrome”) look, nor matte-gray, but a darker shiny gray that I’ve seen at least in the 3xAA and 2xD lights that I’ve got. That would look awesome in a C8…
Question about moonlight/firefly mode, though… Does it ever “stick” off when hot? I’ve heard that when you’ve got the light on high and things heat up, that sometimes if you switch to firefly mode, it just won’t light at all until it cools down (fine in higher modes, though). Which is why… I think it’s in the QLite driver source… there’s a certain minimum (6/256) that you have to set firefly mode to reliably turn on.
Might have to do with the capacitance of 8 parallelled 7135s, too. Little skinny pulses might not be enough to bump them on.
And I’m wondering about PWM flickering when it’s set that low.
Lightbringer
Dunno if I’d want to pocket a C8 unless I were wearing cargo pants. Big Smile
WojtekimbieR
Last seen: 3 days 23 hours ago
This will be the top #1 recommendation for a newbie thrower for the next years, I'm really happy with 8×7135 2.8A and the new modes, especially the proper 1% "low".
Just for a moment... Okay I may stay a little longer
agnelucio
agnelucio's picture
Last seen: 3 weeks 3 days ago
Yeah, I’ve got to agree with Tech; the DTP board is a significant improvement, and the new driver sounds great (sort of A17-ish), but for me, the chrome finish ruins it.
Matte black looks elegant, doesn’t show dirt as much, and is great for radiative dissipation of heat.
I don’t want my lights looking like a chrome bumper. Sick
I’ll stick to the current model, as I never keep anything stock anyway.
teacher
teacher's picture
Last seen: 6 months 1 week ago
Very impressive!! Thumbs Up
DB Custom
DB Custom's picture
It’s obviously not “chrome” but has the same surface of the matte black, without the dye. I’d kind like a high polish SS variant myself. Smile
These are made by and sold by Convoy-Flashlights on AliExpress. They’ll be found at GearBest and Banggood soon enough I’m sure. Simon is Convoy, JDub is working with Simon to help bring the needs of the people to light. (see what I did there? Wink )
stephenk
stephenk's picture
Last seen: 2 months 4 days ago
Great looking C8, and nice improvements. Will there be a 10 or 12 chip stock version?
If this is the same mode grouping that will be used in the newer S2+, I would have preferred a mode group with 50% and 100% in the same group. This would have allowed for the light to be run as bright as possible with no heat issues at 50%, or on “turbo” for when shorter bursts of 100% brightness is required.
Swib
Last seen: 2 days 6 hours ago
Any idea if it gets hotter compared to the FET? I thought I read that the FET ran cooler than a high current regulated driver.
If you don’t like what it looks like on the wall, take it outside.
KawiBoy1428
What was going on before Jared showed up? Now what has happened since Jared has been here……………. EXACTLY! What Dale said….. Big Smile Thumbs Up
Xoden
Serp wrote:
Tangra wrote:
I saw poject driver in which every 7135 was switch on end off individual. So in this case there is no PWM and efficiency is hifher in low modes because work as many 7135 as neccecary for each level.
Is there any problem using this driver in new Convoy C8.
http://forum.fonarevka.ru/showthread.php?t=28412
This. This is very convenient and easy mod for 105c. Two extra wires and new firmware. Too bad it didn’t get done here.
Though I guess even slightly altering a PCB layout is a too massive undertaking for a budget-friendly flashlight.
ToyKeeper
ToyKeeper's picture
Last seen: 8 hours 58 min ago
When I went to sleep, this thread didn’t exist. Now it’s already at 90+ posts. That’s a lot of activity in just a few hours!
I tried to fit as much as I could into a standard nanjg 105d driver, and make it useful for a wide audience. This new C8 is the first item to have the new firmware. I assume it should also work in anything with a compatible driver, like the S series and maybe M1/M2 or BD series.
So far it’s called bistro-mini, because it’s based on bistro but half the size. People have told me this is a bad name though, so I’m considering some others…
  • biscuit or biscotti, to keep the tie to bistro but indicate something smaller
  • converge, convertible, conveyance, convect, convene, convey, convalesce, … to tie into the Convoy brand
  • “Jared Stinks”, as suggested by Jared (J-Dub74)
Any preferences?
(edit: my preference is to not put my name in the title)
