New Convoy C8 – Clearly better
1530 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 4 hours 1 min ago
Yeah, getting atmel setup can be hard, thats why I just use linux to compile now, no such complaining.
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 48 min ago
I may be biased, but it really does seem a lot easier to do this stuff in Linux. Paste in a couple commands to set things up the first time, then a couple more for each build/flash. That’s about it. No need to go menu diving, manually importing files, or finding obscure settings in the GUI.
Jack Kellar
Jack Kellar's picture
Last seen: 6 hours 31 min ago
Linux is consistently the better option as long as you have the least bit of experience with a command prompt and programming language. A college freshman or amateur enthusiast can do wonders already.
gchart
gchart's picture
Last seen: 1 hour 13 min ago
I’ll echo the above comments. I solely use Linux and it’s a cinch for firmware programming on.
J-Dub74
J-Dub74's picture
Last seen: 8 months 3 weeks ago
I appreciate all that but I don’t know Linux. I wish I did but if wishes were fishes I’d have a SWEEEEEET sushi bar setup… Facepalm
mapache
mapache's picture
Sushi Linux is pretty easy these days. I have only played with a few flavours (settled on elementary) and most of them had easy to follow guides on how to make a bootable USB drive if you don’t want to worry about partitioning, from there it should be mostly cutting and pasting. If you run into troubles I am sure some of the cool kids that know linux well could help you out.
Texas_Ace
Texas_Ace's picture
You can use atmel but good luck getting it to compile, I think Tom posted some ready to compile exports from atmel to make it easier at some point.
As was said if you have a spare USB drive laying around it is really quite simple to install a “live USB” version of linuix on a USB drive and simply boot your computer to that when you want to use it.
I have a USB drive with a half dozen linux installs along with every utility I have come across that can be run from the command prompt. I even have a full windows 8.1 install on a USB drive.
TWN
Last seen: 5 days 3 hours ago
Any tutorial for Linux which I can read?
Surely I would love learn simple code for my needs.
Not Linux expert, but I can understand both Win and *nix.
J-Dub74
J-Dub74's picture
That sounds like a nice alternative option. I used to run a version of Knoppix (old Linux build) off a CD and that was pretty simple to use. I’d ask Tom about that but he doesn’t respond to my PMs anymore. Sad
gchart
gchart's picture
+1 for Ubuntu Linux or one if it’s official flavors (Xubuntu, Lubunut, Kubuntu, Ubuntu MATE, etc) loaded onto a USB drive. It’s typically much easier than you’d imagine and it doesn’t make any changes to your hard drive (unless you specifically tell it to).
gastonpatagonico
New arrival, ohhhhh !!!!
kaizer
Last seen: 2 years 3 months ago
Is there something wrong with my C8?
My set up is with memory turned off. Every time I switch it on, the light will flicker/strobe before it goes into moonlight mode. Is that normal?
benoe
Last seen: 2 years 5 months ago
Yes, I have the same problem, waiting for the seller’s (Simon from Convoy store) feedback.
From where have you bought yours?
The problem is that the light enters into group selection mode every time you switch it on. Unfortunately it is something that you can only possibly fix with driver reprogramming.
There is a detailed explanation here: link
benoe
Are these working as they should? Isn’t there a few blinks every time you switch them on?
kaizer
Hi Benoe, got it from Convoy store in Aliexpress as well.
In my case, that doesn’t seems to be group selection mode. Seems to me it’s in normal operating mode. Just that the light flickers some kinda code (doesn’t look like a random blink) before it goes to the default moonlight mode.
Will check out the link, thanks.
atbglenn
atbglenn's picture
Mine doesn’t do that. I have mine programmed to group #3 with memory
Boycott Nike
benoe
Yes, it should be the config mode, and what you see is the two “buzzes” (first for group selection, second for mode memory on/off). Normally you should get here after tapping the button 10 times.
You can also find a video about it here
gastonpatagonico
Hello, it works correctly to buy in the store of simon, only that it is a little quick the blinks, it hinders a little the programming requires some attempts, one is programmed in mode 10 the other stock.
notfast1
Last seen: 2 years 11 months ago
Just got mine today. Can’t really beat it for the price.
I’m a n00b when it comes to programming a light but was able to get memory turned on which was most important. Planning on trying a different setting (4) but 1 is good for now.
I’m really impressed
gastonpatagonico
10 clicks fast less than 3 seconds, with flashlight turned on, if after this flashes 2 times and then 3 enter as a programming, not really, repeat 10 clicks fast not deep, flash 2 times tighten before doing 3 Blinks, re-start, starts 1 blinking, pause 2 blinking pause …….. 12 blinking, not counting blinking counting pause between blinks, if you want 4 press in pause 4 in depth to turn off / on, on And verify that it is the way to your taste, it seems difficult but it is not after 2 or 3 try , and excuse my bad english use translator, greetings !!!
rdoc613
Last seen: 1 year 3 months ago
I enjoyed reading this. LOL
I take it that you figured out the programming. Awesome!
gastonpatagonico
Not really, pepinfaxera of FOROLINTERNAS. Here the link, greetings and do not stop trying !!!
http://forolinternas.com/viewtopic.php?f=4&t=13032
Lexel
Lexel's picture
Last seen: 4 hours 10 min ago
I did order the new driver from Banggood
The programm fuses were set right so no problems with timing
jigsaw
jigsaw's picture
Last seen: 5 hours 15 min ago
When will these be back in stock?
JasonWW
JasonWW's picture
Last seen: 35 min 17 sec ago
From what store do you mean?
The Convoy store should open back up on Feb 15.
Other stores I have no idea.
Click this to go to signature links.
jigsaw
jigsaw's picture
JasonWW wrote:
From what store do you mean? The Convoy store should open back up on Feb 15. Other stores I have no idea.
That’s what I meant. Thanks
kaizer
Just want to update.
Although Simon mentioned he’ll be back online on 15FEB on his store, I drop him a message on the 13FEB regarding my C8 flickering issue. Received a reply from him yesterday and by today it’s concluded. He will send me a replacement driver. While I still have to find someone to solder it for me, that’s the best customer service I’ve had from any China retailer.
Frankly with a festival as big as Chinese New Year celebration in China, I wouldn’t thought of getting any reply from him before 15FEB.
He came out top and I’m sold.
He gained a loyal customer. Awesome guy.
benoe
Yes, I can confirm Simon is back, and he offered a replacement driver for me as well. I just hope that it will work correctly.
In the meantime, I also ordered an usb programmer+clip to try to reflash the non-working driver.
fuzun
Last seen: 1 day 14 hours ago
Does this light better if you compare against S2+ ?
JasonWW
JasonWW's picture
The big difference is the C8 has a very focused beam for long distance use. The S2+ has a wider beam for close use and general purposes. They are both high quality.
