Test/review of Konig Home charger IPD-Power30
Official specifications:
  • Type: USB Adapter
  • Input Voltage: 100 - 240AC V Volt
  • Output Voltage: 5 V Volt
  • Output Current: 1000 mA milliAmps
  • Output Power: 5 W Watt
  • USB Connection: Yes
  • Stabilized: Yes
  • Standby Usage: < 0.3 W Watt
Measurements
  • Power consumption when idle is 0.18 watt
  • Usb output is coded as Apple 1A
  • Weight: 43.6g
  • Size: 82.5 x 55 x 32.6mm
Output current is 1.4A before it shut down, this is fine for a 1A charge.
120V looks similar, but with slightly less output current.
There is no problem maintaining the rated 1A current.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
M1: 40,5°C, HS1: 54,1°C
M1: 42,4°C, HS1: 54,1°C
HS1: 54,2°C
Noise at 0.5A load is: 47mV rms and 357mVpp.
Noise at 1A load is: 64mV rms and 388mVpp.
Tear down
I could not crack this with my vice, I needed a screwdriver to pry it apart, it uses clips.
At the mains input there is a fusible resistor (1W10R) followed by a bridge rectifier made with four diodes. There is two capacitors with a inductor between (L1). The safety capacitor is hidden in heatshrink.
On the output is also used a round leaded diode.
A single switcher chip (AX2535) handles everything here, including output voltage stablization without an opto coupler.
The missing opto coupler is also the reason for the voltage drop at low loads, the regulator need a bit more current draw before it compensates for load.
There is good isolation distance.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This is a small usb power supply with only 1A output and missing DCP coding, it is safe and works fine, but has not really kept up with the times.
Notes
Charger was supplied by Pro backup (probackup.nl)
My high voltage test is done with a real HiPot tester allowing me to use the correct voltages for US and EU.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
