HaikeLite Preview for MINI Triple-XHP70 prototypes--Discussion thread
203 posts / 0 new
hIKARInoob
hIKARInoob's picture
Last seen: 17 min 6 sec ago
Interesting. The rubber USB port cover is not designed to withstand pressure from the inside, hence air can escape (apparently) if pressure is sufficiently high as was the case with the EC60.
The fact that this (most likely) happened with the MT03 makes me wonder if this can happen with other high output lights as well. If this is not the case, then I question the water proofing capabilities of the switch of the MT03… Or perhaps the rubber button is not securely tightened from the inside?
maukka
maukka's picture
Last seen: 7 hours 38 min ago
The button has a metal bezel fastener without threads so it can just pop out if there’s enough pressure. I believe it can prevent water coming in though.
hIKARInoob
Wowowowow….what? No threads? How does it exert pressure to the rubber button? Just press the metal ring downwards and that’s it?
Edit:
I don’t get it… I mean this looks like the reason air can escape easily from the inside… And I seriously question water proofing now…
leaftye
Last seen: 1 month 1 week ago
Different expansion rates would help it pop out.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
hIKARInoob
Correct. Aluminium has much higher thermal expansion than steel. Meaning, if the light gets hot, the ring’s normal force with the body reduces as well…
leroycp
Last seen: 5 hours 22 min ago
Got mine yesterday. This thing does put out some light! In a living room I pointed it at the corner of the ceiling and, in turbo, it bounced off all walls and clock and pictures…and hit both of us in the eye. Don’t use turbo in the house! Serious amount of light. Very nice neutral version. Outside massive flood. I did compare to the Buffalo BT07 which has serious throw for an XHP70 plus the normal amount of spill. Different topic but the MT03 is again a serious flood. It is well built. I used 4 × 18650GA 3500s.
maukka
maukka's picture
Heh, yeah, I just showed it to my dad. He thought it was already on turbo even though it was on high, a bit of clicking and holding and BOOM, he was startled and burst out laughing.
Have you physically locked your light by screwing open the head? I’ve done it a couple of times and suddenly the thing didn’t work anymore. The driver retaining ring had come loose from all the head opening.
hIKARInoob
Typical guy thing. Couple of weeks ago I was in the woods after midnight with my lights. Cop car showed up (in the woods). Of course I had to explain what I was doing. I showed them my lights. Cop asked politely if he could play with it a bit. No problem. I gave him my Meteor M43. Told him “just press and hold the button”. He did so, and there was a wall of light in front of him. Cop was giddy as a little kid Wink
leroycp
No I haven’t used lockout yet. I am checking without lockout and carry it along on the road. Waiting for night again…lol
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 5 hours 18 min ago
How many lumens do you think it is? Mine hit over 10k lumens if my ceiling bounce is set up right. But I could be way of.
pilotdog68
pilotdog68's picture
Last seen: 3 months 5 days ago
These are the best moments
maukka
maukka's picture
Havent’ tried sphere yet but according to ceiling bounce I get pretty much spot on 10k at 30 seconds.
HaikeLite Official
HaikeLite Official's picture
Test sample has no glue on the retaining ring considering you want to test the inside.
The retaining ring of Stock MT03s are all glued tight. So it can not be pop out even with pressure.
HaikeLite Official--all rights reserved
www.haikelite.top
Skype: haikelite@yeah.net
Texas_Ace
Texas_Ace's picture
Last seen: 10 min 54 sec ago
It is sad that they will be glued. Glue on anything really hurts the moddability of the light.
JockRobbins
JockRobbins's picture
Last seen: 3 years 2 months ago
Location: The slightly cooler end of a high powered torch
So looking at the latest posts, how does the fan vent to atmosphere? I take it there are no always-open vents, due to the waterproofing??
HaikeLite Official
yes.glued rings by default.However,if you wanna do modder to this light,you can contact us to send unglued version.
www.haikelite.top
leaftye
I don’t know any other manufacturer that would be that flexible.
Flashy Mike
Flashy Mike's picture
Last seen: 2 hours 30 min ago
What’s about repairing if the switch gets faulty? You should consider using threads in the next batch.
HaikeLite Official
The quality of the switch is very stable. We have 2 year’s warranty.
Thanks for your suggestion. We got it
www.haikelite.top
techieman33
Last seen: 9 months 5 days ago
Warranty’s are nice, but they aren’t that valuable if you have to send your light halfway around the world and pay half of what you paid for the light just to get it there. Then wait a couple of months without the light while it’s being shipped and repaired.
JamesB
Last seen: 1 day 16 hours ago
The press/glue fit of the side switch is reminicent of some zerbalight bezels, they have frequent waterproofing failures with those as has been discussed on CPF.
I actually very much like the idea of a over pressure failsafe even if it wasn’t by design Thumbs Up granted it doesn’t pop out with regular use but only in case of battery venting.
Nicolicous
Nicolicous's picture
Last seen: 19 min 30 sec ago
you’re right.
I had the super old model H600 and it got water issues.
Nico -.-
