Review w/pics: ReyLight's Golden Rey of Sunshine
64 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 46 min 47 sec ago
I was contacted last week by Rey about his newest little AA/14500 light made from solid brass. He asked if I’d be interested in doing this review and taking some pictures and I was more than happy to oblige! Rey has been making some really nice lights and they’ve certainly outdone themselves with this one! Smile
As you can see, this came to me with a brushed finish and a nice mirrored clip. The light is meticulously prepared top to bottom, the finish is very uniform and quite pleasing to the eye and also surprisingly easy to hold onto. This one takes a regular Alkaline AA cell or if more power is desired (and one knows what they are doing with these more powerful cells) the 14500 Li-ion cell can also be used.
This sample has a Nichia 219C with a warm white tint that is seemingly in the 4000K range, it’s warm but not extremely so, which is actually quite pleasant in this small light with an AA cell, the tint bin complements the brass and is easy on the eyes. The reflector is a mild orange peel with a semi-hybrid cone at the base, as such it gives a smooth but again surprisingly tight beam profile. Surprise is a key element with this light, I was continually amazed as I opened it up for these pictures. Smile
Testing showed the following results using a new Alkaline Copper Top 1.5V cell…
Level___Current___Lumens
1…………0.003A…….0.069
2…………0.047A…….4.002
3…………0.391A…..30.774
4………..1.325A……86.94
Energizer Lithium Primary 1.5V
1……….0.003A………0.00 on the meter
2……….0.044A………2.09
3……….0.389A…….33.496
4……….1.323A…..106.95
And with a freshly charged dark purple Efest 14500 650mAh cell…
1………..0.001A……..0.00345 (firefly, barely glowing)
2………..0.063A……10.212
3………..0.477A……96.945
4………..1.83A……362.25
[Above numbers edited on 9.13.16 at 5:04PM to reflect accuracy. Sorry about that!]
The tail cap has a SS button with a slot for a tritium vial already machined in. The slot is amply deep, the button clears the brass for easy tail standing, and the operation is smooth and easy in a reverse clicky format. If the button is stressed, pushed from the side, it can drag a little. I’m finding 4 modes, starting with a true firefly and stepping up in nice increments that make it a very usable EDC. I can easily see this in the suit pocket of a business man or woman, or carried in a small handbag or clutch in an equally plush office setting for a female from a nice secretarial job to a lawyer. Obviously it would work well in a myriad of user situations, make note though that the solid brass construction is substantial, you’re not going to lose this one in a pocket as it’s weighty enough to remember it’s there!
Well machined at every turn, notice the rounded bevel around the switch button. Easy on the fingers or fine gloves. Wink This kind of attention to detail prevails throughout the build of this little brass light and I for one very much appreciate the effort. Wink
Removing the tail cap to put in a cell has the pocket clip retained by the o-ring. It will come off without removing the o-ring if you wish, but it’s secure enough to not lose with a cell change in most normal type situations where a reasonable person is paying attention.
As you can see in these two pics, above and below this sentence, threading is clean and robust, heavy enough pitch to make it easy to engage and not get in a bind. This IS brass, so a person should exercise some care though as the threads will be prone to damage otherwise. Just something to keep in mind.
Notice too the fitment of the retaining ring, the care given to even have flat bottom holes in the tiny access holes of the retaining ring! Well done, this shows someone that knows flashlights and works with them regularly is behind the design on this, to every last detail. Even the cord hole in the pocket clip, also serving to keep the light from rolling far when laid down.
Thread fitment on all sections is snug, well backed by the o-rings, and there is already a bit of grease in place where needed.
The driver is held into the light engine with an external retaining ring, a neat idea in a small light such as this. If you must remove the light engine, the retaining ring comes out first (it’s in the same threads as the pill itself) and it is a bit tedious re-inserting this pill and keeping the driver in place… it has tabs on either side that fit into slots on the pill and then opposing these slots are narrower tweezer slots for pill removal. All in all well thought out and executed.
Taking the tail cap assembly apart shows once again that somebody was really thinking here! There is a nicely machined brass cup that presses a sealing rubber boot into the end of the tail cap so it’s water proof and yet the SS external button has an easy use. The retaining ring fits perfectly, everything is just really well done here! Surprised again, was I!
The fitment of every tiny piece, the machining, just extraordinarily well done at every turn! Bravo!
The pill is no different, housing the Nichia emitter with a nicely done centering/isolation disc that cups the reflector perfectly.
The driver is a dual board design, I didn’t remove it for these pics but probably will later at some point and I’ll get pics then of the driver components and layout.
The reflector is well done, apparently designed and made for this light as I don’t recall seeing anything quite like it before, from the external fitment at the base to the cone style hybrid like design at the emitter. The result is a nice focus that will have this light becoming a favorite to use. Wink
Will you just Look at how exquisitely machined these threads in the head are?! Superb! Again, surprised by the attention to detail and fitment. Beautiful work!
Even a bit of crenelated bezel style, so you can see if the light is on when standing on it’s head. Smile
And even the lens is 2 side AR coated with a nice purple reflection indicative of a quality coating. Not leaving any stone unturned, there is a bevel on the edge of the glass as with any nicely done lens.
A Pleasure Rey, very well made light through and through and I very much enjoyed doing the review on it. Well done, as usual! Smile
Dale
Edited by: sb56637 on 09/02/2017 - 11:48
CRX
CRX's picture
Last seen: 3 hours 51 min ago
This is really nice!
will34
will34's picture
Last seen: 2 weeks 4 days ago
Looks great, there are no visible sharp edges, huge step up compared to the BLF-Ti
Would love to see a 18650 version made of titanium.
mattlward
mattlward's picture
Last seen: 12 hours 7 min ago
This will be a must have! Rey assures no visible PWM and someone who understands how to install a pocket clip!
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 56 min ago
I’ve been looking forward to this one. It seems like a very nice host, and the clip really helps make it useful for daily purposes.
Will probably get one or two and see what I can do about customizing the driver, because I enjoy that kind of thing. The default seems pretty decent though, with modes and spacing similar to the venerable L3 L10-219.
EyeballFryer
Last seen: 5 hours 51 min ago
I have some 14500 batteries sitting around, doing nothing. Not for long.
Any suggestions on where to get a tritium vial that will fit inside that tailcap slot? How does the tritium vial stay inside the slot if the flashlight is jolted, such as from a fall?
djozz
djozz's picture
Last seen: 1 hour 24 min ago
Very nice review, your pictures are a treat, as usual! It looks like Rey has learned all the lessons there were to learn, and again delivers a custom light for a price that is way below custom light prices, but now also with all the details right.
This light is too heavy for me to consider buying, but seems more than worth the money!
ToyKeeper
ToyKeeper's picture
Glue.
Specifically, Norland 61 optical adhesive. It goes on like vegetable oil, but cures in UV or sunlight to form a hard, durable, invisible glue.
EyeballFryer
ToyKeeper wrote:
Glue.
Hmm, so that means if I decide to change the vial because the vial’s color doesn’t work for my usage, I’ll have to pry it loose from the adhesive?
Gunga
Gunga's picture
Last seen: 4 days 23 hours ago
Use boiling water to soften the norland. Then pick it out carefully.
DB Custom
DB Custom's picture
101 g with Energizer Lithium prinary AA
Dale
mhanlen
mhanlen's picture
Last seen: 2 weeks 1 day ago
Looks super nice. Those low moonlights are awesome, as is the tint, and pocket clip. Good job Rey, and thanks for the review Dale!
MRsDNF
MRsDNF's picture
Last seen: 5 hours 30 min ago
Thanks Dale and Rey. Looks like a real winner.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
DB Custom
DB Custom's picture
For TK, the ReyLight Brass Cutie next to the DQG 18650 Brass Beauty. Cells alongside for comparison.
(Yeah yeah yeah, I used the little Canon S90 instead of the 7DMkII with 100mm Macro Hybrid IS. Lazy, pure and simple.)
The thing here is, the DQG Brass Beauty was made to be as small as possible and fit an 18650. I have but one cell of all my cells that will fit inside this light and it’s really snug at that. The ReyLight Brass Cutie is made more robust, takes ANY AA cell or ANY 14500, lot of options there. Both are brass, yes. One is more refined, serves a grander purpose. Big Smile
Dale
WWEFANS
WWEFANS's picture
Last seen: 10 hours 5 min ago
Of a Ti 18650, yes, yes, yes.
WWEFANS
WWEFANS's picture
I will add a pic with trit installed later.
DB Custom
DB Custom's picture
I was just thinking about that as well Rey, I’ve got a green trit sitting here and the Norland to put it in with. And a crazy powerful UV light I made a while back to cure it. Big Smile
Edit: Not feeling so great but got a quick trit shot anyway. Sorry if it sucks…
Dale
jacktheclipper
jacktheclipper's picture
Last seen: 23 hours 59 min ago
Neato .
But I would have to file off the cord hole on the clip .
ToyKeeper
ToyKeeper's picture
Thanks! It looks like it’s about the size I expected, similar to a Thrunite T10. Between the nice aesthetics and the clip, I’ll likely get a lot of use out of mine.
It’s fun trying to avoid perspective distortion on those little cameras, isn’t it? I always have to back away and zoom in as far as I can without making the exposure impossibly-long.
DB Custom
DB Custom's picture
I shot that in Macro from about 5” away, applied distortion correction in Lightroom 5. Wink
Easier, at the time, than digging out the big camera. Not sure what’s going on tonight but I feel lousy. Oh well.
Dale
james y
Last seen: 13 hours 16 min ago
Looks really good. Do you have a Rey Ti for a quick size comparism?
lumenzilla
lumenzilla's picture
Last seen: 6 hours 52 min ago
Beautiful! Love
www.lumenzilla.com
MiG0
Last seen: 1 day 3 hours ago
Dear DB Custom,
Thanks for excellent review and especially the photos.
Are you sure that your current measurements are correct?
I suppose you measured current drawn from battery.
Comparison between levels 2 and 3 for both types of energy source looks very disturbing to me.
Henk4U2
Henk4U2's picture
Last seen: 2 hours 58 min ago
If a valet is a gentlemans gentleman,
then this must be a gentlemans flashlight.
Ready to serve you a lifetime.
And I would NOT file off the cord hole on the clip!
@Dale: nice review. This light has touched you, or what?
I always think long and hard before I say something really stupid.
DB Custom
DB Custom's picture
MiG0, I took current readings at the tail with a 12Ga loop and clamp meter. Have no idea why the numbers would disturb you. Must be missing something…
Henk, yeah, I like it. The overall style is nice, build quality is exceptional, numbers from the 2 different (3 different?) cells are very acceptable and the light, used as such a light would be used, just works nicely. The Nichia emitter is a good choice here I think, seems good choices were made in a lot of areas on this one… my opinion of course, as I really like a well made small flashlight.
I know some people just really have to have some negatives to feel good, where I tend to overlook negatives and focus on the positives. So, that said, if one just had to look for cons I suppose one or two could be found. Here’s a couple of little nigglin things… the switch button needs a pretty deep press to turn it on initially. It’s a concentrated effort, not likely to be done accidentally. My ~80 yr old Uncle was here yesterday and he has fat fingers and thumbs, he had issue with it. He loved the light, the weight of it, and thought it’d make a great gift for his wife. (both are very persnickety and want things to be Just So!) He said the light was made solid enough to fire out of a shotgun. I have to agree, but I don’t think it’s overkill here. The CNCQ DNQ Brass Beauty feels like it could be easily crushed, they tried so hard to make it as small as possible. Nice to see a light made for the long haul.
The pocket clip doesn’t grip as strong as some, so it won’t hold the light at the top edge of the pocket for example. And of course it is attached to the tail cap (in a manner of speaking) and comes off when changing cells, where it could have been maybe better if it stayed with the body of the light.
FWIW, the Nitecore MH20GT that just came in yesterday isn’t perfect either, and cost a smooth hundred bucks. (Pocket clip is TOO tight, difficult to remove from the pocket.) But that’s another story…
Nigglin things, hardly worthy to note which is why I didn’t in the first place.
If you look for the bad in life you will find it, if you spend your time looking for good you will likely create it. Wink
Dale
jf_smm
Last seen: 3 days 21 hours ago
The pre-machined tritium slot is genius
J-Dub74
J-Dub74's picture
Last seen: 8 min 20 sec ago
Dale – Very nice review with the great pictures we expect from you.
Rey – Just based on the pictures I’m in agreement with Dale. That is one fine piece of craftsmanship. I think you nailed it in the styling department. In that side by side comparison picture of the DQG 18650 Brass Beauty there is really no comparison. The “Brass Beauty” looks like an unrefined piece of brass pipe compared to the styling you’ve worked into yours. What is the actual name of the light? I’m not sure if the “Golden Rey of Sunshine” was just clever wordplay by Dale or really the name of the light.
I do agree with jacktheclipper about the cord hole and would definitely file it off if I had one but as evidenced by comments above some people like the cord hole. For me it would just be something sticking out as a snag point or would be poking into my leg if I had it clipped to my pants pocket. If the clip is a little loose it should be easy enough to give it a gentle bend to tighten it up. I’ve had to do that on many lights and pocket knives and do not consider that anything to gripe about. This looks like a nicely done review of a nicely done flashlight. Bravo!
maukka
maukka's picture
Last seen: 10 min 20 sec ago
Does it smell bad?
Yes, really, I have some bad smelling brass stuff…
WWEFANS
WWEFANS's picture
It is called ReyLight Pineapple. In the EOI thread, we named it yesterday.
quetzalcoatl
quetzalcoatl's picture
Last seen: 10 months 2 weeks ago
maukka wrote:
Does it smell bad?
Your hands produced to much sweat Smile
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 3 weeks ago
Nice review Dale. It looks like the driver has two very shallow inductors. It would be nice if HKJ could get a hold of one for testing to see how performance is on the two types of cells. Very nice work Rey, well done all around.
Scott
