Test/review of AW IMR18650 2200mAh (Red) 2016
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 14 min ago
DSC_5283
Official specifications:
  • Nominal Voltage : 3.7V
  • Capacity: 2200mAh
  • Lowest Discharge Voltage: 2.50V
  • Standard Charge: CC/CV ( max. charging rate 2.2A )
  • Cycle Life: > 500 cycles
  • Max. continuous discharge rate: 20A
  • Operating Discharge Temperature: -10 – 60 Degree Celsius
  • Dimensions: 18.15 × 65.6 (+/-0.05)mm
AW%20IMR18650%202200mAh%20(Red)%202016-info
A high current and fairly low capacity 18650 cell. This is one of the few high current cells with button top.
DSC_5282
DSC_5284 DSC_5285
DSC_5286
DSC_5287
AW%20IMR18650%202200mAh%20(Red)%202016-Capacity
Discharge curves looks very good up to 20A with very good tracking and nearly constant capacity, but the cell cannot handle 30A (Probably the reason it is rated for 20A).
AW%20IMR18650%202200mAh%20(Red)%202016-Temp-15.0
AW%20IMR18650%202200mAh%20(Red)%202016-Temp-20.0
The battery gets warm during a 20A discharge, but not too warm.
AW%20IMR18650%202200mAh%20(Red)%202016-CapacityTimeHours
AW%20IMR18650%202200mAh%20(Red)%202016-Energy
AW%20IMR18650%202200mAh%20(Red)%202016-PowerLoadTime
AW%20IMR18650%202200mAh%20(Red)%202016-TripCurrent
AW%20IMR18650%202200mAh%20(Red)%202016-Charge
Conclusion
The cell handles 20A fine, but the capacity is a bit low by todays standards.
Notes and links
The batteries was supplied by aw-akku.de for review.
Compare to 18650 and other batteries
MRsDNF
MRsDNF's picture
Last seen: 11 hours 58 min ago
Thanks HKJ. Thumbs Up
