Title: SeresRoad Mu08 Penlight Flashlight with Keychain
The SeresRoad Mu08 LED flashlight is designed for teenagers. It’s compact, lightweight to carry for daily using. It’s water resistant with skid and shock design.
Flashlight Specifications:
Brand: SeresRoad
Condition: Brand new
Uses Cree XPG-R5 LED
Material : Metal
Waterproof level: IPX8
Brightness: High - Mid - Low (When use a while it will turn into Middle or Low brightness, please don’t worry. Change new battery will recover original brightness.)
Item Weight: 17-Gram weight (excluding the battery).
Size: about 67mm(length)*15mm(body diameter).
Batteries: AAA batteries required. (included)
Tail tap switch for on/off and output selection
Made of Aircraft-grade Aluminum.
Premium Type 3 hard-anodized anti-abrasive finish
High- efficiency reflection lens.
Package contents:
Black SeresRoad Mu08 LED Flashlight(Included 2 AAA batteries, hat clip and keychain)
How do you change the modes on this flashlight?
The Middle rotate switch controls all the functions: Rotate the neck to turn change modes and turn on /off. Caused its rotary switch, please take the battery away as electrical treatment, in order to avoid battery drain or affect circuit board.
Quality guarantee, professional customer service!
If it was US$5 from Amazon, I would buy it to try but for $10 (which is 50% off, according to Amazon), I’d rather buy an Olight i3E for about $10-$15, which is a well known and respected brand with customer support that backs the product.
