Aspire 18350?
29 posts / 0 new
Gerrh
Last seen: 1 week 5 days ago
Aspire 18350?
Hello, I wanted to share some really nice batteries I found.
http://www.aspirecig.com/products/MOD/mod367.html
I don't know how they did it but Aspire squeezed 1300mah and 15Amps out of an 18350. I ordered some a week or so ago and they showed up just a few days later. I have not done extensive testing on them except capacity and they really are 1300mah. They rocked in my Astrolux S41 much longer than my AW or Efest 18350's. Just wanted to get something started on these and see where it goes. Will post more of my findings soon.
Edited by: Gerrh on 10/03/2016 - 02:44
start90a
start90a's picture
Last seen: 12 hours 53 min ago
News on this? I’ve just ordered one to compare next to an efest imr 700 mAh..
I found this aspire 18350 discharge curves from dampfakkus
EasyB
Last seen: 4 min 36 sec ago
Wow, impressive performance. It blows away any other 18350 cell in capacity, and it seems to have low IR comparable to other high drain 18350s.
Gerrh
They are amazing! I've been using them in series and they with quite well. They are a really nice upgrade for capacity over anything else I've found. They also do well under high amps.
Jerommel
Jerommel's picture
Last seen: 2 days 13 hours ago
If those specs are real, that would be very nice. Thumbs Up
edit:
It seems they’re hard to find…
Any suggestions on where to buy?
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
start90a
start90a's picture
They are available at Svapostore.net for about 3,7 € each.
Aspire 18350 1300mAh 18350
start90a
start90a's picture
Had just tested and result is Aspire has 60 % more capacity than Efest IMR 700..so above 1120 mAh.
maukka
maukka's picture
Last seen: 5 hours 51 min ago
Can you measure the dimensions of that Aspire. Sure looks bigger from that perspective.
start90a
start90a's picture
It’s the prospective, don’t worry about dimensions. They are the same!
Edit: added a new link of a capacity test by a user
Aspire 18350 amateur battery test
Agro
Last seen: 1 day 12 hours ago
€10 shipping.
https://www.nonsmokers.dk/en/batteries-32/18350-batteri-1300-mah-flad-to...
ships cheaper, but charges €9.37 per battery. Slightly cheaper when buying 2, but still expensive.
patmurris
patmurris's picture
Last seen: 3 hours 48 min ago
Quite a surprising jump in capacity! Shocked
I’m not far from Svapostore but the 10 euro shipping sort of kills the deal, even for four cells – 25 euro. I paid less for a set of four 30Qs i received today.
Still… why do i think i urgently need some? Facepalm
start90a
start90a's picture
i wrote to the store asking new shipping options but haven’t received an answer yet…
Jerommel
Jerommel's picture
I think i’ll send an email to NKON.nl
Would be sweet if they stocked some.
Agro
Barkuti
Barkuti's picture
Last seen: 30 min 52 sec ago
Look nice, but ≈1100mAh and a 7A max continuous rating would be far more accurate. Their internal resistance is not of high discharge class (voltage sag is ludicrous), worse than that of modest Sammie 26Fs, those single in class 26350s and or TrustFire IMR14500s (red-gold).
Cheers Party
patmurris
patmurris's picture
Still… at 1050 mAh and 7A this 18350 battery is more then welcome.
It’s been around since August 2016 – at least nine month, but it doesn’t seem to have drawn much attention… that’s odd, but that’s not a very popular size either.
Barkuti
Barkuti's picture
As I see in the graphs, they could deliver about 1036mAh down to 3V at 3A discharge rate. Two of these cells in series still can't match a top brand 18650 in performance, but with this improvement it can make sense to employ an LD-29 driver and enjoy a spectrum of fully regulated modes without PWM and the ability to “fully” utilize the cells. With such input, I bet the LD-29 could drive a standard emitter at 5A max (or close), with a nice mid of 1.5A and a 250mA low.
Oh! Yes, I like fully regulated drivers.
Cheers Party
Jerommel
Jerommel's picture
They would be very nice for many short lights up to 10 Watts.
patmurris
patmurris's picture
Why 10W? I’d guess they would do well in the A6 or S41 too?
Jerommel
Jerommel's picture
They’re not high discharge cells, so they would get hot and / or sag significantly with high currents.\
It’s a bit like the good old Panasonic 3400mAh 18650.
They are just not made for high current.
Lowtech
Last seen: 1 week 4 days ago
Seems Keeppower has some 1200mah 10A 18350s as well now.
And highdrain protected 18650s..
Listed under batterys on BG.
Barkuti
Barkuti's picture
Keeppower P1835C2? The Aspire (YDL) cell with a different wrap and a protection circuit, for sure.
Cheers Party
RollerBoySE
RollerBoySE's picture
Last seen: 5 hours 20 min ago
Cheers Party
and NOT shipping to Sweden.
Apparently it’s no longer enough to add a box… Sad
Barkuti
Barkuti's picture
Check here RollerBoySE: Aspire 18350 Battery sale
The instructions are clear, got a 4-pack for me everything tidy. Remember to send the payment as friend.
Cheers Party
RollerBoySE
Cheers Party
Thanks for the tip!
But I’ve already been using Aspire 18350 for a couple of months, got mine from Aspire in China.
My point was rather that BG apparently no longer have a way to ship Li-Ion to Sweden (adding a box is not enough anymore).
MattSPL
Last seen: 2 weeks 5 days ago
I got a couple here http://dreamcloud.ie/product/aspire-18350/
They are working great in my Emisar D4 Smile
Pete7874
Pete7874's picture
Last seen: 13 hours 2 min ago
TheAuditor
Last seen: 6 days 11 hours ago
Hi All,
I was just wondering what single RCR123 flashlights these can actually fit in? I have a Jetbeam RRT01 and a Manker E14II, and an Astrolux S42s on order, but are there any others people would recommend?
Thanks very much,
TA
Boaz
Boaz's picture
Last seen: 46 sec ago
Pete7874 wrote:
For those in the US, liionwholesale has them… https://liionwholesale.com/products/aspire-18350-battery-10a-15a-1100mah...
They were out a few days ago… but I just got some so they either got more or found some hiding in their warehouse . Smile
