Test/review of Shockli IMR26650 5200mAh (Black)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 44 min ago
DSC_6444
Official specifications:
  • Nominal Capacity: 5200mah (1A Discharge)
  • Nominal Voltage: 3.7V
  • Discharge Cut-off voltage: 2.6 V
  • Standard Charge: 1.0 A / 4.2V±0.05V (Recommend 1.0A-2.0A)
  • Maximum charge current: 4A
  • Continuous Discharge Current: 30A
  • MAX Discharge Current: 60A
  • Initial Impedance: <=20 mOhm
  • Cycle Life: 500 cycles to 60%
  • Size(mm): 26.2±0.2mm(Diameter) x 66.6±0.5 mm(Length)
  • Weight(g): 95±2g
  • Operating environment: Charging, 0°C ~ 45°C, Discharging, -20°C~60°C
  • Storage environment: Temp(-20°c -35°c) / Humidity (65±20%)
Shockli%20IMR26650%205200mAh%20(Black)-info
This is a high capacity and high current 26650 cell.
DSC_6443
DSC_6445DSC_6447
DSC_6448
DSC_6449
Shockli%20IMR26650%205200mAh%20(Black)-Capacity
The discharge curves tracks fine and the cell has nearly constant capacity up to 15A. At 20A one of the cells got too hot and I stopped the test.
Shockli%20IMR26650%205200mAh%20(Black)-Temp-15.0
Shockli%20IMR26650%205200mAh%20(Black)-Temp-20.0
The cells gets very hot at 20A.
Shockli%20IMR26650%205200mAh%20(Black)-Temp-30.0
At 30A they discharge before I measure the heat, but they get even hotter.
Shockli%20IMR26650%205200mAh%20(Black)-CapacityTimeHours
Shockli%20IMR26650%205200mAh%20(Black)-Energy
Shockli%20IMR26650%205200mAh%20(Black)-PowerLoadTime
Shockli%20IMR26650%205200mAh%20(Black)-TripCurrent
Shockli%20IMR26650%205200mAh%20(Black)-Charge
Conclusion
This battery has good capacity and can deliver a fairly high current, but the 30A/60A is too optimistic.
Notes and links
The battery was supplied by shockli.com for review.
Compare to 18650 and other batteries
sidecross
sidecross's picture
Last seen: 1 year 6 months ago
Thank you HKJ!
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
