Test/review of AW IMR18650 3000mAh (Red) 2016
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 45 min ago
DSC_5289
Official specifications:
  • Nominal capacity: 3000 mAh
  • Nominal Voltage: 3.7V
  • Lowest Discharge Voltage: 2.50V
  • Diameter: 18.00mm
  • Length: 65.00mm +/- 0.1mm
  • Max. discharge: 20A
  • Max charge rate: 1.5 to 4A
  • Lowest discharge rate: 2.5V
  • Working temperature: -20 to 60 Degree Celsius
AW%20IMR18650%203000mAh%20(Red)%202016-info
Batteries with both high capacity and high current ability from AW.
DSC_5288
DSC_5290 DSC_5291
DSC_5292
DSC_5293
AW%20IMR18650%203000mAh%20(Red)%202016-Capacity
The discharge curves tracks very nicely and capacity drops only a little with increase current, at least up to the rated 20A.
But why do one cell terminate on temperature and other do not?
AW%20IMR18650%203000mAh%20(Red)%202016-Temp-15.0
From this temperature chart the explanation is clear, I forgot to mount the temperature sensor on the A cell.
The battery gets rather warm at 15A
AW%20IMR18650%203000mAh%20(Red)%202016-Temp-20.0
AW%20IMR18650%203000mAh%20(Red)%202016-Temp-30.0
The cell without temperature sensor must have been very warm here. It was warm enough to get damaged!
AW%20IMR18650%203000mAh%20(Red)%202016-CapacityTimeHours
AW%20IMR18650%203000mAh%20(Red)%202016-Energy
AW%20IMR18650%203000mAh%20(Red)%202016-PowerLoadTime
The damage to the A cell is very obvious here.
AW%20IMR18650%203000mAh%20(Red)%202016-TripCurrent
And also on this curve. Due to this damage I had to cheat with the “internal resistance” value in the table, it is only for cell B, I did not use the value from the damaged cell.
AW%20IMR18650%203000mAh%20(Red)%202016-Charge
Conclusion
The batteries has good performance but watch out for the temperature at high current.
Notes and links
The batteries was supplied by aw-akku.de for review.
Compare to 18650 and other batteries
sidecross
sidecross's picture
Last seen: 2 years 5 months ago
Thank you again for the testing you provide.
I do hope the battery distributors would correctly label their batteries; this is not a true 20 amp battery. Until they do label them more truthfully your tests will remain very important.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
light-wolff
So what’s inside? Not 30Q or VTC6. HG2?
Tom E
Tom E's picture
Last seen: 1 hour 11 min ago
These track really close to the EFEST IMR 3000 Purple 2016 discharge curves, but lag in total capacity a little.
Definitely not as good as the VTC6, but nothing else is.
Bright_Mike
Where can you buy AW IMR in USA?
SpaceCowboy
It is LG HG2 battery
