Review: ThruNite TN42 LED Searchlight
109 posts / 0 new
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
*Disclaimer: TN42 provided for review courtesy of Thrunite.
This is it, folks... the reigning King of Throw in LED flashlights!
Manufacturer's Description:
Features
  • One of the most powerful throw LED lights on the market.
  • Uses one advanced CREE XHP35 HI LEDs with a lifespan of 20 years
  • The high output reaches 2000 lumens and an ultra-long distance of 1550 meters.
  • ThruNite ITC technology to prevents possible damage from overheating.
  • Reversed polarity protection system prevents damage to the light.
  • Intelligent and ergonomic user-friendly interface.
  • Only applicable for 18650 batteries to use.
Specifications:
  • LED: 1xCREE XHP35 HI LED with a lifespan of 20+ years of run time.
  • Runs on: 4 x 18650 (ThruNite 18650 3200Mah).
  • Working voltage: 5.5V-8.4V.
  • Output & Runtime (Tested with four pieces ThruNite Li-ion 18650 batteries (3.6V/3400mAh) and for CW. NW parameters is 10% off):
    • Strobe(680 lumens /10.8hrs),
    • Turbo(2000 lumens/1.5hrs),
    • High(780 lumens /5.3hrs),
    • Medium(256 lumens /17.8hrs),
    • Low(38 lumens /4.3days),
    • Firefly (0.8 lumens /58days).
  • Peak beam intensity: 600750cd.
  • Max beam distance: 1550m.
  • Waterproof to IPX-8 Standard (2 meters).
  • Impact resistant: 1.0 meter.
  • Working Temperature: -40℃-40℃.
  • Dimensions: 206mm (length) x 100mm x 52mm.
  • Weight: 666g (including battery carrier).
  • Accessories: Shoulder strap*1, Strap ring*1, A, Spare O-ring*2, Side switch Cap*1, Battery Carrier x1 (inside the flashlight).
THE QUICK AND DIRTY
There you go.  3000 words in 6 seconds. $199 USD gets you over 700kcd.  You like throw? BUY IT!
THE LONG AND DIRTY
What?  That wasn't enough to convince you how awesome the new LED king of throw is?  OK...fair enough.  Read on.  I thought about making everything above this paragraph my entire review but I took a lot of pictures and spent too much time testing, editing, uploading, and writing to just throw away all the effort.  So here are the particulars, starting with what everyone really wants to know, how bright is it and how far will it throw?
PERFORMANCE & UI
Here are the particulars.  I take my OTF lumen measurements using a calibrated Integrating Sphere.  Lux is measured at 8.9m distance and 30 seconds of "on" time and converted back to 1m.  Throw distance is calculated as distance until output reaches to 0.25 lumens (ANSI standard).  Batteries used in testing are Samsung 30Q INR 18650 high drain 20A cells.  Cells at full charge of 4.2V.
To measure a light like this it is imperative that lux be measured from more than 7m away due to the convergence point of the beam which is several meters away.  Taking measurements any closer than that will definitely result in inaccurate readings since the beam won't even be focused at closer ranges.  This is why I measure at 8.9m distance and almost feel I should go back further for this crazy light but I'm confident that my readings, for my sample, are accurate.
You can see the insane numbers this light returns (728kcd!!!), especially for throw (1.7km!!!).  How does it look in the real world?  Let's take a look and see.  With claims of 1550m of throw, I needed a place to take beam shots that was as close to 1.5km as I could find.  The best I could do is 1.2km and this worked out great because it is far enough to show how insanely brilliant this light is as well as one or two other lights to have a chance to show their reach.  I don't have as many dedicated throwers as some other flashlight collectors but I'm working on it. The only lights I have that I know for a fact that could reach 1.2km are my TN40 (quad XP-L HI) and the TN42 (XHP35 HI).  I also brought along my Fenix TK61 and ThruNite TN32 to see if they even stood a chance of hitting that far.
Click for larger 1024px image
The TK61 and TN32 don't really hit it at all to my eye.  I believe the TN32 may barely touch it but not enough to say it does.  The TN40, with it's huge 100mm head and quad XP-L HI emitters hammers the entire building with a huge swath of light.  In my testing the big quad can hit over 1300m so it's no surprise to me that it hits at 1.2km.  The TN42 lights just a small section of the big building even more with it's focused beam.  I thought the TN40 was king of throw, or at least equal to other renowned competitors such as the Acebeam K70, until I got the TN42.  This baby THROWS!  Imagine... Over 728kcd and 1.7km of throw!  Based on how well it lights the tower at over 1200 meters, I have no doubt that it can truly reach 1.7km.  With custom modders getting around 3000 lumens form the Cree XHP35 HI emitter, there should be room for modders to increase the output even more and get even better throw.  This light is stunning.  Bravo, ThruNite!
^ You can see in the gif above just how focused this beam is.
USER INTERFACE
The TN42 uses the same UI as all the newer models they make that have electronic switching.  The only oddity in the mode switching that is different from other brands with similar UI is that whenever you press and hold to change modes starting in Medium mode, the light will switch to Low, then Medium, then high, then loop back to Low.  If you change modes while starting in High mode nothing will seem odd.  If you are in Low mode to start it will switch to Medium then High - nothing odd here either.  It's only odd if you start in Medium: the light will drop to Low, then back to medium and then to High.
This is different from pretty much every other light where modes cycle starting with the mode above the one you are in., For example, if you are in Medium and press and hold to change modes, most other lights will go to High, then loop to Low, then go to medium, and so on.  On the ThruNites, if you are in Medium and press and hold to change modes, the light will always shift to Low, then to Medium, then to High.
If you aren't used to this it feels very odd but there is a bright side to it and I now believe I understand the thinking behind it, at least why it makes sense in my opinion - it protects your night vision.  If you start from Low it goes to medium an up no issue, as one would expect. What if you are in Medium and want to back down to Low?  Instead of having to cycle past High before getting to Low, like in most every other light with press and hold UI, it drops back into Low first, thereby preventing you from damaging your night vision.  If you wanted to get to high from medium, there is only a brief amount of extra time needed to cycle through and reach High.  To me, I would rather take an extra second to reach high than flash my eyes when I don't want High but want Low instead.  Personally I would like it best if every light, including this one, utilized short, medium, and long presses to navigate both forward and backwards through the modes.  Click to go up in modes, medium press to go backwards in modes, and long presses, double-clicks and triple-clicks for special functions.
Either way, the TN42 UI functions perfectly well, it's just that it may throw you off the first few times you change modes from Medium and it drops to Low before going to Medium then High instead of going directly to High mode.
  • Turn On/Off
    • Press the side switch to turn the light on/off.
  • Change Mode
    • When the light is on, long press the side switch to cycle through low, medium and high.
    • Shortcut to firefly: When the light is off, long press the side switch to get firefly mode.
    • Double click to turn to turbo from any mode. Another double click to get strobe.
  • ITC Technology
    • The light will automatically lower the current when temperature in LED or driver rises to 80 degrees centigrade to protect the flashlight from overheating. Thus to extend its lifespan.
  • Memory Function
    • The light will turn on in the last mode accessed, except firefly, turbo and strobe.
  • Low Voltage Indication
    • When the indicating light on the side switch turns from blue to red, it means the battery package should be replaced or charged.
  • Battery Replacement:
    • Take off the tail cap, insert four 18650 batteries into the battery carrier, put the carrier into the flashlight and screw on the tail cap. With either end of the battery carrier towards the light head is OK. But make sure the batteries are correctly inserted into the carrier with polarities matched (springs on the carrier should connect with the cathodes of batteries).
DETAILS & CLOSEUPS
Onto what is actually my favorite part of a review - seeing close-up details you won't ever see unless it's in your hands, or by reading my reviews.  Smile
^ The TN42 and TN42C are shipped in the same sturdy cardboard box
^ Inside the box is a fitted foam liner holding the light, Accessory bag, User Manual, shoulder strap, and "Thank You" card.  The large cutout in the back-right corner is where the charger for the TN42C (rechargeable version) would be.
^ Nice, simple User Manual tells you everything you need to know about the operation of the light.
^ With the non-rechargeable TN42 this is all you get, but all you need.  A couple of spare O-rings, a sturdy, flat split-ring for attaching the shoulder strap to the tail of the light, a replacement inner switch seal, and the shoulder strap in lieu of a holster.
^ With the TN42 out of it's box the first thing that strikes you is the humongous head with that smooth, deep reflector.
^ Way down in the reflector well is a Cree XHP35 HI emitter.
^ The emitter is perfectly focused for long range throw.  The LED is perfectly centered.
^ Here is a little shot with the LED in Moon low.  You can see the double-sided AR coating on the inside in this photograph.  I usually like to get a photo taken head on with throwers (and most of my reflectored lights) where the reflection of the LED makes the entire reflector appear yellow like the LED itself.  I couldn't do that with this light because the focus point for the beam is so far out that to get it all yellow I would be too far from the light to really see anything.  I certainly was unable to get the shot in my kitchen due to limited space.  This is the first time I've ever had this happen.  3 or 4 feet is usually all one needs to get a full LED reflection.
^ The beam from the TN42 is almost artwork in my opinion.  This shot was taken with the TN42 perfectly level with the surface it was on and the beam is so tight and focused that the center of the beam isn't even touching the surface it was on.  This creates a beam profile that looks to be the smoothest, creamiest spill I've ever seen on any light.  Usually I take this pic and it allows me to overlay a protractor image to get the beam angles in degrees.  Not even possible with this light as it is so damned focused and tight.  Amazing to me!
^ When the TN42 is powered on, the LED in the center of the switch glows blue (looks turquoise in this photo).  As the cells drain the LED charge indicator changes to red when it's time to charge or swap the four 18650 cells.
^ The head of the TN42 is so big that there is tons of surface area for heat dissipation.  Around the driver and emitter section of the light, where the switch is, there are a few deep, wide fins cut into it for further heat management.  The flat, raised shelf the switch is located on makes it really easy to find the switch in the dark just by feel.  No mistaking or doubt when locating by feel.
The knurling behind the switch allows great grip of the head while unscrewing the battery tube to swap or charge cells.
^ The knurling, like every other big ThruNite light I have, is exceptional.  Tons of grip for a secure, comfortable hold.
^ The tail itself is just like that of the TN40.  The 3 wide crenellations offer a stabile platform on uneven surfaces (think tripod) and the large, chamfered lanyard holes easily accommodate 550 Paracord with absolutely no sharp edges to cut your lanyard.
^ Here is where you would install the included split-ring for the shoulder strap but you can also clip the end of the shoulder strap directly into one of the holes without using the split-ring.
^ To swap cells, the battery tube unscrews from behind the 3-piece head.  The TN42 uses a cartridge style battery holder.
^ On the head of the TN42, the anode contact is a huge, stiffly sprung, brass button.
^ Threads where the battery tube join the head are perfectly machined and square.  The thick O-ring is perfectly sized for a real tight seal.  O-ring and threads came perfectly prelubed from the factory.
^ With the battery cartridge removed, this is what the inside of the battery tube looks like.  The inner surface is perfectly smooth just like the exterior of the light.  No shortcuts in machining were taken to save time.  Anodizing on the TN42 is also exceptional with no missed or thin spots and no uneven coloring.  Just beautiful throughout.
^ The battery cartridge is well made and very sturdy.  It allows for insertion into the light in either direction.  Batteries, however, must be inserted into the cartridge in the correct directions.  Raised contacts allow the use of flat or button topped cells.  Very stiff and thick cathode springs are just long enough to use about any cells you want to use although I feel you will want to use only high-drain cells.  Cells are arranged in a 2S2P format for 8.4v output.
^ I used Samsung 30Q flat-topped cells.  There is just enough tension with these 65mm long cells and plenty of room for longer cells.
DECONSTRUCTION
Time to take a look at the internals as far as I can without unsoldering things.
^ The contact/retaining plate for the driver is a very thick slab of anodized aluminum with a broad, machined contact ring for negative current.  A plastic isolator ring is pressed snugly into the center of the contact plate to insulate the positive current from the thick brass anode contact button in the center.  Removing the three screws in the plate allow access to the driver itself.
^ The driver is sandwiched between the pill section and retaining plate.
^ The center anode spring is very thick and stiff.  ThruNite performs a factory spring bypass for as little resistance possible and maximum current throughput.
^ All the larger components on the back of the driver are potted for extra impact resistance.  This driver boosts the voltage from the battery pack to power the XHP35 HI emitter which is a 12V emitter.  Modders will be happy to see what look to me to be a bank of four sense resistors that could probably be changed to increase output beyond the factory 2000 lumens.  It goes without saying but doing so will definitely void your warranty.  Some folks I know won't be deterred from seeing how much they can wring from the boost driver.
^ With the driver lifted out of the way we see the one-piece pill and emitter shelf.  Very thick leads provide current to the LED itself and a ribbon cable leads to the electronic switch.
^ The head of the light consists of 4 main pieces: main light engine section, upper head section, bezel (with lens and O-ring), and reflector.
^ Fine, square threads in the bezel are very smooth.  All components of the head thread super smoothly and seal very tightly.
^ A close look at the square threads of the upper head section where the bezel attaches.  Everything came prelubed and the O-ring is perfectly sized for snug, tight fit.
^ The upper head section attaches to the main driver section here with more perfectly machined, square threads.  Again, everything is prelubed and the O-ring seals perfectly.
^ Looking into the light engine, we see a square, copper, DTP emitter board (MCPCB) that is mounted to the main emitter shelf with screws.  The MCPCB has thermal grease under it for better heat dissipation. A large, nylon centering ring/insulator fits over the XHP35 HI emitter and centers the big reflector perfectly.
^ Leads to the LED are fairly thick and soldered perfectly.  The big reflector is so deep that the switch sits inside the reflector cup area in the head.
^ A shot of the undomed LED in Moon low.
^ The aluminum reflector in the TN42 is gorgeous.  The depth of the emitter is 84mm to the broad, flat opening.  This broad opening allows the LED to sit deep into the reflector for perfect focus.
^ Inside diameter of the reflector well is roughly 90mm.
^ Outer diameter of the reflector is just under 93mm.
^ The double-sided AR coated lens is 94.24mm*2.5mm
^ Outer diameter of the head itself is a beefy 100mm.
SIZE COMPARISONS
Here is the TN42 shown next to a couple of other ThruNite mega-throwers.  On the far left is the TN42 with quad XP-L HI emitters that throw a broad swath of light easily past 1300m.  Farther than most dedicated single LED throwers.  In the middle is the TN42.  The TN40 and TN42 share the same head diameter and the same battery tube.  On the far right is the TN32.  ThruNite's classic mega-thrower that may be aging but still holds up against many of today's throwers.
^ Even though the TN40 and TN42 have the same head O.D., the TN40 with it's big quad reflector looks larger in this pic.  The TN32 with it's big 79mm head looks absolutely diminutive next to the big TN42.
^ From this angle you can get an idea of the different reflector depths.
^ The odd shoulder strap clip makes instant sense once you see how it hooks into the head of the light with a solid, secure connection.  The lobster claw clip on the other end of the strap can be attached directly into one of the lanyard holes in the tail cap if you don't feel like attaching the stiff split-ring between the two.
^ The TN42 is a big light, no doubt, but it doesn't feel that big in the hand.  The huge head does not create a front heavy feel like one might expect.  The majority of mass is in the battery tube which sits behind my index finger.
CONCLUSION
As you can readily see, this is a superbly built machine.  It's the flashlight equivalent of a .50cal sniper rifle.  If you need a light to reach out and touch something far, far away, this is the one to have.  At $199.95 for the TN42 (as I have here) and $259.95 for the TN42C with rechargeable battery pack and charger, it's competitively priced for a light of this class and capability.  I LOVE it!  I recommend it without any reservations.  Need another reminder of just what a light it is?  Here you go:
Edited by: JohnnyMac on 10/14/2016 - 15:45
MRsDNF
MRsDNF's picture
Last seen: 2 days 10 hours ago
What more can be said but WOW. Thanks for the review JM. Thumbs Up
southland
southland's picture
Last seen: 1 week 6 days ago
Great review, love the XPH35 in throwers.
DBSAR
DBSAR's picture
Last seen: 13 hours 29 min ago
Great review! Smile
gaston01
gaston01's picture
Last seen: 4 months 16 hours ago
Excellent review and images Shocked I wanted very much to see inside Evil
An incredible flashlight, I see my dreams come true Shocked
Many thanks
Sorry for my bad English…
JohnnyMac
JohnnyMac's picture
Thanks for the kind words, guys. Yeah, this light knocked my socks off and exceeded all my expectations from it.
NikolaS
NikolaS's picture
Last seen: 2 months 3 days ago
Ohhh man great review, that sense resistors got my intention right away. 1 mile is down, let’s go 2 km Big Smile
Tom E
Tom E's picture
Last seen: 6 hours 11 min ago
Nice review!
I clicked on the driver pic and see a 5R1 resistor, 5.1 ohms, so that seems like a current limiting/sensing guy. Could be experimented with.
But there's also that huge 47R0, that's 47 ohms, and has that beefy jumper. Appears to be a true current limiting resistor, supporting the full power path. Interesting, also might be worth while experimenting with. I like what they did with the spring bypasses - same way I do them.
leaftye
Last seen: 2 weeks 3 days ago
That handle _looks _way too small. I wish I could justify a pencil beam thrower this expensive, but I’ll be waiting and hoping that someday they blow it out at $90 like they did with the TN31’s.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
JohnnyMac
JohnnyMac's picture
You may wait quite a while for that to happen. The TN31 dropped in price because the TN32 then TN32UT came out rendering it obsolete. I’m guessing this will be top of the heap for some while. Also, not sure how big your hands are but mine are fairly large. Lots of lights look small when I hold them.
Sirius9
Sirius9's picture
Last seen: 6 days 21 hours ago
Crying great, now I need one, anyone needs a kidney Big Smile Thumbs Up for review
leaftye
Yep, I remember why, and I have no reason to buy a light like this right now, so I can wait for another generation. I was referring to the relationship of head to handle making it look like a stubby.
blueb8llz
Last seen: 58 min 18 sec ago
thank you and great review. for some reason, in the comparison pictures, the tn40 doesnt seem far behind the tn42. it may even look the same and the tn40 being even more powerful because the whole building is lit up.
i would have thought the extra 300kcd the tn42 has over the tn40 would be more noticeable.
JohnnyMac
JohnnyMac's picture
I thought the same at first but I think it’s because the TN40 lights the entire building. You have to remember that the TN40 is hammering 4700 lumens down range compared to 1965 from the TN42. If you block everything else out and focus only on the same area of the building as lit by the TN42 I find the TN42 is definitely brighter. The TN40 is a monster thrower in its own right and can match just about any other production thrower on the market. The TN42 simply steps it up another notch or two. If you already own a TN40 then you might not need a TN42.
lightx
Last seen: 3 years 2 months ago
Man, this thing is crazy!!
Stockton-Rob
Stockton-Rob's picture
Last seen: 1 month 4 weeks ago
Hiya!
I’ve ordered one directly from Thrunite.
My manparts twitch if there’s a knock at the door in case it’s the courier, I can’t wait to get my hands on it. I live on the northern edge of the North Yorkshire Moors (in the UK to our brothers and sisters across the pond) and there are some areas that are completely devoid of ambient light pollution, put it this way, an old Jacob A60 (direct drive) and a Convoy L2 (also direct drive after the driver blew) in these areas of the moors threw a ridiculous distance (I don’t have any figures on these hand cannons…..sorry) so I can imagine the throw the TN42 will produce in the same area!!
The waiting is killing me and the twitching is unpleasant now!
All the best,
Stockton Rob
PS: Any tips on a good battery set?
and the lord did utter….‘let there be light’……..and CREE said ‘how much?’
JohnnyMac
JohnnyMac's picture
Stockton-Rob wrote:
Hiya!
My manparts twitch if there’s a knock at the door in case it’s the courier, I can’t wait to get my hands on it. I live on the northern edge of the North Yorkshire Moors (in the UK to our brothers and sister across the pond) and there are some areas that are completely devoid of ambient light pollution, put it this way, an old Jacob A60 (direct drive) and a Convoy L2 (also direct drive after the driver blew) in these areas of the moors threw a ridiculous distance (I don’t have and figures on these hand cannons…..sorry) so I can imagine the throw the TN42 will produce in the same area!!
All the best,
Stockton Rob
That’s awesome, Rob! Just remember that the evening I took those beamshots it was almost a full moon with lots of ambient light after the treeline where the high rise building was. I can’t imagine in a place like you have! Be sure to take beam shots. Smile For batteries I’m a Samsung 25R/30Q guy (have lots of 25R but switching to 30Q with new ones). Right now it’s hard to beat a reliable 20A cell.
Sirius9
Sirius9's picture
OP used Samsung INR18650-30Q, can’t go wrong with them or something like LG HG2…
hank
hank's picture
Last seen: 2 hours 41 min ago
Wow.
I know it’s an illusion, but in that first set of pictures, it really seems to be making the Moon shine brighter ….
Stockton-Rob
hank wrote:
Wow.
Now THAT is throw…….
M4D M4X
M4D M4X's picture
Last seen: 5 hours 13 min ago
great Review again!
thanks for your work!
( i hope HKE stocks the NW soon Sad )
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Rusty Joe
Rusty Joe's picture
Last seen: 5 days 6 hours ago
Amazing even by the highest of amazing standards!
Do you know if you’d get constant-current regulation with the 18650s as opposed to the rechargeable battery pack from Thrunite?
will34
will34's picture
Excellent review!
I don’t think this light can be further improved in anyway, it’s simply flawless even in the eyes of an modder. Maybe a small current bump, but the performance in stock form is just insane. Really want to get rid of my K70 now. Big Smile
Stockton-Rob
Good news…..well I think it’s good news!
My TN42 has been dispatched…..by Amazon!!
It appears Thrunite have used Amazon as a ‘dropship’….is this good or indeed…bad?
Cheers
Rob
Maiden666
Almost In Europe Thrunite send the flashlight by means of Amazon.
hank
hank's picture
Look carefully at what you get from Amazon, make sure it’s what you thought you were getting
because they commingle inventory — trusting the label, no matter what the source, to be accurate — from all sources.
So the warehouse picks the next thing out of the bin for your order, regardless of who you think you’re actually buying it from.
That has let a lot of counterfeits be sold through there in the past few years and they’re getting a lot of attention about this practice.
https://www.google.com/search?q=amazon+commingled+inventory+wsj
Maiden666
Thumbs Up
I´ve buyed in Thrunite Store.
When i claim thrunite that ship the flashlight fast to make a review in spanish flashlight forum, the Thrunite explain to me the they use the logistics of Amazon.
(Thrunite have a store in Amazon Europe).
Stockton-Rob
hank wrote:
Look carefully at what you get from Amazon, make sure it’s what you thought you were getting because they commingle inventory — trusting the label, no matter what the source, to be accurate — from all sources. So the warehouse picks the next thing out of the bin for your order, regardless of who you think you’re actually buying it from. That has let a lot of counterfeits be sold through there in the past few years and they’re getting a lot of attention about this practice. https://www.google.com/search?q=amazon+commingled+inventory+wsj
Great!!!
How will I be able to verify if my purchase is genuine???
It’s probably arriving tomorrow!
dw911
Last seen: 2 months 4 weeks ago
Thanks for the heads up, I’ve recently bought another torch direct from thrunite, I was surprised when a package from amazon turned up, anyway it was the thrunite torch I ordered.
Now the same exact model I bought a while back didn’t come via amazon it was sent by thrunite.
Anyway the one from amazon was a bit of a let down, horrible tint and not quite the same quality as the first.
Was disappointed and just sort of put it to one side and thought o well I’ll just mod it one day.
But now after reading what you put and looking at the link, I’m wondering if it’s a clone/fake
Stockton-Rob
F**king great!!
£150 I’ve paid!
EDIT:
Well mine arrived today……..OH MY GOD it’s bright!!
Can’t determine if it’s genuine or not. I’ve emailed Thrunite to ask them if there’s anything I can do to determine it’s authenticity!! But fake or not it’s ridiculously bright.
I can’t wait for total darkness to arrive!
Cheers
Rob
wolfdog1226
wolfdog1226's picture
Last seen: 9 months 3 weeks ago
^^^^ Glad you like it.
Does it have a serial number on it?? Thrunite should be able to verify it if it does.
I will have mine in a few weeks,TN42vn.
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
