Switch problems on DIV08
Hello,
on my last dive I had problem on turning my DIV08 on. Fortunately after some fiddling I got light and could do the dive without going to my backup light.
Unless my memory is doing tricks, I’m sure I’ve seen somewhere about DIV08 switch problems and a cure for it. But for the life of me I can’t find anything about it. Is it my googlefu or my memory letting me down?
Hi, do you know If the magnet is the problem?
I found this video online which might help
Hi, yes the switch was the problem. Brinyte is sending me a new switch.
I had the older body with the old switch assembly. Brinyte sent me the newer switch assembly and it works perfectly. I had to dremel some grooves to the old switch assembly to get it out.
