10440 High capacity and quality
12 posts / 0 new
fran82
Hi friends, where can I get 10440 batteries with the highest REAL capacity?
I dont want Chinese ones (xxxxFire) with a real capacity of about 300mAh
Thanks
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Don
Don's picture
Last seen: 3 years 5 months ago
The only alternative one Google came up with was this one.
http://www.batteryspace.com/li-ion10440cylindralcellaaasize37v300mahlc-1...
Only two manufacturers show up in a directory
http://www.ecplaza.net/search/0s1nf20sell/icr10440.html
There may be others but the cells are likely to be extremely expensive or have an enormous minimum order. Or both
And i doubt that much over 300mAh is actually available till the technology improves.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
fran82
And there are not IMR 10440 cells?
Don
Don's picture
Not to my knowledge. And they would almost certainly be lower capacity. Most lithium cobalt cells grossly overstate their capacity.
fran82
OK, thanks, then the better is to get the chinese ones xxxxFire for about 4 - 5 dollars a pack of 2?
how2
Last seen: 1 day 1 hour ago
fran82
Try these you set 4 for $6.02 . If you do get it tell us the real capacity.
http://www.lightake.com/detail.do/sku.TrustFire_10440_900mAh_3.7V_AAA_Re...
Don't forget to use flashlight coupon then you'll get it for $5.72
fran82
Yes I knew about those batts and the 5% discount
However those are the unprotected version of the TrustFire gray protected that sells DX at 5,08 in a pack of 2.
The real capacity is 287mAh under 700mA load.
agenthex
agenthex's picture
Last seen: 6 years 11 months ago
You're not going to get much more than 300mah. AAA are 1/3 of a AA. So, pointless to look unless you start seeing >1000mzh AA's.
Reading this makes you smarter: http://lesswrong.com/
anduril
Last seen: 3 years 4 months ago
From lightake.com:
TrustFire 10440 900mAh 3.7V AAA Rechargeable Battery Specifications
Brand/Battery type: TrustFire 10440
Capacity: 600mAh
Laughing
Photo shows 600mAh.
fran82
Yes I already purchased them, I am waiting they arrive at home (must arrive this week or the next)
And they are the same as the gray protected ones but without protection circuit.....600mAh declared, 300mAh in real
anduril
You mean... 900 mAh declared?
anduril
I ordered the same four-pack from Buyincoins just because it was cheaper with all the discounts.
http://www.buyincoins.com/trustfire-10440-aaa-3-7v-600mah-rechargeable-l...
Planning to use them in my new iTP A3s (which I hope will arrive soon).
