Test/review of TLife 18650A Protected 2200mAh (Green)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 59 min ago
Button top and flat top protected TLife 2200mAh cells.
TLife 18650A BT Protected 2200mAh (Green)
DSC_6550
Official specifications:
  • Model: 18650A
  • Battery Type: Lithium-ion
  • Rechargeable: Yes
  • Protected: Yes
  • Positive terminal style: Button-top
  • Nominal voltage: 3.7V
  • Discharge end voltage: 2.75V
  • Charging voltage: 4.20 +/- 0.03 V
  • Standard charging current: 1.625 A
  • Nominal capacity: 2200mAh
  • Rated capacity (minimum): 2100mAh
  • Dimensions: (2.77 × 0.72)” / (7.04 × 1.84)cm (L x Dia.)
  • Color: Green
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-info
This is a low capacity, low current cell. Tmart has this cell in four configurations, this is the protected button top.
DSC_6549
DSC_6551 DSC_6552
DSC_6553
DSC_6554
DSC_6555
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Capacity
The protection limits the current from this cell to less than 3A, the curves looks good enough.
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Temp-2.0
With this low current there are absolutely no temperature problems.
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Temp-3.0
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-CapacityTimeHours
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Energy
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-PowerLoadTime
Due to the low protection threshold the battery cannot drive a 10W light.
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-TripCurrent
TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Charge
TLife 18650A FT Protected 2200mAh (Green)
DSC_6536
  • Model: 18650A
  • Rechargeable: Yes
  • Protected: Yes
  • Positive terminal style: flattop
  • Dimensions: (2.73 × 0.72)” / (6.94 × 1.84)cm (L x Dia.)
  • Color: Green
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-info
This is a low capacity, low current cell. Tmart has this cell in four configurations, this is the protected flat top.
DSC_6535
DSC_6537 DSC_6538
DSC_6539
DSC_6540
DSC_6541
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Capacity
Something is wrong here, a 2500mAh battery has sneaked into the 2200mAh collection of 2200mAh batteries. This makes me doubt the quality control.
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Temp-2.0
Both types of batteries handles stays cool.
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Temp-3.0
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-CapacityTimeHours
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Energy
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-PowerLoadTime
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-TripCurrent
TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Charge
Conclusion
Due to the low protection threshold these cells are not for 1000 lumen flashlights, but only for equipment with a very moderate current consumption.
Generally these batteries has looked acceptable, but the 2500mAh cell is strange.
Notes and links
The batteries was supplied by TMart.com for a review.
Compare to 18650 and other batteries
MRsDNF
MRsDNF's picture
Last seen: 1 hour 1 min ago
Buy one cell and get a bonus 300mAh’s in the next batter. Facepalm
Thanks for the review HKJ.
DavidEF
DavidEF's picture
Last seen: 5 days 8 hours ago
Well, not useful to me. Thanks for doing the testing, HKJ! I had been curious about these after seeing them featured in some adverts! Now I know: AVOID!
Okay, well, I’ll still avoid, just because I’ve already got dozens of laptop pulls that probably will perform at least as well as these – or better! Wink
- The YKK Philosophy
