Test/review of Staring IMR18650 2500mAh (Green)
Official specifications:
  • Battery type: 18650 battery
  • Typical capacity: 2500mAh (real capacity)
  • Typical voltage: 3.7V
  • Voltage range: 4.2V~2.75V
  • Battery demensions: 18.23(D)*65.11(L)mm
  • Unit weight: 50g
  • Capacity density: 457Wh/L
  • Specific energy: 180Wh/Kg
  • Standred charging current: 1.1A (0.5C)
  • Standred discharge current: 1.1A (0.5C)
  • Max discharge current: 4.4A (2.0C)
  • Cycle life: 500T
  • Tempreture: –20°c~60°c
  • Certifications: CE, RoHS, UL
This is high current 18650 with fairly high capacity.
The discharge curves tracks just about perfect and the batteries works well up to 20A, at 30A they are strained.
They gets fairly hot at 20A, but it is in the acceptable range.
At 30A I would have terminated on temperature if the discharge had lasted a few second more, i.e. they are too hot.
Conclusion
The cells has very good performance up to 20A continuous.
Notes and links
The batteries was supplied by Staring for a review.
Compare to 18650 and other batteries
