Convoy L2/L6 modding thread
972 posts / 0 new
Etex
Etex's picture
Last seen: 1 year 11 months ago
JasonWW thank you for sharing the above, wish I had known about the little notches in the side switch mounting hole trick (Kawiboy). Will do that on the next one.
DB Custom
DB Custom's picture
Last seen: 6 hours 59 min ago
Jason, did you put power to the 2 SMD LED’s in Series or in Parallel? Reason I ask is because those are 3V LED’s and the power supply is 8.4V on a fresh pair of cells, so either you ran them in series or the power supply point you found on the driver is a 3V output side supply point. Is that supply point from the Inductor (silver box like component) actually 3V? Think I’m seeing what you did there, makes for a nice and easily sourced lighted side switch without a lot of hassle.
At first I didn’t see why the two slots then I figured out it lets you feed the switch board from the inside, completely wired up.
Thinking slow these days… just looking to confirm I’m seeing it right. Wink
JasonWW
JasonWW's picture
Last seen: 16 min 30 sec ago
XXX-Man wrote:
What size led’s go on switch?
And where I can get transparent cover for it?
The clear switch covers are from Convoy. Simon uses them on the clear version of the L6. He will send you some only for the cost of shipping (a couple dollars) or if you buy something he can add them to the order for free.
The LEDs I got from DBCustom. I’m pretty sure they are sized 0805/2012. They are cheap if ordered from china. EBay has lots of them.
At first I thought 1206 leds would fit, but as you can see, they are a little big for the switch pads.
Click this to go to signature links.
JasonWW
JasonWW's picture
Yep, the notches are just to slip the switch PCB through. It would be nice if Simon designed the L6 with notches, but a small round file does the job pretty easy. The top and bottom of the ridge get really thin so that’s the best spot to file.
If you look at the pictures you can see where I bridged the 2 pads on the back of the switch with a small metal wire and ran a single wire to them.
The negative side of both leds connect to the blue negative wire on the pcb. The switch was designed with 4 pads on the back. One positive wire for the switch and one positive for each led. That way you can use 2 different color leds like for battery voltage, USB recharge indicator, etc… All 3 positive wires share the one negative wire.
The positive voltage source on that metal can is battery voltage, so 8 volts roughly. If I had added 1 led I could have used a 5k to 10k resistor to drop down the voltage. Since I added 2 leds, for better light distribution, a 10k to 20k seems to work well.
I dont think it’s possible to run the 2 leds in series since they share a common ground.
I plan to tidy this up and reduce the chances of a short by using a tiny smd resistor now that I know what value to use. I’ll look through some old circuit boards to salvage one.
I plan to pull this current driver out soon to put in my Tx Avenger FET driver from Lexel when it arrives. It will also have a lighted side switch when the tail switch is turned on.
I’m gonna put this current driver (detuned to maybe 4 or 5 amps) in a little Supfire L5-S. It uses a 29mm driver, a clear momentary side switch and a clicky tail switch. Add some 26350 batteries, some copper spacers, shorten the reflector depth, add an xhp70 and you have a mini version of the L6! Lol
XXX-Man
XXX-Man's picture
Last seen: 4 hours 25 min ago
Thank you JasonWW Thumbs Up
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
DB Custom
DB Custom's picture
I looked at doing this lighted switch design on my Black L6, but it’s got an FET driver and I wasn’t sure where to draw power… figured the switch wire was coming from the MCU which had a regulated voltage of >5.5V due to the Zener mod, but couldn’t get it to work… might have something to do with my pain meds, don’t know. Wink I have LED’s on the board, will look into it later.
Texas_Ace
Texas_Ace's picture
Last seen: 9 hours 45 min ago
If you run an inline resistor you can run the switch LED’s off the full voltage no problem.
JasonWW
JasonWW's picture
I took the driver out and used magnets to hold the batteries together and to hold the negative wire to the battery. Then I pressed the driver spring up against the battery positive. It was pretty tricky to do. Then I could use my multimeter to find a constant source of positive power on the top of the driver.
JasonWW
JasonWW's picture
He’s gotta find full voltage first. He’s got a zener modded MTN17DD driver.
Texas_Ace
Texas_Ace's picture
For the full voltage simply connect to the V+ from the main LED and then to ground via a resistor. Lots of grounds you can use from the input to the FET or the ground ring, OTC ground, C1 ground ect.
DB Custom
DB Custom's picture
Built hundreds of FET drivers, pretty much know the drill there. Just not used to using these tiny SMD LED’s. Nor am I used to doing the mods so heavily drugged. Sick Probably shouldn’t, have burned myself a few times lately. Left hand and arm are totally out of whack.
DB Custom
DB Custom's picture
Jason, the package those LED’s came in identifies them as SMD SMT 080. Hope that helps. I got 8 colors, 20 in each tape, for like $8 and some change on ebay.
Texas_Ace
Texas_Ace's picture
they are most likely 0805 LED’s. These are cheap and easy to get on ebay. You can get 100 of them for like $2.
I have hundreds laying around for building lighted tailcaps.
JasonWW
JasonWW's picture
That would only light the side switch when the main beam is on (and not needed then), but not when the light is in standby mode.
My whole reason for wanting the lighted side switch is so I would know whether the rear tail switch is on or off. It also helps to locate the switch in the dark instead of having to feel for it.
Texas_Ace
Texas_Ace's picture
By connecting the side switch LED to the main led V+ and then to the ground ring via a resistor (most likely between 25-50k), the LED will be on anytime power is applied to the driver. The V+ is connected directly to the battery and so in the ground ring.
JasonWW
JasonWW's picture
Okay, so there is always battery positive going to the emitter and it’s the negative wire from the emitter that the driver controls/manipulates?
Is that how all drivers work or do some control the positive wire going to the emitter?
I’m still not sure how power flows through a driver.
Texas_Ace
Texas_Ace's picture
In all the FET based drivers we use the positive is always connected, we only control the ground. Since you are bypassing the 7135/FET by going directly to the ground ring (with any of the connection points I listed above) the LED always gets power when power is applied to the driver.
You would need a firmware and driver that supports an indicator LED in order to control the LED past that.
JasonWW
JasonWW's picture
I could have done this instead of searching and probing for a positive battery source? I didn’t bother to check this because I assumed it only had power when the main beam was turned on.
Texas_Ace
Texas_Ace's picture
Well what I said above applies to the BLF FET drivers in reply to DB. Some buck and boost drivers do switch the positive side, so you need to see if yours is one of those. If so then you can usually tie into the LED ground and then into a voltage source.
The easiest way to find the V+ voltage source is generally to look for the vias from the spring and see where they come up and follow them to the first easy to tap into location.
JasonWW
JasonWW's picture
Okay, so it’s best to take it case by case. Don’t assume. Just apply power to the driver and probe around to make sure you find a good voltage source.
My next driver is going to be one of yours and it has a spot to add a “power on” led. Now since the led has to use the same negative wire as the momentary switch, can you tell me which pad is positive and negative?
I labeled them A and B.
Hmmm, maybe it’s not important. I can try the red switch wire to A and the blue switch wire to B. If the LED doesn’t light, I can switch them around.
Nope, that could damage the driver. Pad A is for the red switch wire and pad B is the ground so that gets the blue switch wire.
Oops, forgot the picture.
Texas_Ace
Texas_Ace's picture
If you are using narsil with the indicator LED then it needs to go to the correct pin, no idea which one that is as I have never used it.
If just having it on anytime power is applied then it would work the same as I listed above, you could use the bleeder resistor pads as well.
JasonWW
JasonWW's picture
I’ll have Narsil v1.2.
I’m not using the “indicator” led. I’m not sure what it’s supposed to be used for actually, but I just need a simple light to tell me if the rear switch is on or off. Nothing fancy. Positive power to the switch LED is shown on the picture above (lighted side switch). I’ll use a smd resistor to drop the power down.
The negative side of the switch LED shares the same wire as the momentary switch. So polarity of the momentary switch is a factor.
Texas_Ace
Texas_Ace's picture
The negative side of the switch LED shares the same wire as the momentary switch. So polarity of the switch is a factor.
You can connect the negative wire to any of the locations I listed above, they all go to the same place, the ground ring. Indeed the e-switch ground is perfectly fine.
The positive is the only thing you need to worry about, in the case of the TA driver the easiest V+ is the bleeder resistor, the pad closest to the LED V+ wire.
JasonWW
JasonWW's picture
I think I have it figured out now.
I can see a lot of new folks with the TA driver in an L6 that might want to do a simple lighted side switch. Beer
DB Custom
DB Custom's picture
Well, I tried it and failed… again. I tried to use a 22K resistor but that’s not going to work, not without some form of support, as the end cap simply pulls off the resistor. In trying this, I somehow messed up my FET driver. Ended up removing the SIR800DP FET and replacing it with an SIR404DP. I have it working again, without the lighted switch but with a clear boot cover and led’s on board. Still have to figure out how to power em up.
I now am getting 12.03A at the tail with the Uni-T clamp meter and 7077.5 lumens with these LiitoKala 5000mAh cells.
These pain meds are totally screwing me up! Even the MCU ended up coming off the driver! Heating up the board with my hot air to remove the FET I somehow got the MCU loose and ended up with it literally falling off when I was trying to test everything. One thing after another when you’re mentally least ready to deal with it all, but of course.
Texas_Ace
Texas_Ace's picture
What pads are you using? It is a TA driver right?
Try using the bleeder pads for the LED. Do you have a lighted tailcap? If so then yes, that will screw with things. In fact that could get interesting to figure out.
DB Custom
DB Custom's picture
Nope, just a little 17mm MTN driver board. I have a bunch of those and a bunch of Wight’s A17DD S08 boards. Richard had OshPark mess up on an order of boards where they covered the spring pad with mask. They worked it out but he had way too many of these to deal with so I bought em from him, I usually build one at a time compared to his hundreds so it works out for me. I don’t need the extra 7135 chip on a ramping e-switch driver anyway. Wink I also don’t use lighted tail caps as they’re just a battery drain for me. I like draining the battery in other ways. Big Smile
JasonWW
JasonWW's picture
What do you mean by “the end cap pulls off the resistor”?
Are you using a momentary switch like the one that comes on the FX30 driver that has the extra LED pads built in?
If so, then the polarity of the switch wires becomes a factor due to the traces on the pcb.
Normally it doesn’t matter which switch wire (red or blue) goes to ground and which goes to the “switch signal” part of the driver because it’s a simple contact switch. When you add LEDs, the polarity of the switch wires suddenly become important because the LEDs are polarity sensitive and share a ground wire with the switch.
Since the blue switch wire is a common ground (for 3 things, the switch, the left LED and the right LED) you want to make sure it’s going to a ground source. If it’s not, you need to swap the switches red and blue wires around where they make contact on the driver.
If you switch wires were backward then that might have been what caused your problem. You might have fed 3 or so volts into the switch positive trigger when its designed to only sense ground.
Polarity of the LEDs is also important. They need to be like this.
Now if your using a different momentary switch you’ll need to map out its traces on the pcb. I just used the continuity circuit on my multimeter.
Here is the switch from the FX30 again. All the blue dots go to the blue wire. Red dots to red wire.
Hopefully that will fix you up.
Etex
Etex's picture
Received shipment of my Shockli 26650 5500mah batteries today. Came with a nice case, carabiner clip, & magnets. They don’t easily make in series contact, without pretty good spring pressure, 65mm long x 26.7mm. Not enough spring reach / pressure without using magnets, at the moment, although I was able to take tail amp readings without.
Got at least an extra +1.0 tail amp measurement (9.71 @ 4.20 volts) with my cheap setup using 6” × 10ga leads over the Keeppowers. They do make the L6 with TA Driver get warm, real quick. Hard for me to get good representative distant pics, differences are more obvious in person. I can fairly easily tell the difference at a 600 feet (200m) treeline. This night shot is 150 feet (46m) to center brush/wood pile & 250 feet (76m) to background trees (just left of the wood pike in bottom pic).
Lexel
Lexel's picture
Last seen: 5 hours 52 min ago
!{width:95%}http://img.photobucket.com/albums/v335/JasonWW/Misc%2014/IMG_2967-1-1_zp...!
A is positive switch
LED positive are always on the 4.7k resistors
R1 is not populated as Narsil v1.4 does not support 2s LVP
