It can take 3-18650's Does 3 give more Lumens or just run time?
Thanks again for all the help...
Bob,
Thank you for replying. So if I use the light in the 2 18650 mode, on turbo/high say 10 min would it drop off noticeably?
Thanks,
Rick
No, it is regulated, the output stays the same, maybe sag just a little like 5% due to heat. But if you are below 15 deg C, it's generally ok.
Thanks 2100.
