Test/review of Sanyo NCR18650BF 3350mAh (Red)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 15 min ago
DSC_4238
Official specifications:
  • Rated capacity: min. 3200mAh
  • Nominal capacity: min. 3250mAh, typ. 3350mAh
  • Nominal voltage: 3.6V
  • Charging method: CC/CV
  • Charging voltage: 4.20V
  • Discharge voltage: 2.50V
  • Charging current: std. 1625mAh
  • Ambient temperatyre: Charge: 0°C ~ 45°C, discharge: -20°C ~ +60°C, storage -20°C ~ 50°C
  • Weight (max): 46.5g
Sanyo%20NCR18650BF%203350mAh%20(Red)-info
A high capacity cell from Sanyo/Panasonic, this version is improved over the NCR18650B version, but the specifications are the basically the same (My discharge curves are not).
DSC_4237
DSC_4239 DSC_4240
DSC_4241
DSC_4242
Sanyo%20NCR18650BF%203350mAh%20(Red)-Capacity
The chart looks good with fairly good tracking between the cell (Sorry about missing one 7A track).
Sanyo%20NCR18650BF%203350mAh%20(Red)-Temp-5.0
Sanyo%20NCR18650BF%203350mAh%20(Red)-Temp-7.0
The cell has a reasonable temperature at 7A.
Sanyo%20NCR18650BF%203350mAh%20(Red)-Temp-10.0
Sanyo%20NCR18650BF%203350mAh%20(Red)-CapacityTimeHours
Sanyo%20NCR18650BF%203350mAh%20(Red)-Energy
Sanyo%20NCR18650BF%203350mAh%20(Red)-PowerLoadTime
Sanyo%20NCR18650BF%203350mAh%20(Red)-TripCurrent
Sanyo%20NCR18650BF%203350mAh%20(Red)-Charge
Conclusion
A fairly good high capacity battery, but superseded by the NCR18650GA
Notes and links
Compare to 18650 and other batteries
SpaceCowboy
Last seen: 3 months 4 weeks ago
Great job like always HKJ
For those who would like to see Panasonic NCR18650BF datasheet.
Here it is:
http://www.orbtronic.com/battery-specs-datasheet/ncr18650bf-panasonic-da...
