New Olight S10RIII
9 posts / 0 new
-X3-
-X3-'s picture
Last seen: 3 hours 36 min ago
New Olight S10RIII
Just saw that new model, and noted a new LED supplier : Luminus
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 38 min ago
I wonder what the point of this model is? Do you think it will be a lot cheaper then the S1R? You have heaps of Olight flashlights do you think they need that many model that are kind of the same?
emarkd
emarkd's picture
Last seen: 3 days 12 hours ago
S10R is a reflector’ed light, so the beam is quite a bit different from the S1R with its optic. Plus its bigger, and for some folks that a good thing. Its also been around longer too, so its kind of a “legacy” item at this point. I agree there’s some overlap here with the S1R, but I think there’s enough differences for each light to have its own audience.
-X3-
-X3-'s picture
everydaysurvivalgear wrote:
I wonder what the point of this model is? Do you think it will be a lot cheaper then the S1R? You have heaps of Olight lights do you think they need that many model that are kind of the same? W
I was thinking that with the S1/S1R they will stop their reflector-based models…
But hey have some throw, which the TIR S1/S2 don’t have.
The S10RII was base on an XP-L so it has a bit of throw, nothing to compare with the S1.
The S30RIII is reflector-based too, and has the same advantage comparing to the S2 : traditional beam with a hotspot, in a compact body.
EDIT : from the Olight store, the S10RIII will be 60$ and the S1R is 65$
Thanks mate i only own the S1R so i do not know the differences. Like i could see the difference between these and the S mini. Some times it feel like Olight is competing with them selves not many companies do this.
-X3-
-X3-'s picture
They have a huge amount of different model, that’s for sure !
But the UI is consistant so you’re never lost when using them.
They have launched quite a few models recently, between the S-mini, S1A, S2A, S1R, S2R, R50, R50 PRo, S10RIII, S30RIII, X7, H1… but they make sure that the customer will find exactly what he needs I think.
If you like the Olight line, including CW tint (yeah I don’t like it) and UI (yeah, I like it), you’ll find the right shape/battery/compactness that you need.
The choice of proprietary batteries, however, is not in my taste Sad
djozz
djozz's picture
Last seen: 1 hour 31 min ago
Must have missed the SST-40, or it is a brand new led. I looked it up and it has the XM-L footprint, and similar die size, similar output (better?), low Vf, low thermal resistance, promising. Where can I buy one for testing?
will34
will34's picture
Last seen: 8 min 51 sec ago
XM-L2 with low Vf Shocked
Mitko
Mitko's picture
Last seen: 1 week 5 days ago
Well it seems like a fresh breed, nov.2016, and they claim 1200 lumens at 3amps and 85 dec C ?
Well thats new..
