BLF recoil über-thrower
384 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 3 days 23 hours ago
Nicolaas wrote:
Even if you guys could find a suitable host and reflector, won’t the placement of the led with big limitations on heat transfer limit the Amps the led will be able to endure?
And thus limit the beam intensity – throw of the light?
If a light like this can use 100% instead of roughly 75% ot the light for the spot, but the led can be driven at 75% of maximum, where’s the benefit? (other then beam characteristics).
The heat transfer will indeed be the big limiting factor, so just one arm would probably not suffice. Maybe the “Mercedes” star design would be best?
Interesting idea, bu waiting to see whether it can be turned into a practical design.
Grtz
Nico
I think some of you underestimate the thermal conductivity of a copper boom.
But we could opt for a bar across the reflector, so it goes both directions to the head.
A ‘mercedes star’ will definitely look nicer but is much more complicated to construct from one piece.
I think i will change the drawing to have a copper bar in stead of a boom, doubling the thermal conductivity.
But you should also consider that an XP-L can run 3 Amperes on a ‘normal’ aluminum MCPCB, which is absolutely not ideal.
2Q19
Enderman
Enderman's picture
Last seen: 46 min 33 sec ago
Jerommel wrote:
I think some of you underestimate the thermal conductivity of a copper boom. But we could opt for a bar across the reflector, so it goes both directions to the head. A 'mercedes star' will definitely look nicer but is much more complicated to construct from one piece. I think i will change the drawing to have a copper bar in stead of a boom, doubling the thermal conductivity. But you should also consider that an XP-L can run 3 Amperes on a 'normal' aluminum MCPCB, which is absolutely not ideal.
It's honestly not that conductive due to the distance the heat has to travel, liquid cooling work work far better but cost far more.
Maybe if you can find some heat pipes from china that would work a lot better? They transfer heat a lot better than just solid copper.
Jerommel
Jerommel's picture
Enderman wrote:
Jerommel wrote:
I think some of you underestimate the thermal conductivity of a copper boom. But we could opt for a bar across the reflector, so it goes both directions to the head. A ‘mercedes star’ will definitely look nicer but is much more complicated to construct from one piece. I think i will change the drawing to have a copper bar in stead of a boom, doubling the thermal conductivity. But you should also consider that an XP-L can run 3 Amperes on a ‘normal’ aluminum MCPCB, which is absolutely not ideal.
It’s honestly not that conductive due to the distance the heat has to travel, liquid cooling work work far better but cost far more.
Hmmm… I guess i overestimate the copper boom…
What’s in those heat pipes anyway?
I assume you mean those copper tubes used in laptop cooling etc..
2Q19
Lexel
Lexel's picture
Last seen: 1 hour 42 min ago
Heat pipes have some sort of liquid inside
If I remember right a bar of 3 heatpipes of about 5×6mm could cool my 85W Laptop CPU they were like 15cm long
They are used in big cpu coolers because they can transport heat a lot better than way thicker solid copper
I am sure a bar of 3 smaller heatpipes can easily handle 20-40W of LED power
8×2.5mm Heatpipe
https://www.aliexpress.com/item/1PCS-LOT-YT257-Flat-Copper-Heat-pipe-100...
Jerommel
Jerommel's picture
Cool! Thumbs Up
(pun not intended)
2Q19
pommie
Last seen: 1 hour 10 min ago
It will only need one pipe to handle a 50w light as roughly half is converted to light and half generated as heat, a 8mm x 2.5mm pipe will handle that with room to spare, however I would suggest two for rigidity and also the cooler a led is the more efficient it is.
Have a read of this pdf from Digi-Key.
Cheers David
Nothing to see here folks, move along...
Nicolaas
Last seen: 3 days 9 hours ago
Cheers David
Still that much?
If an XP-L HI is used at 6A @ 3,9 V, would that not mean a total energy of 23,4 Watts of which the majority is transformed into light?
Please correct me if I’m wrong, these kinda calculations are not my strong suit.
So maybe one small copper bar with one small heat pipe inside?
Grtz
Nico
djozz
djozz's picture
Last seen: 9 min 23 sec ago
The reflector that I’m checking out atm is a cheap plastic reflector used in those optical illusion discs, like this one: http://www.ebay.com/itm/Toysmith-3-D-Mirascope-6-Inch-/162165285686?hash... The focal length of this reflecor, as EasyB noted, is short, just as needed for this kind of set-up, just a bit above the edge of the reflector. I have a 6 inch version that I’m trying out, but there is a 9 inch version that should work better and have better throw. But here in The Netherlands I can not buy one for cheap, in the States they are plenty available. I think that optically the reflectors in these toys are not bad (or they would not work for the optical illusion) but I suspect that the surface does not reflect optimally, there’s more light loss there than is desirable.
In a test set-up with a XP-G2 S3 3d dedomed and direct drive (I used a 14500 zoomie flashlight without lens, so as a mule), and blocking the outer edge of the beam so that a 90mm diameter section of the reflector is used, I get 310kcd. But it is running from an Efest 14500 and the flashlight and clamp are blocking quite some light, in a better build I expect over 400kcd from this. Considering that 90mm of the reflector is used, there is room for improvement, probably with a better reflector, but it is fun anyway to see the principle working so well.
emarkd
emarkd's picture
Last seen: 19 hours 2 min ago
Alright, if you guys manage to build a recoil thrower with active liquid cooling I’m definitely in Cash
joechina
Last seen: 48 min 7 sec ago
Would a heat pipe behind the LED a good idea?
Jerommel
Jerommel's picture
Apparently, yes.
I ordered one today, hope it will arrive soon so i can check it out.
2Q19
Jerommel
Jerommel's picture
…you mean with a pump and a radiator? Big Smile
2Q19
alpg88
Last seen: 4 months 1 day ago
8×2.5mm Heatpipe
heat pipes by themselves can not handle anything, they only move heat, not dissipate it.
there is always a heatsink and fan on the other side of heatpipes, also heatpipes work well only when hot end is lower than cold end, with something stationary like a computer, you can have radiator\heatsource mounted with height difference, but a flashlight that is not stationary it is not the best solution at all.
EasyB
Last seen: 7 min 44 sec ago
alpg88 wrote:
8×2.5mm Heatpipe
I think a heatpipe is probably a good solution for getting heat away from the LED. Even if it is not oriented optimally, it’s probably a lot better than a solid piece of Cu of the same size. I could be wrong about that, but heatpipes in laptops, for example, are not oriented vertically.
I think everyone is aware that the heatpipe is just a way to transfer heat and not dissipate it. Of course it would be connected to a heatsink.
Lexel
Lexel's picture
Heatpipe is the best solution to cool a led above 15W
djozz
djozz's picture
I’m going to make my test light without active cooling: the XP-G2 will be producing about 14W of heat, let’s see if I can get that guided away fast enough, I think I can Smile
EasyB
To make this a bit more quantitative:
The thermal resistance of a piece of material with cross sectional area A, length x, and thermal conductivity k, is
R=x/(A*k)
So for a copper bar 0.5cm x 1cm and 7cm long, with k=385 W/m*K, the thermal resistance is 3.6 K/W. This is quite high when compared to other flashlight shapes/designs. For example, I did some thermal testing of a couple flashlights and found their thermal resistances (from MCPCB shelf to outside of flashlight head) were almost 10x less. Whether it’s too high depends on the power of the LED and the size of the heatsink and how hot we allow the heatsink to get.
Jerommel
Jerommel's picture
alpg88 wrote:
8×2.5mm Heatpipe
It’s supposed to transfer the heat from the LED to the head (and body) of the light in this case.
I didn’t know that it uses height differences.
If so, the drawing in opening post is upside down. Smile
I think i should have ordered more than one heat pipe maybe…
(edit) Just ordered a 2nd one.
2Q19
Jerommel
Jerommel's picture
Dang, i wish i had a mirror i could use…
…but when you say the XP-G2 will produce 14 Watts of heat, you’re apparently gonna push some 7 Amperes through it..??
2Q19
EasyB
I think the height difference is not necessary, it just helps. If the hot side is lower, the liquid that recondenses on the cold side then doesn’t have to diffuse/wick back to the hot side against gravity. Just a guess.
Enderman
Enderman's picture
djozz wrote:
The reflector that I'm checking out atm is a cheap plastic reflector used in those optical illusion discs, like this one: http://www.ebay.com/itm/Toysmith-3-D-Mirascope-6-Inch-/162165285686?hash... The focal length of this reflecor, as EasyB noted, is short, just as needed for this kind of set-up, just a bit above the edge of the reflector. I have a 6 inch version that I'm trying out, but there is a 9 inch version that should work better and have better throw. But here in The Netherlands I can not buy one for cheap, in the States they are plenty available. I think that optically the reflectors in these toys are not bad (or they would not work for the optical illusion) but I suspect that the surface does not reflect optimally, there's more light loss there than is desirable. In a test set-up with a XP-G2 S3 3d dedomed and direct drive (I used a 14500 zoomie flashlight without lens, so as a mule), and blocking the outer edge of the beam so that a 90mm diameter section of the reflector is used, I get 310kcd. But it is running from an Efest 14500 and the flashlight and clamp are blocking quite some light, in a better build I expect over 400kcd from this. Considering that 90mm of the reflector is used, there is room for improvement, probably with a better reflector, but it is fun anyway to see the principle working so well.
That's really high. Could you post a picture or link of your setup plz? Smile
emarkd wrote:
Alright, if you guys manage to build a recoil thrower with active liquid cooling I'm _definitely_ in $)
OP is not going to do that for costs reasons and convenience, but when I do in the future, I'll definitely put a build log on the forum Wink
Nicolaas wrote:
Still that much? If an XP-L HI is used at 6A @ 3,9 V, would that not mean a total energy of 23,4 Watts of which the majority is transformed into light? Please correct me if I'm wrong, these kinda calculations are not my strong suit. So maybe one small copper bar with one small heat pipe inside? Grtz Nico
The actual light efficiency of an LED drops when you give it more current, so even if the LED is 150lm/W at stock it might only be 100lm/W or less when running near max.
https://en.wikipedia.org/wiki/Luminous_efficacy
So you get about 15-20% efficiency.
I think people overestimate how efficient LEDs are, there is still a ton of energy being turned into heat.
Jerommel
Jerommel's picture
I think people don’t realise how totally inefficient incandescent lights are. Smile
2Q19
Enderman
Enderman's picture
Jerommel wrote:
I think people don't realise how totally inefficient incandescent lights are. :)
That too.
10x better efficiency than 2% is still only 20% Silly
Jerommel
Jerommel's picture
Enderman wrote:
That too.
I thought LEDs did better than 20% though, Djozz’s XP-G2 will probably survive then. Smile
2Q19
djozz
djozz's picture
The led will be reflowed on the middle of a copper bar, 3mm thick, on average 15mm wide, and 90mm long, so the heat can go in two directions 45mm far. After that it is spread out over an aluminium plate. I’m ok with the led running at 100degC I guess….
Sounds like it is made already but I have done nothing yet Silly
Enderman
Enderman's picture
djozz wrote:
The led will be reflowed on the middle of a copper bar, 3mm thick, on average 15mm wide, and 90mm long, so the heat can go in two directions 45mm far. After that it is spread out over an aluminium plate. I'm ok with the led running at 100degC I guess.... Sounds like it is made already but I have done nothing yet :P
But 95mm isn't even close to the diameter of the reflector?
A 95mm heatpipe would be good from the center to the edge, but not the full diameter, if you're talking about the 6" one.
BTW thanks for the info on these cheap mirascope reflectors Smile checking some out right now.
djozz
djozz's picture
I’m not going to use the full 6 inch, but a 9mm section (~3.5 inch). I have a feeling that that is a sort of optimal size/throw combination for this reflector.
So for the 9inch version the optimal size would be 135mm, and that may even get close to the 1 Mcd (well, 900 kcd). But as said, can’t get that one for cheap, let’s first try this one.
Jerommel
Jerommel's picture
I hope you’ll try if more will work too, because the idea is to collect / catch as much light as possible / sensible / worthwhile.
2Q19
EasyB
Collecting that last bit of light (the less intense light) will not add that much extra light (lumens), but the extra area of the reflector (going from 90 to 120mm) will add a lot more throw, assuming the reflector is shaped well enough to be focused. The light reflected from the outer portions of the reflector would make a very small hotspot.
djozz
djozz's picture
I did try what the complete reflector did, but as I was sort of playing around I did not write it down. I did give more throw but not much more, and the light will be a whole lot bigger.
