Olight S1A Head disassembly
14 posts / 0 new
Anthon
Last seen: 15 hours 40 min ago
Hi Friends
Is there a way to disassemble the S1A head or remove the blue front bezel?
I love my S1A but the tint it’s too cool for me and I’d like to swap the led with a warmer one
Anthon
I found this tutorial video from a member here
http://budgetlightforum.com/node/48826
Polaris
Last seen: 2 years 12 months ago
This disassembly video should be helpful for you:
https://www.youtube.com/watch?v=ZAgAf4D05kY
Edit: Anthon beat my by a few seconds Wink
-X3-
-X3-'s picture
Last seen: 11 hours 11 min ago
Innocent
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Anthon
I disassembled it yesterday and found that it has a thin aluminium 15mm PCB so I ordered the new parts,
XM-L2 U3 3D LED 4700-5000k. I want something similar to the MH20 NW (4500-4700k) but I can’t find it, and the T6 4C it’s too warm for me
I also ordered a 16mm noctigon PCB for it, I’ll have to file it down to 15mm but it’s for the best
-X3-
-X3-'s picture
You’ll have to sand your Noctigon down to the same thickness as original or it won’t close at all
djozz
djozz's picture
Last seen: 10 hours 30 min ago
..which is not a trivial thing to do. I always make a ‘handle’ by soldering a solid copper piece of wire from one solder pad to the other, and start sanding the Noctigon down while holding it by the piece of copper. When done, I remove the wire and reflow the led.
-X3-
-X3-'s picture
I saw your technique in a thread, really genius Smile
Also, I don’t see the necessity of swapping the stock Al board for a Noctigon…if Olight put this one I think we can keep it.
Although it’s weird, because in the S1 it was aluminum, but not in the s-mini nor the S2…
I’ll open the S1R and S2R soon to swap the emitters (will surely take some pics) and tell BLF if it’s copper or alu
Gunga
Gunga's picture
Last seen: 2 hours 37 min ago
So you have opened the s mini?
will34
will34's picture
X3 has even made a tutorial for it! I want to do a swap on my S1R, hopefully it has a Copper board.
BTW X3, did you apply glue on the bezel for resealing and what kind?
-X3-
-X3-'s picture
No glue, it’s pressed and there is a flat gasket between the bezel and the optic to ensure the sealing.
You’ll find the S-mini teardown in my signature BTW
Anthon
You don’t need glue, it’s pressed and it’s hard to put the blue bezel again. I had to get the bezel in the freezer and heat the flashlight about 50ºC to get it into it again
Now the worst part, the 20 days waiting for the new led
RobertB
RobertB's picture
Last seen: 1 week 1 day ago
Would like to change out the emitter in my S1 Cu, but afraid of damaging the copper body
mattlward
mattlward's picture
Last seen: 3 days 19 hours ago
RobertT, I have done several aluminum Olight’s now, but I am also concerned about doing my copper. I would really hate to damage the shell, I think copper is softer and I am not sure how it would affect the light after the bezel was removed and pressed back in. Really want to make it a 5A1!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
