Test/review of BestFire IMR26650 6000mAh (Purple)
Official specifications:
  • Short Circuit Protection: No
  • Battery Capacity (FastTech Tested): 4616.5 mAh
  • Battery Capacity (Mfg Rated): 6000 mAh
  • Battery Chemistry: Li-MP
  • Battery Feature: Rechargeable
  • Battery Form Factor: 26650
  • Battery Rated Voltage: 3.7 V
  • Diameter: 26.2 mm
  • Height: 65 mm
A “high” capacity, high current rated cell.
The two cells are not the same, they match in capacity, but the internal resistance is different (It is more obvious on the time charts). This also means there is a difference in current handling ability.
One cell cannot handle 15A
The other cell can handle 20A continuous drain.
But it gets to hot at 30A.
The internal resistance I calculate is 78mOhm and 44mOhm, this is a large difference.
Conclusion
I am not very impressed with the huge difference in internal resistance and I would not draw 60A from the good cell.
Notes and links
Compare to 18650 and other batteries
Compare to 26650 and other batteries
