these are the newer ones with the green bottoms.
out of the package
1.277-1.281
discharge at 500ma c9000 underway…
968 1000 1003 1078
first full discharge.
2116 2090 2097 2093
second cycle
2114 2116 2118 2111
third cycle
2098 2099 2097 2093
fourth cycle
2094 2104 2102 2096
fifth and last.
2090 2097 2093 2093
Do us a favor and see if they jam in an Ozark Trail Coleman Dorcy or other clones made by the same company.
doubt i have any of those.when test is done i can measure.
Good capacity, have had good luck with the older green/black ones as well.
For the money they perform great.
Thanks for the testing.
the earlier green/white were lousy.high ir in 20 cycles.
seems ir dropped in the first 2 cycles by the test mode(alkaleak rejection test).
went from 1.67 to 1.44
will test some fresh from the pack with the dick smith esr monday and compare to these cycled cells.
ir test dropped to 1.41 on cycle 4.
still breaking in.
4x for $6.99 = you cannot go wrong.
dia=14.39mm at the widest point.which is the wrapper overlap.
length=50.27mm - a very thin sheet of mylar i used as an insulator.
cycled and new in package ir 40mohms
