What kind of sorcery is this?
55 posts / 0 new
hIKARInoob
hIKARInoob's picture
Last seen: 2 min 35 sec ago
MAD TM26 wrote:
Jerommel wrote:
MAD TM26 wrote:
@Jerommel
I’m not sure understand you correctly? You mean like the second photo?
Yeah, but without the battery, because apparently the tube and spring add 1.3 Volts to it, so you should measure the voltage over tube and spring.
So if you can, stick the (+) probe inside the tube touching the spring.
It should read 1.3 Volts somehow.
Speaking of LSD, maybe there’s some acid in the bottom of the tube, maybe from a leaky alkaline?
I don’t know what voltage aluminium and chrome produce, but that could be it.
Does the light work properly?
You nailed it!! Acid from alkaline battery that came with it and leaked inside. Thumbs Up
Wow. Impressive how solution was found. Kudos.
Jerommel
Jerommel's picture
Last seen: 1 month 4 days ago
MAD TM26 wrote:
Jerommel wrote:
MAD TM26 wrote:
@Jerommel
I have my moments..
But it had to be either that or indeed sorcery. Big Smile
Pretty amazing though that it adds a measurable 1.3 Volts.
MAD TM26
MAD TM26's picture
Last seen: 8 months 4 weeks ago
Jerommel wrote:
I have my moments..
hehe..
Took me several attempts to get this as I have no one here to help me take this photo but here it is.
we buy light for a brighter tomorrow
pilotdog68
pilotdog68's picture
incredible
hIKARInoob
Obviously it’s not sorcery; it’s all accountable with science.
(picture taken with floating camera)
Jerommel
Jerommel's picture
LOL Big Smile
MAD TM26
MAD TM26's picture
Captured with drone Big Smile
freeme
freeme's picture
Last seen: 3 hours 19 min ago
With voice or gesture command function.tongue-out
MAD TM26 wrote:
Captured with drone :D
MAD TM26
MAD TM26's picture
Jerommel, do you think this magic can power the LED on this flashlight (i3s) if connected without the battery (of course I have to use some sort of dummy AAA)?
Asking this because the flashlight wont turn on with this 2V+ but when I use different i3s battery tube, the head is fine.
Mitko
Mitko's picture
Last seen: 4 months 1 week ago
OMG Manker started producing batteries? Wonder though…..what would be their 18650….prolly 10.5 volts or somthing
hIKARInoob
Probably not. Capacity is extremely limited. When you connect to head and try to switch on, you will get extreme voltage sag; it is not able to deliver power.
The driver does however recognise this voltage bump, so therefore it’s not working.
clemence
clemence's picture
Last seen: 41 min 19 sec ago
Amazing finding Jerommel! I’ve never thought of this before. Reminds me of Lemon battery back in my elementary grade
Jerommel
Jerommel's picture
I think it’s probably because the impaired spring and tail connection won’t allow the needed current to pass through, there are salts between them (due to acid and metal chemical reaction).
You will probably measure very very low voltage when you put a load on it.
An analogue VU multimeter would probably read much less than 2.6 Volts due to that.
You’ll have to take out the spring and clean everything with soap and scrape off the mess and then re-assemble.
dchomak
Last seen: 1 year 9 months ago
All modern volt meters, cheap or otherwise, have a very high input impedance. They can “see” a voltage thru very high resistances. As others have stated, and then reversed themselves, this volt meter is reading the boost voltage from the driver, even though there is no “connection”.
But actually there is, thru the voltmeter.
EDIT:
I base my assumptions on that it looks to me like the voltage reading is taken at the LED side of the light. The shirt clip is pointing down.
Even if that is the tail cap, I think the meter would still see the voltage thru the LED even though it is not on.
Yokiamy
Yokiamy's picture
Last seen: 25 min 4 sec ago
As Jerommel stated before, it is just a tube with a tailcap and Spring.
To identify by zooming the picture.
There is No led
Voltage reading is affected by acid from leakage.
Magneticitist
I’m kind of curious as to how much current this accidental battery tube cell can produce. We’re probably talking microamps but it could potentially power a small joule thief, which would be kind of pointless but for some reason that’s still cool to me. Not sure which metals are somehow creating this reaction but over 1v seems pretty good, I mean I can’t think of any differing metal parts in there that would actually be aligned properly enough to create that much voltage. It has to be the spring and the aluminum right?
kramer5150
kramer5150's picture
Last seen: 2 months 3 days ago
Have you checked the accuracy of your meter? How old are ITS batteries? I have found faulty meter probes to wreck all kinds of havoc on my readings, with both my Fluke and my cheaper Sears re-branded meter.
SawMaster
Last seen: 5 months 4 weeks ago
You’ve just discovered a use for lights damaged by alka-leaks; kudos!
And you’ve just infringed my patent for making free energy so be prepared to deal with my lawyers: Dewey, Cheatham, and Howe Silly
I’d have never thought about the alkaline voltage reaction still occurring here. I’m certain that there’s so little of it that it couldn’t power anything but a DMM checking voltage or an o’scope. Try it with an analog meter and it will probably read zero as those need more current to get a reading Wink
Phil
wle
wle's picture
Last seen: 3 hours 53 sec ago
i do not believe the ‘acid’ would make that much extra voltage
clean it out and remeasure
it isn;t acid anyway
there is a reason it is called an ‘alkaline’ battery
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
kramer5150
Jerommel wrote:
MAD TM26 wrote:
@Jerommel
Speaking of LSD, *_maybe there’s some acid in the bottom of the tube, maybe from a leaky alkaline?
I don’t know what voltage aluminium and chrome produce, but that could be it._*
Thats interesting… so the theory here is that there may be an electrolytic solution surrounding the spring and battery tube and thats creating the additional voltage potential. It would be really interesting to see a V measurement between the spring and battery tube.
kramer5150
wle
(enter Mythbuster mode)
I think its plausible under the right chemical and physical conditions. Its like those kids science experiments using copper and Zinc pieces where you jab them into a potato, apple or lemon and measure a voltage potential from cathode to anode.
It is voltage were measuring, not amp-current. So while there could be a voltage difference, the available current may or may not be all that much.
Wouldn’t the spring NEED to be completely electrically isolated from the body tube though? If theres any conductivity between the two then its just a short… 0V, right?
MAD TM26
MAD TM26's picture
kramer5150 wrote:
Jerommel wrote:
MAD TM26 wrote:
@Jerommel
Yep. Its here
kramer5150
Cool!!! Normally alkaline battery leaks piss me off. But this ones kind of cool. can you get a nail, screw or paperclip shove it in that rolled up paper and power the light?
[EDIT] doing that, as cool as it may be will probably tarnish the spring. and might ruin it.
wle
wle's picture
clean it and remeasure
only way to know
wle
-Greg Lemond.
