Review: Nitecore P30 (1x18650, XP-L Hi)
13 posts / 0 new
Budda
Budda's picture
Last seen: 2 months 6 days ago
I received the Nitecore P30 for the review from Nitecore.
The light comes in this box.
Inside the box: Light, cordura sheath, spare o-rings, clip, cigar ring, silica bag (inside the light), CR123 adapter (inside the light),
The P30 adopts an XP-L Hi V3 CW emitter, in a relatively big smooth reflector.
The tailcap with a forward clicky, completely exposed.
The threads on the body are anodized on both sides (so you can physically lockout the light), and are trapezoidal at the head.
The positive contact pole at the head is a raised button. So flat top and button top cells will work in the P30.
The big head has an electronic switch, with a blue LED underneath it. It has a grippy rubber cover, that protrudes a bit from the surface. The milling on the circumference of the head acts as anti-rolling devices.
The P30 can be considered a bigger and nobler relative of the C8.
UI
The clicky switch at the tailcap turns the light on and off.
Once the light is on you can cycle through the modes with the side switch (lower, low, medium, high, turbo, lower…).
Keep pressed the switch to activate strobe, another long press will activate SOS, another will activate the beacon.
The light has memory for all constant output modes and strobe.
If you turn the light on while keeping pressed the side switch, the blue LED under the switch will turn on and blink the voltage of the battery.
When the battery is running low, the blue LED under the switch will start to blink.
Beamshot at 0.5 meters from the wall
Well, no surprise here. This light can throw for sure. On my sample the spot is on the NW side, and the spill is cooler.
The spill arrives at your feet but it is very dim in brightness. The more you move from your feet, more bright will became (but remains narrow as far as output distribution)
Output and Runtime
Both tested with Nitecore 3400mAh 18650 battery.
Note that this battery is not included with the light. I just had it around.
My thoughts
Construction and finishes are as you would expect from Nitecore. The sheath is an accessory that I always appreciate, and it is good.
I would like the cigar grip to be threaded so it doesn’t spin (and could over the clip and keep it in place, preventing its movement).
Compared to other Nitecore products, this light is more simple.
You don’t have a double stage switch, no charging port, and there is only a shortcut for battery voltage and strobe.
I’d like to see a shortcut for low and turbo, and add another level between moonlight (1 tiny lumen) and low (100 lumens!), or reducing their difference. But this light is advertised for “tactical” purposes (comes with a cigar grip and remote switch available) , so I guess this also has to be considered.
This is a good light if you need a simple interface, memory and great throw.
Thanks to AntoLed for the camera and the luxmeter.
All my reviews, in italian and english, here: Lumenreviews.com
Edited by: Budda on 12/08/2016 - 14:38
Enderman
Enderman's picture
Last seen: 1 hour 7 min ago
Nice review!
Do you get the lumens with an integration sphere?
And does the luxmeter plug into a computer so that you can get the readings over time?
Budda
Budda's picture
Thanks.
No. Ceiling bounce (for the highest output) and Cd (obtaining the % of each level compared to the max output).
Yes, it has a data logger function.
Enderman
Enderman's picture
Cool Smile
Budda
Budda's picture
PJBrendel
Last seen: 2 years 5 months ago
Hmmm, just about to buy a Convoy C8 and then saw that Andrew and Amanda have the P30 on sale tomorrow for $41.00. Wondering if it’s worth twice the price of the C8? What to do?
Lexel
Lexel's picture
Last seen: 5 days 4 hours ago
Forward switch with sideswitch has advantages but also disadvantages
Its not easy to find sideswitch quick especially with gloves
The C8 is very modding friendly while the Nitecore lights are a bitch to get open and its almost impossible to mod the glued in drivers
I am a bit puzzled by the fast step down of the P30, my P12 gets to almost 65 dC when driven on turbo for 5 minutes, no stepdown visible
Does the P30 stays at max output with fan or watercooling?
PJBrendel
“Watercooling” I like that!
No moding, just want durability and dependability.
vidramon
Last seen: 1 month 4 days ago
Does someone do a tailcap amps reading of this P30 ?
Same battery, KD C8 about 3A, P30 about 2.5A and B58U about 2.7A.
What is wrong with P30 why so low amps reading ?
Mkduffer
Last seen: 4 weeks 6 hours ago
So get both, then, right? Big Smile
People say I’m a flashaholic like it’s a bad thing…
mountainair26
mountainair26's picture
Last seen: 5 days 12 hours ago
is there any info on this driver, like buck or linear etc? thanks
akoposilester
akoposilester's picture
Can you do a side by side beamshot of c8 and p30?
FL Newbie
Budda
Budda's picture
That will not be so useful. That C8 rocks a 3A driver with a 3000K XM-L2 emitter. So only the body is stock.
Now all the good C8 should run with an xp-l hi and have a completely different emitter.
