Review : Utorch UT02 Flashlight (XHP35 / 26650 / usb rechargeable)(in progress)
237 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 6 days 5 hours ago
Maybe only mine is/was faulty .
Anyway , if there is an issue it will be solved somehow .
hIKARInoob
hIKARInoob's picture
Last seen: 1 month 4 weeks ago
Contact Manker, they have the blueprint.
giorgoskok
Gearbest is the shop that sells the lights . That’s the one thing i know , and contact gearbest if you want to know the manufacturer .
I would appreciate if people who get the light report back , thanks .
Mstevens113
Mstevens113's picture
Last seen: 1 month 1 day ago
Trouble is most have no way of measuring output so won’t know if it’s working properly or not Sad
Martini
Martini's picture
Cool, thanks for reviewing this light.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
JamesB
Last seen: 1 week 1 day ago
Measuring the amps at the tail will do.
giorgoskok
Exactly
Mstevens113
Think I’ll give this one a miss.
Don’t have the equipment to measure output or amps at tail.
giorgoskok
We don’t know if any other flashlights have any problem.
We will see…
cdjaney
cdjaney's picture
Last seen: 7 months 2 weeks ago
For reference, and comparison, does anyone know what the stock Manker U21 pulls?
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
giorgoskok
From Tom E ‘s review i remember 5.45 amps in turbo .
cdjaney
cdjaney's picture
Ohhhhhh. That’s why those numbers were being quoted. Sorry. I thought that was AFTER he modded it.
Tom E
Tom E's picture
Last seen: 2 min 35 sec ago
cdjaney wrote:
Ohhhhhh. That's why those numbers were being quoted. Sorry. I thought that was AFTER he modded it.
No, it's in the review thread OP and I'll stick with stock #'s, etc. for the OP.
"On Turbo, measured 1.08A at the LED (16 AWG patch wire, UT210E clamp meter), and 5.52A at the tail with a EFEST IMR 26650 5200 mAh cell. "
cdjaney
cdjaney's picture
Tom E wrote:
No, it’s in the review thread OP and I’ll stick with stock #‘s, etc. for the OP.
“On Turbo, measured 1.08A at the LED (16 AWG patch wire, UT210E clamp meter), and 5.52A at the tail with a EFEST IMR 26650 5200 mAh cell. “
Ouch. I really hope giorgoskok’s results aren’t the norm then. Guess I’ll find out tomorrow night when mine arrives. I don’t know how to measure that, but at that much of a difference, I’m sure eyes will tell me when sitting side by side with my U21 (that I was hoping to be able to send back if this could replace it).
khas
Last seen: 8 hours 3 min ago
So far It’s three out of three that’s low in amp draw :
KawiBoy1428 wrote:
Meh, just got 2 of them today, 2.45amp and 2.22 amp on the other! Purple Efest 4200, Basen and a Imren IMR 26700 all read the same. Dust particles on/in both reflectors and a smear of shmuck on the inside of the lens on one of them! Facepalm Seem well built, focused. Don’t like the switch, sets too low for my liking, too much travel a PITA to activate for me any way, FAT fingers!!! Just wish they were cleaner inside, I’ll try blasting the crap out and clean the lens. Angry Hopefully they will clean up? Sad
mrheosuper
Last seen: 1 day 2 hours ago
2.22Amp, well, it’s even lower than some Xp-G2 flashlight
2.22*4V~9W, with 80% effective, i think the power of led is around 7W, Doubt it is over 1000 lumen
Forgot my pen
Tom E
Tom E's picture
This is what I measured on the Manker U21, CW 1A:
LightRider
LightRider's picture
Last seen: 2 years 1 month ago
mrheosuper wrote:
2.22Amp, well, it’s even lower than some Xp-G2 flashlight 2.22*4V~9W, with 80% effective, i think the power of led is around 7W, Doubt it is over 1000 lumen
If the light is making 9w, the led will see .75amps at 12v. According to the data sheet, the led should make 880-1100 lumens. However, take into aciunt eficiency and losses that means only 600-850 lumens out the front depending on the flux bin.
Tom E
Tom E's picture
Hhmm. Would be interesting to compare against the stock Manker U21 driver:
giorgoskok
Removed the driver this morning . It’s the same driver you posted Tom E .
I looked for weak connections or something suspicious but i found nothing .
So , stock numbers : Amps at the tail : 2.65A / Amps at the emitter : 0.7A / ~70kcd intensity (meter i a bit under-reading)
As a last step , i checked the sense resistor . It was the same R050 as Tom E’s driver , http://prntscr.com/dhcbsh .
I added another R050 on top of the existing one , and it was pulling 5.7A from the battery .
I let the light run for 10 mins without any issue . Charging cell now for more tests …
PS . I have already contacted gearbest to check the production with the factory .
Also UT01 came today , at least this is working properly .
freeme
freeme's picture
Last seen: 9 hours 39 min ago
Nice looking light. tongue-out
kramer5150
kramer5150's picture
Last seen: 4 months 4 days ago
They claim its 1300L, are those ANSI Lumens or just a ball park number? (looks like the latter)
Curious… how much wattage does the XHP35 need to reach 1300 emitter Lumens ?
How is the PWM ?
How did you get the UT01 so quickly?… hope mine comes soon to CA, USA.
giorgoskok
I think it only needs 800mA to 1A to reack 1300lm .
Pwm not visible , i’ll try to test with oscilloscope (if i have access this week) .
UT01 was sent with dhl .
LightRider
How is the PWM ?
It depends on the flux bin, but in this light it would probably take 14-16watts
Tom E
Tom E's picture
kramer5150 wrote:
They claim its 1300L, are those ANSI Lumens or just a ball park number? (looks like the latter) Curious... how much wattage does the XHP35 need to reach 1300 emitter Lumens ? How is the PWM ? How did you get the UT01 so quickly?... hope mine comes soon to CA, USA.
Again, the Manker U21 specs were basically copy/pasted, so I'd expect what I posted in post #48, assuming they copy/pasted the light smile.
The 1,345 lumens I measured was at 30 secs in my NIST calibrated PVC light box (ok - PVC light boxes can't be NIST calibrated, but would be nice). I'm pretty confident my PVC light box is in the ballpark from testing 100's of lights in it. The lower modes though are quite a bit off in what I measured.
It sounds like 3 of 3 received so far are doing much lower in amps, much lower in output, so....
giorgoskok
I don’t know about KWB’s lights…
Sent him a pm , never got an answer . I really don’t know .
LightRider
Tom E wrote:
kramer5150 wrote:
They claim its 1300L, are those ANSI Lumens or just a ball park number? (looks like the latter) Curious… how much wattage does the XHP35 need to reach 1300 emitter Lumens ? How is the PWM ? How did you get the UT01 so quickly?… hope mine comes soon to CA, USA.
Again, the Manker U21 specs were basically copy/pasted, so I’d expect what I posted in post #48, assuming they copy/pasted the light smile.
The 1,345 lumens I measured was at 30 secs in my NIST calibrated PVC light box (ok – PVC light boxes can’t be NIST calibrated, but would be nice). I’m pretty confident my PVC light box is in the ballpark from testing 100’s of lights in it. The lower modes though are quite a bit off in what I measured.
It sounds like 3 of 3 received so far are doing much lower in amps, much lower in output, so….
In that case, this is not high flux bin, so it looks like 18-20watts required? Is this why people are saying it’s no less to use an overdriven xpl?
khas
giorgoskok
I have seen this khas .
I sent him a pm too .
thijsco19
Last seen: 8 hours 16 min ago
Can you test if 2 26350 will fit? Without destroying the light of course..
