Review : Utorch UT02 Flashlight (XHP35 / 26650 / usb rechargeable)(in progress)
237 posts / 0 new
Lj-_-
Lj-_-'s picture
Last seen: 1 year 8 months ago
Lj-_- wrote:
AlexGT wrote:
Heat and strap wrenches, for heat you can put it in boiling water, inside of a waterproof bag, the temp will never rise above 100°C, use gloves.
That is how I managed to open my TN-31
Thanks Alex, I’ll give that a try. I assume wrapping the torch with a piece of thin rubber and using a nylon strap wrench would be best.
Ok, so I don’t have any strap wrenches, so I improvised….!
I tied some pieces of paracord to two screw drivers and wrapped two pieces of thin rubber around the body and head of the light. Then I wrapped the paracord in opposite directions several times until tight and used the screwdrivers as leverage. Same principle as using strap wrenches.
No heat required, just brute force Cool
ZozzV6
ZozzV6's picture
Last seen: 4 days 3 hours ago
Great work! Thumbs Up Tomorrow I will do mine! And add some resistor to bump up the current to a bigger but safe level.
Lj-_-
Lj-_-'s picture
Thanks.
What resistor value are you going for? I’ve got some 100 Ohm resistor’s that I’m going to try.
ZozzV6
ZozzV6's picture
Do you mean R100 labeled resistor? That is 0,1 Ohm. I have a lot R100 so I try it with that.
Lj-_-
Lj-_-'s picture
Yeah I meant R100 not 100 Ohms Facepalm
SoCalTiger
SoCalTiger's picture
In case anyone is curious, this light will work with a 3xAAA battery adapter as a power source. Out of curiosity, I tried it with some fresh AAA Eneloops. Turbo mode didn’t work but on High it was getting in the range of 400-500 lumens. The battery indicator was red in this mode due to the voltage. Not too shabby although I’m sure the runtime would not be good on High. I was considering gifting one with a NiMH option to someone who didn’t own lithium batteries.
Agro
Agro's picture
Last seen: 3 hours 14 min ago
I’ve had UT02 before and lost it.
Today I received a new one and noticed a big drop in quality:
  • the USB port cover is very flimsy
  • I got a nearly 2 mm dust particle inside reflector as well as small amount of fine dust
  • There’s ~1 mm gap between the head and the battery tube. I see grease shining in it.
KawiBoy1428
KawiBoy1428's picture
Last seen: 45 min 21 sec ago
Where did you get it from?
KB1428 “Live Life WOT
Agro
Agro's picture
I think there is exactly 1 shop that sells Utorch lights:
Gearbest.
At least that is where I bought it.
KawiBoy1428
Didn’t know that Gearbest was the exclusive seller, thanks!
Early on when they first came out I had 2 that where really dirty, the last time I purchased 4 of them was 2 Christmas’s ago and they were perfect. I was about to get 2 more?
Meh back to the quality lottery again… Facepalm
hIKARInoob
hIKARInoob's picture
No science here… But when they start selling these for less than 30 bucks… yeah, I kinda can imagine manufacturer needs to spit ‘em out faster…
giorgoskok
giorgoskok's picture
Last seen: 2 days 10 hours ago
Well , last one i received back in November was superb . I guess i was lucky …
I wish there were more hosts with this reflector diameter , like the Supwildfire 18650 light but in better quality .
arficus
Last seen: 2 weeks 4 days ago
Just got a NW one for $29. Great light. I appreciate the extra capacity of 26650, and with such a large head there’s really no reason not to use one. I would’ve paid extra $10 or so for (slightly throwier) emisar D1s, but it’s use of single 18650 in this form factor seems ridiculous.
10fp
Last seen: 1 week 11 hours ago
+ 1 exactly
BLF A6 S2+ SST40, GT Micro
a few C8`s , C8+ SST40, M21A SST40
HS 802, dd SST20 5k @4.6 amps,
P30,
Emisar D1S xp-g2 dd S4 2b
EC01
S70s,
UT02 - 5 amps and luv it ! with E2 3C
Klarus G35
Maxtoch New Sniper M24 dd U3
MF02 ,
FT03 SST40
Emisar K1
i think iv got it covered ! Wish list SP70 , SP36 BLF
komeko
komeko's picture
Last seen: 3 hours 49 min ago
For some time I wanted to improve my UT02 but … I could not take out the driver. I could not sleep tonight so I took one more approach and succeeded. As it turned out, the tile is slightly different from those in the first versions. You can see big sloppiness. In addition, I received a “corporate modification” in the form of an additional capacitor. Hmm interesting. I added the resistor R100, corrected the cables, cleaned and reassembled. It works and it’s good. The current measurement for 4.15V in turbo mode is 3.93A and in High mode 1.32A. Before modification, I had 2.9A and 0.9A. As I later make a calibrator measurement, I will complete the entry.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
komeko
komeko's picture
Supplement, before modification, color 4258K and 3292 Lux with 5m:
After modification, color 4332K and 4505 Lux with 5m:
SikSemper
Lfatman wrote:
Hello.
As the resistor mod using an R050 gets similar readings than Manker U21, and I fear it may be dangerous for the driver, I made this mod using an R100 from Fasttech.
These are my readings
Modes:
1- ———-
2- 0,20A
3- 0,62A
4- 1,34A
5- 3,85A.
I ran it in turbo mode in periods of five minutes until the voltage dropped to 3,5V
4,14V. 3,85A. 144.400 Cd.
4,01V. 5,19A. 146.160 Cd.
3,90V. 4,29A. 143.600 Cd.
3,69V. 4,47A. 145.080 Cd.
3,56V. 4,60A. 143.280 Cd.
In five minutes it gets very hot.
At 3,5V turbo mode is not maintained and the flashlight only has four modes.
Can you or someone provide a like to where you can get the resistor on fasttech? I can’t find it anywhere. Other vendors included. The main problem is that I don’t know what size resistor. Is it a 2512, 1812, 0805, 0603? Thanks
komeko
komeko's picture
The resistor has a length of about 2mm
JasonWW
JasonWW's picture
Last seen: 10 hours 40 min ago
Since you are in US, I would buy on ebay. I think you need the 1206/3216 size 1/4 watt. This is a common size for sense resistors. If you want R100, look here.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk...
komeko
komeko's picture
Too big.
Of course, the larger one will also fit, but originally it is 2mm, at least from what I remember.
JasonWW
JasonWW's picture
komeko wrote:
Too big.
So like a 2012 (2mm x 1.2mm) or 0805?
Here is one.
Lfatman
Lfatman's picture
Last seen: 1 month 1 week ago
JasonWW
JasonWW's picture
Lfatman wrote:
https://www.fasttech.com/product/1615807-1206-0-1r-smd-precision-resistors-100-piece
It’s discontinued. That’s why we can’t find it with a search of the store.
arficus
So an 1/8 W R100 would work?
JasonWW
JasonWW's picture
It looks like it. They are so cheap, you might buy some R082 and R120 as well. Maybe even some R050 to try out, but it might push the driver too hard.
vidramon
Last seen: 6 months 3 weeks ago
I don’t read whole topic but maybe some have the same problem, my sample of UT 02 is only getting barely 800 lumens, and tail current is 2.6A. Ok, I’m not expecting 1300 lumens but 1000 will be expected any situation similar to mine ??
