L T P;s new builds light bar complete @141
144 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 7 hours 1 min ago
You have made three nice lights ltp. I’ll have to take them out for a test drive next time I’m up. Beer
Whats next on the agenda? I know Rob wants a bike light. Wink
lostheplot
lostheplot's picture
Last seen: 1 day 14 hours ago
not a patch on your workmanship. you have set the bar way high mrsdnf.
I have a quad to build and that will be it for a while
but I need to plant some oats first.
I’ve got a c8 in the shed rob can have.
sorry all images down
thanks photobucket
MRsDNF
MRsDNF's picture
You are far to modest ltp. Beer
teacher
teacher's picture
Very nice indeed!!! Thumbs Up
lostheplot
So the sickness continues Assembled a few parts from kd driver from lexel some ally I had and some kindly donated by Mrs Dnf.
this wont make sense as I have just uploaded the finished product
due to photobucket issues
recess for driver and battery tube
tech specs. 3 xpl hi ta/lexel/ bistro driver single 26650 power..
thanks photobucket
CRX
CRX's picture
Last seen: 4 min 4 sec ago
Very nice, I like these Thumbs Up
MRsDNF
MRsDNF's picture
Looking good and looking forward to Sunday morning. Is your mum going out Saturday night to someones 80th?
lostheplot
no idea.see you sunday,
thanks for the kind words guys
thanks photobucket
MRsDNF
MRsDNF's picture
This is coming along nicely Ben.
I was good to catch up for brecky yesterday. Short and sweet.
Dad is still talking about his new custom built light you gifted him yesterday. Cheers.
MRsDNF
MRsDNF's picture
With those fins you should be able to get rid of a lot of heat ok.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 hour 9 min ago
What size thread do you cut lostheplot? I find the bigger the thread the easier it is to cut neatly.
lostheplot
I use 1.25 pitch
Have just bought some hss to grind my own tools as my external tool
(cheap ebay) doesnt have any rake.
I use a carbide tip job from banggood for internal
thanks photobucket
lostheplot
ok so finally done as had to wait for some 3 mm taps from ebay
battery tube is 5mm thick and 10mm where it bolts to head clamping the driver in position
bezel is bolted with 3mm studs and acorn nuts
pictured with c8 and srk
the shed 60 metres
the quality control comitee at about 50 metres
thanks for looking..lastly the lexel ta driver runs just over 11amps into the 3 by xpl2 leds
so I guessthats around the 3000 lumen
thanks photobucket
makiyoung
Last seen: 2 years 5 months ago
Maybe you can find the ic on electronic components distributor.
lostheplot
thanks for the tip but it is not wanted
thanks photobucket
MRsDNF
MRsDNF's picture
Thats one fine looking light ltp. What reflector and led did you use and was the three mm tap any good you bought of Ebay?
lostheplot
this is the reflector which I trimmed to 50mm dia
http://www.kaidomain.com/p/S021812.52mm-D-x-26mm-H-SMO-Aluminum-Reflector
slightly bigger than the srk one and a bit deeper
the leds 3 x xpl v2 hi 5000k
http://www.kaidomain.com/p/S026431.Cree-XP-L-HI-V2-3C-NW-5000K-LED-Emitter-with-KDLIGHT-3535-20-20mm-x-1_5mm-DTP-Copper-MCPCB
I am actually fairly happy with this light ran for 10 mins on high and still no ware near getting to hot I think the battery will go flat before heat becomes a problem
as it was down to 3.9v after 10 mins
http://www.ebay.com.au/itm/M3-M4-M5-M6-M8-HSS-Screw-Thread-Metric-Spiral-Hand-Plug-Tap-Kit-New/381463171403?ssPageName=STRK%3AMEBIDX%3AIT&var=650605571619&_trksid=p2057872.m2749.l2649
the taps I didn’t break them
thanks photobucket
MRsDNF
MRsDNF's picture
Thumbs Up Thanks.
lostheplot
so this will be my first build with my own reflector.
picture with a c8 reflector I used for profile.
machined some chunky fins and thread and a bezel /pill.
my knurling skills suck today just couldn’t get it right
tail cap to go and then some assembly will be using xml2u4 1a..possibly a single mode driver or a biscotti
thanks photobucket
MRsDNF
MRsDNF's picture
Are you going to dedome the led?
lostheplot
no I would not dedome it. as I will prob give this to my sister with a protected cell for her birthday.
not after any crazy outputs ,just a look what my brother gave me .
you get the idea..
thanks photobucket
lostheplot
So its done
fairly floody beam runs at 2.1amp on protected panasonic 18650
modes just on..
thanks photobucket
MRsDNF
MRsDNF's picture
I was privileged enough to see this light first hand last Friday and ltp pictures just dont do it justice. Its an amazingly compact large, little triple. Nice work ltp and really nice work. Thumbs Up
lostheplot
This is the tripple
http://tinypic.com/usermedia.php?uo=bpRy0IYlPgNVNMdYlWh%2B84h4l5k2TGxc
Couldn’t get image to work with phone
thanks photobucket
Lexel
Lexel's picture
Last seen: 4 min 57 sec ago
a lot of your old pictures are unavailiable as photobucket does not support 3. party sharing anymore
lostheplot
sorry this thread has become a bit hit and miss
I have deleted a lot and just put some finished pics up
due to the photobucket issue..
thanks photobucket
lostheplot
Well I have been assembleing a bit of stuff for another build
4 × 21700 cells
1 x xhp70.2 5000 tint
L6 smooth reflector
bistro driver from lexel
12’‘ of plastic rod
and some alloy
1st up battery holder
hogged it out a bit in the milldrill
All the slots done
Enough for today.
thanks photobucket
pinkpanda3310
Cool, looking forward to this Cool
MRsDNF
MRsDNF's picture
Me as well.
lostheplot
A little more this arvo wired the magazine
hopefully nothing will explode
thanks photobucket
