Review : Utorch UT01 Flashlight (XP-L V6 / AA & 14500 / e-switch)
383 posts / 0 new
Freedom
Freedom's picture
Last seen: 1 year 1 month ago
Thanks, George.
(Still naively? hoping for a shorter/protected/quality cell out there or a work around)
Domari Nolo “I Refuse to be Subjugated” (1st Pennsylvania Regiment Flag) https://www.1stcontinentalregiment.org/blank
(Flagguys.com):..and man o man did they ever refuse to be subjugated. These guys were everywhere. They were important in Washington’s siege of Boston. They stayed behind and were the last to leave after covering the main army’s dangerous nick of time retreat from Long Island. They crossed the Delaware with Washington. They were “..at Brandywine, Germantown, Monmouth, and every major skirmish, and battle all the way to Yorktown..” where they fought “the most important part of the siege” according to General Steuben. These guys saw action in every one of the original 13 colonies.
evankouros
evankouros's picture
Last seen: 6 days 4 min ago
Thanks Giorgos! Thumbs Up
Give us the lumen/cd data now, cause I can’t wait… I wanna order this little AA monster and compare it ot Mi7! Big Smile
giorgoskok
giorgoskok's picture
Last seen: 4 days 14 hours ago
evankouros wrote:
Thanks Giorgos! Thumbs Up Give us the lumen/cd data now, cause I can’t wait… I wanna order this little AA monster and compare it ot Mi7! Big Smile
I will update the post when i have these values , be patient Big Smile
evankouros
I was, till I saw the first part of your review! Big Smile
giorgoskok
pirate joe 22 wrote:
Weren’t there some design problems with the Manker version ? What were they ? Is this U Torch an improvement over the Manker light ?
Only think that it needs special treatment is the length of the battery , nothing more .
giorgoskok
Updated OP with intensity measurements .
Now running runtime test (Medium mode , 14500 battery) .
Tomorrow will update with amperage draw on AA and lumens . These should have been updated today but i had zero free time…
strongest2004
strongest2004's picture
giorgoskok wrote:
I’ll give you an estimation :
Lowest – 10-25 lm
Low – 70 lm
Medium – 270 lm
High – 775 lm
Thanks for the info.
Low mode and long runtime lover…
cdjaney
cdjaney's picture
Last seen: 7 months 1 week ago
I don’t want to pull the thread off track at all…..but somebody help me. This was in the OP:
Eneloop AA 2000mAh :
Amperage Draw :
Lowest –
Low –
Medium –
High – 4.2A to 3.3A
I am not going to claim any sort of knowledge here…but how does a AA put out 4.2A??? I don’t understand all these currents, draws etc.
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
giorgoskok
I wrote it that ways because i see 4.2 amps in my clamp meter for some seconds .
Don’t forget that UT01’s driver , when you insert a AA battery acts like a boost driver . boosts 1.5 volts to 3V that led operates .
Also measured output with AA , high mode is about 340-350 lumens .
Andyman
Thanks, this has been a helpful review!
I’m not a fan of mode memory in an EDC light – do you know if there’s any reasonable way to disable this, like a solder blob across key contacts on the driver?
Thanks!
giorgoskok
Thanks!
If you short click to enable light , always starts on lowest mode .
Only longer click has the memory .
Andyman
Thanks!
Hm – OK, thanks! I thought I saw in the other video review that a regular “on” click takes it to the last-used mode.
Short-click to low sounds perfect though!
kramer5150
kramer5150's picture
Last seen: 4 months 3 days ago
Cool thanks for the review!!
Can’t wait for mine. Shipping is REALLY slow.
Mine is stuck…
“Awaiting International flight – Airline Inspection” since 12/7.
Hopefully its just a laggy tracking update.
cdjaney
cdjaney's picture
EDIT: Sorry…wrong thread.
lumiere
Last seen: 1 hour 36 min ago
Trying to decide between this and the Klarus Mi7. What are people’s thoughts on how they compare?
peteybaby
peteybaby's picture
Last seen: 1 hour 15 min ago
I was trying to make that same decision. What clinched it for me was that I want my light to come on in the lowest mode every time, and be able to cycle up through the higher modes, which the UT01 can do.
finges
Last seen: 14 hours 9 min ago
The UT01 is brighter (with Eneloops) and you can buy it in NW. Easy decision Wink
wle
wle's picture
Last seen: 7 hours 54 min ago
no firefly or moonlight mode?
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
cloggy
Last seen: 7 hours 26 min ago
Ordered NW and on the way- thanks
cloggy
Kusie
Kusie's picture
Last seen: 10 months 4 weeks ago
I had the MI7 and the Manker E11 (the Original of this clone) and kept the Manker. Both are excellent AA/14500 lights with lots of power, but the beam pattern is completely different. MI7 has XP-L Hi and is more like a little thrower (tight bright spot and much darker spill) , and it´s only available in cold white. The Manker on thr other side is much floodier, which I prefer as an EDC that is also used indoors. Plus it´s available in neutral white.
K.
Andyman
K.
Very helpful comparison, thanks for sharing!
evankouros
+1 @Andyman. Wink
Thanks for the info Kusie. Thumbs Up
lumiere
I’m convinced. Ordered NW Smile
Antenne
Antenne's picture
Last seen: 11 hours 34 min ago
In the UI description I’m missing the “shut down” (off). I guess a longer press will do?
giorgoskok
Exactly
Threadneedle
Threadneedle's picture
Last seen: 2 weeks 6 days ago
Kusie wrote:
I had the MI7 and the Manker E11 (the Original of this clone) and kept the Manker. Both are excellent AA/14500 lights with lots of power, but the beam pattern is completely different. MI7 has XP-L Hi and is more like a little thrower (tight bright spot and much darker spill) , and it´s only available in cold white. The Manker on thr other side is much floodier, which I prefer as an EDC that is also used indoors. Plus it´s available in neutral white. K.
This mirrors my opinion.
jycheang
Last seen: 6 months 3 weeks ago
If tube almost like another one, i guess it will fit in.
I using XTAR 14500 for T01.
Freedom
Freedom's picture
OK, I’ll bite…are you contradicting post #20 and referring to post #19?
If so, many thanks for sharing your opinion (I would order at least one more if this were true).
kramer5150
Curious….
How does it draw 2.01A from a 650 mah Efest 14500 purple IMR… and achieve a 45 minute run time?
650 / 2010 = 32 min
Where are the extra amphours coming from?
evankouros
kramer5150 wrote:
Curious….
650 / 2010 = 32 min
Obviously it can’t draw the same Amperes all time it’s running.
