Trustfire mini-06
20 posts / 0 new
djozz
djozz's picture
Last seen: 13 hours 38 min ago
Trustfire mini-06
AAA, Luxeon TX led, 1-mode twisty, TIR lens, several colours.
Does anyone have one? I’m completely spoilt by great Lumintop AAAlights with wonderful Nichia 219 leds, but I have always had a soft spot for the Trustfire mini’s, and here’s one with a rare led :-). (10 dollars at KD)
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 8 min 20 sec ago
Cool! It looks the like the Olight? Its expensive for a Trustfire.
Jerommel
Jerommel's picture
Last seen: 3 weeks 4 days ago
My first thought was Olight i3E too.
It’s the same deal.
1 mode, TIR, twisty, Philips LED, $ 10.
I bet it’s the same size too.
Only difference is the grooves in the outside.
djozz
djozz's picture
I should have noticed that but I missed the Olight i3e when it came out. Even the price is similar. You must be a true Trustfire devotee to choose it (that may be me Party )
Jerommel
Jerommel's picture
I think it’s supposed to be the successor to the i3S, but it isn’t..
It’s one of the smallest AAA lights though.
pirate joe 22
Last seen: 1 week 2 days ago
is there a link
O.s.k
It looks like Olight i3e…!
Agro
Agro's picture
Last seen: 1 min 29 sec ago
Does anyone have it?
I consider buying one for the simple reason that it’s the smallest glue-free AAA flashlight that I found….but unless quality is OK this purchase doesn’t make sense. And unless it’s actually glued.
Agro
Agro's picture
I found a couple of reviews. Sadly, they are in German and they are videos – so I can’t translate them…
https://www.youtube.com/watch?v=EdDSrRF6lPE
https://www.youtube.com/watch?v=v06BQledDjY
Agro
Agro's picture
Seeking for any info related to the light I found its sibling, Trustfire Mini3. Not to be confused with Mini-03 which is completely different.
Mini3:
  • has exactly the same dimmensions as mini-06
  • completely different styling, but it looks just as bad
  • has a different LED
  • has a different driver (this one accepts 10440 and has 2 modes)
  • is a bit cheaper (~$10 vs. ~$13)
Neither can be found on trustfire.com though there’s mini2 which is pretty much a 10180 variant of mini3 with micro USB (which costs about 4.5 mm). [ ADDED: it also has a different lens ]
So…is one of them counterfeit?
Is trustfire.com actual trustfire website or just random webstore?
Why is the seemingly better light cheaper?
I can’t find much info on mini2 or mini3 either.
Maybe someone has mini2 or mini3 and can share their experience?
patmurris
patmurris's picture
Last seen: 2 min 14 sec ago
A quick search came up with a listing for the Mini 06 on KD – $9.90, five colors:
TF Mini 06 on KD
I’ve had TF minis for a while… all cute SS twisties, nothing related with 06. I’m missing the 04 – not sure it ever existed.
Agro
Agro's picture
TF Mini 06 on KD
Yes, there’s a deal, that’s why I spend a lot of time to learn about it now. Wink
Noctiluco
Noctiluco's picture
Last seen: 1 hour 54 min ago
I have two Trustfire mini-06, the last one I received a month ago, from Kaidomain. Imitation but not clone of the Olight i3E. They work very well, they are powerful, apparently they reach the 90 lumens that it announces, without visible PWM, a good beam of light with its TIR plastic lens, with a little small central that makes it slightly throwing but also illuminates the environment somewhat. Cold white light, pure white, not bluish; like the i3e, it shows that the led is not Cree. The pill is not attached so there is easy access to the LED, but being a Philips LED is not worth the XP stars for Cree; In addition, the LED is inserted in the same PCB as the driver, so the change of LED I see difficult.
The light comes in a Trustfire plastic blister with technical specifications and does not support 3.7V lithium; but I have tried both units with 10440 efest and they work very well, but I have only tried them a few seconds (but a few times) and they work well, a marvel of tiny light cannons !
Sorry for the googletranslatorenglish…
Agro
Agro's picture
Thanks a lot!
I could have guessed that it had a single PCB. It’s only 2 mm longer than DQG Tiny AAA.
I was looking for a hotrod host with QTC. I was thinking about size similar to Rovyvon Aurora but much higher, possibly double output (in high CRI).
It might be possible in this host but it doesn’t look like there’s a reasonable way to get a good thermal path. Could you please tell something about the place where PCB is connected to the body? Could a MCPCB transfer heat reasonably well?
Agro
Agro's picture
I just noticed that Trustfire MINI3 likely saves some space by using a very compact TIR-reflector hybrid.
So internally it may be different from mini-06, there’s a chance it has a pill or something…
http://budgetlightforum.com/comment/1576093#comment-1576093
ADDED: and actually MINI2 has different optics than MINI3. It has a regular TIR.
Agro
Agro's picture
I found a mini-review of MINI3. Smile
Quote:
La linterna es muy pequeña, demasiado quizá, lo cual la hace apta para llevar en el llavero, su foco de luz es regular para su tamaño, pero el haz es el típico foco con perfil cuadrado que ofrecen algunas linternas cuando se alarga el zoom. Lo peor de la linterna es que no tiene botón de encendido y apagado, es lo que más decepciona de ella, hay que hacerlo enroscando y desenroscando la cabeza
Automatic translation:
Quote:
The flashlight is too small, too maybe, which makes it fit to carry on the keychain, your light spotlight is regular for your size, but the beam is the typical Square-profile focus that offers some flashlights when zoom is lengthened. The worst thing about the flashlight is that it has no button on and off, it’s the most disappointing thing about her, you have to do it by curling and unscrewing your head.
https://www.aliexpress.com/item/4000188578372.html
Small twisty, that’s expected. Square beam? Weird.
Anyway, I’m waiting for 11.11 to get one. Smile
Noctiluco
Noctiluco's picture
Not square, rounded and typical TIR lens beam; strange review…
Agro
Agro's picture
I’ve got my Mini3.
Wow, it’s an interesting light! Cool
Beam shape is unusual. Small (for a 14 mm head), intense square hotspot + wide spill. The hotspot is like aspheric but not in full focus, no die details, the corners are rounded. Chromatic aberration at the edge of the hotspot.
Quite bright.
I thought I was buying a flooder but it’s actually quite a thrower (for the size).
~60.5 mm length turned off, 60 mm turned on. I guess the former matters more. Wink
Threads are anodized, there’s a spring on the tail and solid contact on the driver.
Looks OK.
It has a pill! I strongly believe it’s the smallest 10440 light with this feature. Smile
I don’t want to break it but I’m so anxious to see whether it’s possible to swap the LED that I decided to open it anyway.
I tried unscrewing it. It moved of 1/2 turn then stopped. I see something reflective on the threads. Glue?
I tried scrapping it with pliers, I can’t.
What would be the next steps to open it?…
ADDED:
Driver?
I see quite a few components on the battery side…
According to manual, it features:
Constant current. Thumbs Up
Temperature control. Thumbs Up
LVP with reduced output near the limit. Thumbs Up
One mode. With a (claimed) 350 lm light that’s less than optimal…. Sad
But anyway, this is not a kind of light I would expect from a *fire brand.
DBSAR
DBSAR's picture
Last seen: 8 hours 8 min ago
I still carry the original stainless steel Mini-01 (with the BLF Mini-01 driver) on my key chain after 6 years, it still works great. Big Smile
Agro
Agro's picture
"Agro" wrote:
I wonder how would MINI3 work with MINI2 10180 body. Smile
No, with modestly charged cell (3.7V) the voltage breaks down to 1.x V and there’s 0 light coming out.
Needs a driver swap. Wink
ADDED:
Not to spam the thread too much I decided to just add a reference to a beamshot to my last post rather than write a new one about it:
http://budgetlightforum.com/comment/1593605#comment-1593605
