Test/review of Keeppower IMR18650 NH1830 3000mAh (Black) 2016
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 36 min 48 sec ago
DSC_7332
Official specifications:
  • Nominal capacity: 3000mAh
  • Minimum capacity: 2900mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20V 0/-0.05V
  • Standard discharge cut-off: 2.50V
  • Standard charge current: 1000mA
  • Charge current cut-off: 50mA
  • Max. Constant discharge current: 20A
  • Max. Pulse discharge current: 35A
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-info
A high current and high capacity 18650 cell from Keeppower.
DSC_7330
DSC_7333 DSC_7334
DSC_7335
DSC_7336
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-Capacity
The two cells tracks perfectly.
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-Temp-15.0
At 15A the cells gets warm.
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-Temp-20.0
At 20A they get hot enough that I had to terminate the discharge just before the cell is empty.
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-Temp-30.0
At 30A the temperature reach 87°C after I terminated.
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-CapacityTimeHours
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-Energy
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-PowerLoadTime
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-TripCurrent
Keeppower%20IMR18650%20NH1830%203000mAh%20(Black)%202016-Charge
Conclusion
This is very good high current cells, but watch out for the temperature when running at 20A+.
Notes and links
The batteries was supplied by Keeppower for review.
Compare to 18650 and other batteries
Edited by: HKJ on 12/29/2016 - 09:02
will34
will34's picture
Last seen: 3 hours 53 min ago
Thanks for the test!
Looks like a 30Q but comparing the two it seems like this keeppower has better performance.
Jinx
Jinx's picture
Last seen: 13 hours 32 min ago
Location: Just outside the EU, maybe, one day, possibly
Impressive cells!
Hikelite
Last seen: 2 days 58 min ago
Nope, on the better performance part.
Here is the graph comparison from HKJ’s comparator. (If you don’t see the image you may post that you don’t see it.)
It matches 30Q.
Speed4goal
Last seen: 12 months 1 day ago
Looks like the new batches of hg2 mooch has been talking about. He rates this last year of hg2 as a 18-19 amp cell. Says they overheat at 20amps now when they didn’t when they first came out.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
light-wolff
The discharge curves look much more like 30Q than HG2.
Speed4goal
Your one of the battery experts wolf. So 30q it is
evankouros
evankouros's picture
Last seen: 1 month 1 day ago
Thanks for one more great review HKJ. Thumbs Up
Seeing HKJ’s battery test comparator I thought it was a disguised 30Q, but after 15A looks like the Keeppower has better performance. Impressive high drain 18650, I hope for some promo prices in the near future…
