Difference between Ultrafire WF-501B T6 and Ultrafire WF-502B T6
Difference between Ultrafire WF-501B T6 and Ultrafire WF-502B T6???
The host?
There is a comparison shot in this review here:
Don't be confused by the beamshots in that link as they were using different emitters. Just use it to see the body style and sizes. IMHO the 502B is usually the better choice and usually the better quality.
502B has muxh better build quality
Txs guys,
I want to know more about the beamshots etc.?? I need to import 6, for friends.. and need to make sure which one is the best....
The 502 is a much better body than the 501. The only disadvantage is if you want to mount it on a rifle because there are no remote switches available for it.
There will be no difference between the beamshots of a 501B and 502B assuming that both host the same P60 drop-in.
Given the choice between a 501b and a 502b, I'd always take a 504b. ;)
Depending on what you want to do and what your requirements are, there may be better choices than a P60 host though.
Txs Oxy,
I'm looking for a single cell(18650) type, max lumens / best light....
you recon the 504B............. why??
Just like Oxy M. ro change the rules..... I thought it was 501 or 502 as in the OP.
The 504B is better because it can tailstand and is essentially a Solarforce L2 clone so its parts will usually lego-fit with Solarforce parts.
If its now a choice of 501,502 or 504 I too would say go 504.
What about this one....... UniqueFire M2 T6???
Can this also be compared against???
http://www.manafont.com/product_info.php/uniquefire-m2-t6-5mode-memory-led-flashlight-18650-p-7159
Another vote for the 504.
I'll go for the 504 too.
501A is THE garbage par excellance of p60 hosts, period. The only positive thing is it's compactness. The rest is miserable compared to all other p60 hosts. honest price for the host alone would be 4usd delivered. Would not buy even at 3 usd.
I prefer my 501 to 502 but it was due to poor manufacturing. Most of the threads on my 502 tail were stripped making it hard to put the tail cap on. 504 is my pick of the 3
