Test/review of Soshine 18350 1000mAh (Black)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 17 min 35 sec ago
DSC_5276
Official specifications:
  • Battery Capacity (Mfg Rated): 1000 mAh
  • Battery Chemistry: Li-ion
  • Battery Feature: Rechargeable
  • Battery Form Factor: 18350
  • Battery Maximum Voltage: 4.2 V
  • Battery Rated Voltage: 3.7 V
  • Minimum capacity: 900mAh
  • Internal resistance: 80 milliohm
  • Standard charge current: 200mA
  • Fast charge current: 1000mA (1.2hrs)
Soshine%2018350%201000mAh%20(Black)-info
A 18350 with fairly good capacity from Soshine, the specified capacity and fast charge rate is a bit on the high side.
DSC_5275
DSC_5277 DSC_5278
DSC_5279
DSC_5280
DSC_5281
Soshine%2018350%201000mAh%20(Black)-Capacity
The curves matches fairly well and the cell can easily handle 3A.
Soshine%2018350%201000mAh%20(Black)-Temp-3.0
Soshine%2018350%201000mAh%20(Black)-Temp-5.0
Soshine%2018350%201000mAh%20(Black)-Temp-7.0
Soshine%2018350%201000mAh%20(Black)-CapacityTimeHours
Soshine%2018350%201000mAh%20(Black)-Energy
Soshine%2018350%201000mAh%20(Black)-PowerLoadTime
Soshine%2018350%201000mAh%20(Black)-TripCurrent
Soshine%2018350%201000mAh%20(Black)-Charge
Conclusion
The cell has fairly good capacity and is not a high current cell.
Performance is good, but there are cells with either more capacity or higher current.
Notes and links
Comparison to other LiIon batteries
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 3 hours 52 min ago
Thanks mate for the review! I have a few Soshine 16340s they are good quality but not high drain. Soshine usually makes good cells i wonder why the capacity is so much lower then rated.
kotobuki
Last seen: 7 hours 25 min ago
Thank you very much HKJ, I’ve been looking for 18350 battery.
